Brand
HP DesignJet T1700 Thermal InkJet Large Format Printer
Quicklinx: F482WS00 Mfr#: W6B55A#B19
Type: Printer
Functionality: Printer
Wireless Capability: Wired, Wireless
Max Paper Size: 1118 x 1676 mm
£3,919.84 ex VAT
£4,703.80 inc VAT
Confidently take CAD, GIS colour reproduction to the next level with a 44-in (1118 mm) printer that delivers powerful security features, high productivity on even the most complex files with the Adobe PDF driver, and bright and precise colours.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
HP DesignJet T1700 - large-format printer - colour - ink-jet
Printer Type
44" large-format printer - ink-jet - colour
72 kg
English, German, French, Italian, Spanish / Europe
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
6-ink - cyan, magenta, yellow, photo black, pigment matte black, grey
Max Media Size
1118 x 1676 mm
Min Media Size (Custom)
210 mm x 279 mm
Max Media Size (Custom)
1118 mm x 1676 mm
Print Speed
Up to 0.55 min/page - line drawing B/W - A1 (594 x 841 mm) , Up to 0.55 min/page - line drawing B/W - ANSI D (559 x 864 mm)
Max Resolution (B&W)
2400 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
Cutter
Gigabit LAN, USB host
RAM Installed (Max)
4 GB
Hard Drive
500 GB
Language Simulation
CALS G4, HP GL/2, TIFF, URF, JPEG
Media Type
Plain paper, vinyl, bond paper, film, backlit paper, translucent bond paper, photographic paper, glossy paper, matte paper, semi-gloss paper
Print server
Printer Features
Print from mobile device, 128GB virtual memory
Environmental Standards
EPEAT Bronze
180.2 cm x 69.5 cm x 99.8 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
6 x 2112 nozzles
Minimum Ink Droplet Size
6 pl
Ink Cartridge Configuration
6 cartridges (1 each: cyan, magenta, yellow, grey, photo black, matte black)
Print Speed
Wireless
2400 x 1200 dpi
2400 x 1200 dpi
Language Simulation
Cutter
Printer Features
RAM
RAM Installed (Max)
4 GB
Storage
Hard Drive
500 GB
Media Handling
Media Type
Max Media Size
1118 x 1676 mm
210 mm x 279 mm
1118 mm x 1676 mm
Media Sizes
A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), 210 x 279 mm, 1118 x 1676 mm
Media Thickness Range
Up to 0.8 mm
Media Weight
60 g/m² - 328 g/m²
Media Feeders
1 x manual - 1 roll - 1118 x 1676 mm weight: 60 g/m² - 328 g/m²
Print server
Remote Management Protocol
HTTPS
Security Protocols & Features
TLS, IPsec, 802.1x
1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Self-Encrypting Drive (SED) support, Adobe PDF Print Engine
CSA, VCCI, SABS, CCC, EMC, PSB, FCC, IRAM, RoHS, EN 60950-1, KCC, WEEE, ICES, REACH, LVD, EAC, BIS, ACMA, RSM
Power supply - internal
Frequency Required
50/60 Hz
100 Watt
Power Consumption Sleep
6.5 Watt
Software Included
Drivers & Utilities, HP Web JetAdmin, HP Embedded Web Server, HP Click, HP JetAdvantage Security Manager, HP Partner Link, HP MPS
EPEAT Compliant
EPEAT Bronze
ENERGY STAR
Limited warranty - parts - 2 years
5 °C
20 - 80%
Sound Emission (Idle)
15 dBA
Sound Emission (Operating)
45 dBA
180.2 cm
69.5 cm
99.8 cm
72 kg
Width (Shipping)
195.5 cm
Depth (Shipping)
77 cm
Height (Shipping)
71 cm
Weight (Shipping)
126 kg
Type: Printer
Wireless Capability: Wireless
Brand: HP
Price Range Ex VAT: £1500+
