The easy-to-use 610 mm (24-inch) HP DesignJet T120 Printer gives you more for your money – including front-loading media roll and built-in A3/B+ tray, wireless connectivity, intuitive touchscreen, and easy operation.
VALUE-More for your money
Take control of your print jobs-print technical documents in-house-and help save time and money.Easily print project sets and PDF documents with HP Click printing software.Get HP DesignJet quality in small-format sizes-print half-size documents with the A4/A3 input tray.Print faster-get A1/D prints in 45 sec from the roll, cut sheets at 6 pages per minute from the sheet feeder. -
SUPER COMPACT-This printer can fit anywhere
The most compact 610 mm (24-inch) printer is the perfect fit for your studio or office.Fits anywhere-place this printer on your desktop, shelf, or wherever it's convenient with the optional stand.Move this printer any time, any place-with Wi-Fi connectivity, all you need is a power plug.The professional look and feel of this printer is designed to complement your workplace. -
MOBILE-Easily print from everywhere
Print easily from your smartphone or tablet with HP Mobile Printing.When you're on-the-go, you can print a file by sending an email to the printer using ePrint.HP Smart app provides additional printing and collaboration features.
- HP DesignJet T120 - large-format printer - colour - ink-jet
- Printer Type
- 24" large-format printer - ink-jet - colour
- 25.5 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, pigment black
- Max Media Size
- Roll A1 (61.0 cm x 45.7 m)
- Min Media Size (Custom)
- 210 mm
- Max Media Size (Custom)
- 610 mm x 45.7 m
- Print Speed
- Up to 1.17 min/page - black draft - ANSI D (559 x 864 mm) , Up to 1.17 min/page - colour draft - ANSI D (559 x 864 mm) , Up to 1.17 min/page - black draft - A1 (594 x 841 mm) , Up to 1.17 min/page - colour draft - A1 (594 x 841 mm)
- Max Resolution (B&W)
- 1200 dpi
- Max Resolution (Colour)
- 1200 dpi
- Cutter
- Interface
- USB, LAN, Wi-Fi
- RAM Installed (Max)
- 256 MB (256 MB)
- Language Simulation
- PCL 3
- Media Type
- Plain paper, photo paper, glossy photo paper, bond paper, recycled paper, film, coated paper, heavy-weight coated paper, semi-gloss photo paper, matte film, vellum paper, satin photo paper, glossy paper
- Networking
- Print server - Ethernet, Fast Ethernet, IEEE 802.11
- System Requirements
- Linux, Microsoft Windows XP Professional x64 Edition SP3, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Microsoft Windows 7 Home Premium (32/64 bits), Microsoft Windows Vista Business (32/64 bits), Microsoft Windows Vista Home Premium (32/64 bits), Microsoft Windows Vista Ultimate (32/64 bits), Microsoft Windows 7 Professional (32/64 bits), Microsoft Windows 7 Ultimate (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Microsoft Windows XP Home Edition x64 Edition SP3, Apple OS X 10.8 Mountain Lion, Citrix XenServer, Citrix XenApp
- Microsoft Certification
- Compatible with Windows 7
- 98.7 cm x 53 cm x 28.5 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Minimum Ink Droplet Size
- 12 pl (black), 5.5 pl (colour)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Print Speed
- Built-in Devices
- Touch screen
- Connectivity Technology
- Wireless
- Interface
- USB, LAN, Wi-Fi
- 1200 dpi
- 1200 dpi
- PCL 3
- Cutter
RAM
- 256 MB / 256 MB (max)
Media Handling
- Media Type
- Max Media Size
- 210 mm
- 610 mm x 45.7 m
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), A1 (594 x 841 mm), ANSI D (559 x 864 mm), Roll (61 cm x 45.7 m)
- Media Thickness Range
- Up to 0.3 mm
- Media Weight
- 60 g/m² - 280 g/m²
- Networking
- Print server
- Data Link Protocol
- Wi-Fi CERTIFIED
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- FCC Class B certified, CSA, VCCI Class B ITE, GOST, PSB, R&TTE, RoHS, EN 60950-1, ICES Class B, CCC Class B, WEEE, REACH, KCC Class A, LVD, EuP, EMC Class B
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 35 Watt
- Power Consumption Stand by / Sleep
- 0.3 Watt
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- Windows 7/Vista - 1 GHz - RAM 1 GB - HD 1 GB , Windows XP SP3 - Pentium - 1 GHz - RAM 512 MB - HD 1 GB , MacOS X 10.6 - RAM 1 GB - HD 2 GB
Environmental Standards
- ENERGY STAR
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission (Idle)
- 16 dBA
- Sound Emission (Operating)
- 48 dBA
- 98.7 cm
- 53 cm
- 28.5 cm
- 25.5 kg
- Width (Shipping)
- 114.1 cm
- Depth (Shipping)
- 62 cm
- Height (Shipping)
- 41.5 cm
- Weight (Shipping)
- 30 kg
HP Universal Bond Paper-610 mm x 45.7 m (24in x 150ft) | In Stock | £11.37 |
