HP DesignJet 510ps - large-format printer - colour - ink-jet
Quicklinx: 5H45WS00 Mfr#: CJ997A#B19
HP's most affordable standalone printer for small studios, the new HP Designjet 510 Printer series enables you to print large format CAD drawings in-house. Achieve high-impact results quickly and easily with fine line and excellent image quality.
  • Conveniently print large-format technical drawings in-house
    Bring your CAD printing in-house and gain greater control over cost and quality. HP's most affordable standalone printer also delivers fast speeds, up to 55 seconds for a A1-sized document, and easy HP-GL/2 direct printing.
  • Enjoy performance you can rely on, with fine line and outstanding image quality
    Impress your clients with high-quality, professional-looking output: this printer's 2400 x 1200 optimised dpi resolution ensures sharp detail, fine lines and high accuracy. Process complex files easily with 160 MB memory, and enjoy HP-GL/2 support.
  • Produce high-quality technical CAD prints in-house, easily and affordably
    HP makes it easy and affordable for you to produce high-quality technical CAD prints in-house. A choice of 28-ml and 69-ml HP ink cartridges enables cost-effective printing matched to your needs. Operation is easy with an intuitive control panel.
Printer Type
42" large-format printer - ink-jet - colour
Stationary
45.2 kg
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Max Media Size
Roll (106.7 cm x 45.7 m), 1067 x 1897 mm
Max Media Size (Custom)
1067 mm x 1897 mm
Print Speed
Up to 3.5 min/page
Max Resolution (B&W)
2400 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
Cutter
Parallel, USB
RAM Installed (Max)
160 MB (416 MB)
Language Simulation
PCL 3, PostScript 3, HP RTL, HP GL/2
Media Type
Plain paper, tracing paper, vinyl, transluscent paper, satin paper, banners, canvas paper, bond paper, film, adhesive vinyl, coated paper, heavy-weight coated paper, semi-gloss photo paper, high-gloss photo paper, vellum paper
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Apple MacOS X 10.3, Apple MacOS X 10.4, Microsoft Windows Vista, Apple MacOS X 10.5
Microsoft Certification
Compatible with Windows 7
1-year warranty
169 cm x 67.4 cm x 110 cm
Printer Type
Stationary
Printer
Inkjet Technology
HP Thermal Inkjet
Minimum Ink Droplet Size
18 pl (black), 4 pl (colour)
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Print Speed
Up to 3.5 min/page
Built-in Devices
Cutter
Wired
Parallel, USB
2400 x 1200 dpi
2400 x 1200 dpi
PostScript Support
Included
Language Simulation
Cutter
RAM
RAM Installed (Max)
160 MB / 416 MB (max)
Media Handling
Media Type
Max Media Size
1067 mm x 1897 mm
Media Sizes
A2 (420 x 594 mm), A1 (594 x 841 mm), Roll A1 (61.0 cm x 45.7 m), 610 x 1897 mm, A1 Plus (610 x 914 mm)
Media Feeders
1 x manual - 1 roll - Roll (106.7 cm x 45.7 m)
Expansion Slots
1 x EIO , Memory
1 x parallel - 36 PIN Centronics , 1 x USB - 4 pin USB Type B
Spindle
Consumables Included
4 x printhead (yellow/cyan/magenta/black) , 4 x ink cartridge (yellow/cyan/magenta/black)
CSA, BSMI, GOST, CCIB, NOM, PCBC, VCCI Class A ITE, CCEE, EMC, DOC, PSB, MIC, MOC, FCC, RoHS
Power supply - internal
Frequency Required
50/60 Hz
150 Watt
Power Consumption Stand by / Sleep
17 Watt
Software Included
Drivers & Utilities, HP Instant Printing Utility
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site - response time: next business day
5 °C
20 - 80%
Sound Emission (Operating)
65 dBA
169 cm
67.4 cm
110 cm
45.2 kg
Width (Shipping)
197.5 cm
Depth (Shipping)
97.8 cm
Height (Shipping)
64.5 cm
Weight (Shipping)
105 kg
5H45 HP Universal Bond Paper-610 mm x 45.7 m (24in x 150ft) In Stock £10.39
5H45 HP Heavyweight Coated Paper-914 mm x 30.5 m (36in x 100ft) In Stock £40.57
5H45 HP Universal Bond Paper-1067 mm x 45.7 m (42in x 150ft) In Stock £18.01
5H45 HP Bright White Inkjet Paper-914 mm x 45.7 m In Stock £20.67
5H45 HP Heavyweight Coated Paper-610 mm x 30.5 m (24in x 100ft) In Stock £29.41
5H45 HP Coated Paper-914 mm x 45.7 m (36in x 150ft) In Stock £36.71
Resources
The following resources are available for the HP DesignJet 510ps - large-format printer - colour - ink-jet
