HP DesignJet T120 24" Colour InkJet Large Format ePrinter
Quicklinx: 8D4QWS00 Mfr#: CQ891A#B19
The easy-to-use 610 mm (24-inch) HP DesignJet T120 Printer gives you more for your money – including front-loading media roll and built-in A3/B+ tray, wireless connectivity, intuitive touchscreen, and easy operation.
  • VALUE-More for your money
    Take control of your print jobs-print technical documents in-house-and help save time and money.Easily print project sets and PDF documents with HP Click printing software.Get HP DesignJet quality in small-format sizes-print half-size documents with the A4/A3 input tray.Print faster-get A1/D prints in 45 sec from the roll, cut sheets at 6 pages per minute from the sheet feeder.
  • SUPER COMPACT-This printer can fit anywhere
    The most compact 610 mm (24-inch) printer is the perfect fit for your studio or office.Fits anywhere-place this printer on your desktop, shelf, or wherever it's convenient with the optional stand.Move this printer any time, any place-with Wi-Fi connectivity, all you need is a power plug.The professional look and feel of this printer is designed to complement your workplace.
  • MOBILE-Easily print from everywhere
    Print easily from your smartphone or tablet with HP Mobile Printing.When you're on-the-go, you can print a file by sending an email to the printer using ePrint.HP Smart app provides additional printing and collaboration features.
HP DesignJet T120 - large-format printer - colour - ink-jet
Printer Type
24" large-format printer - ink-jet - colour
25.5 kg
English, German, French, Italian, Spanish / Europe
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, pigment black
Max Media Size
Roll A1 (61.0 cm x 45.7 m)
Min Media Size (Custom)
210 mm
Max Media Size (Custom)
610 mm x 45.7 m
Print Speed
Up to 1.17 min/page - black draft - ANSI D (559 x 864 mm) , Up to 1.17 min/page - colour draft - ANSI D (559 x 864 mm) , Up to 1.17 min/page - black draft - A1 (594 x 841 mm) , Up to 1.17 min/page - colour draft - A1 (594 x 841 mm)
Max Resolution (B&W)
1200 dpi
Max Resolution (Colour)
1200 dpi
Cutter
USB, LAN, Wi-Fi
RAM Installed (Max)
256 MB (256 MB)
Language Simulation
PCL 3
Media Type
Plain paper, photo paper, glossy photo paper, bond paper, recycled paper, film, coated paper, heavy-weight coated paper, semi-gloss photo paper, matte film, vellum paper, satin photo paper, glossy paper
Print server - Ethernet, Fast Ethernet, IEEE 802.11
Linux, Microsoft Windows XP Professional x64 Edition SP3, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Microsoft Windows 7 Home Premium (32/64 bits), Microsoft Windows Vista Business (32/64 bits), Microsoft Windows Vista Home Premium (32/64 bits), Microsoft Windows Vista Ultimate (32/64 bits), Microsoft Windows 7 Professional (32/64 bits), Microsoft Windows 7 Ultimate (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Microsoft Windows XP Home Edition x64 Edition SP3, Apple OS X 10.8 Mountain Lion, Citrix XenServer, Citrix XenApp
Microsoft Certification
Compatible with Windows 7
98.7 cm x 53 cm x 28.5 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Minimum Ink Droplet Size
12 pl (black), 5.5 pl (colour)
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Print Speed
Built-in Devices
Touch screen
Wireless
USB, LAN, Wi-Fi
1200 dpi
1200 dpi
Language Simulation
PCL 3
Cutter
RAM
RAM Installed (Max)
256 MB / 256 MB (max)
Media Handling
Media Type
Max Media Size
210 mm
610 mm x 45.7 m
Media Sizes
ANSI A (Letter) (216 x 279 mm), A1 (594 x 841 mm), ANSI D (559 x 864 mm), Roll (61 cm x 45.7 m)
Media Thickness Range
Up to 0.3 mm
Media Weight
60 g/m² - 280 g/m²
Print server
Wi-Fi CERTIFIED
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
FCC Class B certified, CSA, VCCI Class B ITE, GOST, PSB, R&TTE, RoHS, EN 60950-1, ICES Class B, CCC Class B, WEEE, REACH, KCC Class A, LVD, EuP, EMC Class B
Power supply - internal
Frequency Required
50/60 Hz
35 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Software Included
Drivers & Utilities
System Requirements Details
Windows 7/Vista - 1 GHz - RAM 1 GB - HD 1 GB , Windows XP SP3 - Pentium - 1 GHz - RAM 512 MB - HD 1 GB , MacOS X 10.6 - RAM 1 GB - HD 2 GB
Environmental Standards
ENERGY STAR
5 °C
20 - 80%
Sound Emission (Idle)
16 dBA
Sound Emission (Operating)
48 dBA
98.7 cm
53 cm
28.5 cm
25.5 kg
Width (Shipping)
114.1 cm
Depth (Shipping)
62 cm
Height (Shipping)
41.5 cm
Weight (Shipping)
30 kg
8D4Q HP Universal Bond Paper-610 mm x 45.7 m (24in x 150ft) In Stock £11.37
