HP's most affordable standalone printer for small studios, the new HP Designjet 510 Printer series enables you to print large format CAD drawings in-house. Achieve high-impact results quickly and easily with fine line and excellent image quality.
Conveniently print large-format technical drawings in-house
Bring your CAD printing in-house and gain greater control over cost and quality. HP's most affordable standalone printer also delivers fast speeds, up to 55 seconds for a A1-sized document, and easy HP-GL/2 direct printing. -
Enjoy performance you can rely on, with fine line and outstanding image quality
Impress your clients with high-quality, professional-looking output: this printer's 2400 x 1200 optimised dpi resolution ensures sharp detail, fine lines and high accuracy. Process complex files easily with 160 MB memory, and enjoy HP-GL/2 support. -
Produce high-quality technical CAD prints in-house, easily and affordably
HP makes it easy and affordable for you to produce high-quality technical CAD prints in-house. A choice of 28-ml and 69-ml HP ink cartridges enables cost-effective printing matched to your needs. Operation is easy with an intuitive control panel.
- HP DesignJet 510ps - large-format printer - colour - ink-jet
- Printer Type
- 42" large-format printer - ink-jet - colour
- Form Factor
- Stationary
- 45.2 kg
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Max Media Size
- Roll (106.7 cm x 45.7 m), 1067 x 1897 mm
- Max Media Size (Custom)
- 1067 mm x 1897 mm
- Print Speed
- Up to 3.5 min/page
- Max Resolution (B&W)
- 2400 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Cutter
- Interface
- Parallel, USB
- RAM Installed (Max)
- 160 MB (416 MB)
- Language Simulation
- PCL 3, PostScript 3, HP RTL, HP GL/2
- Media Type
- Plain paper, tracing paper, vinyl, transluscent paper, satin paper, banners, canvas paper, bond paper, film, adhesive vinyl, coated paper, heavy-weight coated paper, semi-gloss photo paper, high-gloss photo paper, vellum paper
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Apple MacOS X 10.3, Apple MacOS X 10.4, Microsoft Windows Vista, Apple MacOS X 10.5
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 169 cm x 67.4 cm x 110 cm
- Printer Type
- Form Factor
- Stationary
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Minimum Ink Droplet Size
- 18 pl (black), 4 pl (colour)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Print Speed
- Built-in Devices
- Cutter
- Connectivity Technology
- Wired
- Interface
- Parallel, USB
- 2400 x 1200 dpi
- 2400 x 1200 dpi
- PostScript Support
- Included
- Cutter
RAM
- 160 MB / 416 MB (max)
Media Handling
- Media Type
- Max Media Size
- 1067 mm x 1897 mm
- Media Sizes
- A2 (420 x 594 mm), A1 (594 x 841 mm), Roll A1 (61.0 cm x 45.7 m), 610 x 1897 mm, A1 Plus (610 x 914 mm)
- Media Feeders
- 1 x manual - 1 roll - Roll (106.7 cm x 45.7 m)
- Expansion Slots
- 1 x EIO , Memory
- Connections
- 1 x parallel - 36 PIN Centronics , 1 x USB - 4 pin USB Type B
- Included Accessories
- Spindle
- Consumables Included
- 4 x printhead (yellow/cyan/magenta/black) , 4 x ink cartridge (yellow/cyan/magenta/black)
- CSA, BSMI, GOST, CCIB, NOM, PCBC, VCCI Class A ITE, CCEE, EMC, DOC, PSB, MIC, MOC, FCC, RoHS
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 150 Watt
- Power Consumption Stand by / Sleep
- 17 Watt
- Software Included
- Drivers & Utilities, HP Instant Printing Utility
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site - response time: next business day
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission (Operating)
- 65 dBA
- 169 cm
- 67.4 cm
- 110 cm
- 45.2 kg
- Width (Shipping)
- 197.5 cm
- Depth (Shipping)
- 97.8 cm
- Height (Shipping)
- 64.5 cm
- Weight (Shipping)
- 105 kg
HP Universal Bond Paper-1067 mm x 45.7 m (42in x 150ft) | In Stock | £18.01 |
HP Bright White Inkjet Paper-841 mm x 45.7 m (33.11in x 150ft) | In Stock | £19.61 |
HP Bright White Inkjet Paper-594 mm x 45.7 m (23.39in x 150ft) | In Stock | £14.28 |
HP Coated Paper-610 mm x 45.7 m (24in x 150ft) | In Stock | £24.80 |
HP Heavyweight Coated Paper-610 mm x 30.5 m (24in x 100ft) | In Stock | £29.41 |
HP Bright White Inkjet Paper-610 mm x 45.7 m | In Stock | £13.86 |
HP Coated Paper-914 mm x 45.7 m (36in x 150ft) | In Stock | £36.71 |
