HP CP2025 Colour Laserjet Printer
HP Color LaserJet CP2025n Printer
Quicklinx: 6CYWWS00 Mfr#: CB493A#B19
Do more colour business printing and in-house marketing with the powerful HP Color LaserJet CP2020 Printer series. Easy to use, with fast speeds up to 20 ppm A4 black and colour, and exceptional colour print quality with HP ColorSphere toner.
  • Enhances productivity
    Enjoy color printing without sacrificing speed with the HP Color LaserJet CP2025 printer series. Get your output and return to work quickly with fast black and color print speeds of up to 21 pages per minute (ppm) on letter-size paper. Start fast and finish sooner. Typical office print job time to completion can be nearly three times faster with Instant-on technology.
  • Easy to use and affordable
    Print professional-quality brochures and more at your desk. With free HP marketing tools, you can easily create high-impact marketing materials on your own, without a design agency or copy shop. HP Print View allows you to see various print settings applied to your document before you print - saving money and preventing waste by eliminating unnecessary test drafts. Now you can control your marketing materials and your budget. By taking care of the simpler projects and revisions right in your office, you'll save money so you can dedicate your marketing budget to more complex promotions.
  • Print-shop quality color
    Immediately see the difference in your documents with sharper text and graphics and vibrant, attention-grabbing color. Count on consistently outstanding color with the printer's HP ImageREt 3600 technology; it's the difference between color that looks good, and color that looks exceptional.
  • Simple and intuitive operation
    Get the results you want every time you print with the print driver's new, radically simple task-based interface. See optimized output quality for each of the many supported media types. With a single click, select from a collection of pre-configured Printing Shortcuts - including settings for general everyday printing, envelopes, cardstock, glossy paper, and more.
  • Budget-friendly printing
    You can print black pages for the same cost as printing black pages on a black-and-white HP laser device. And you can still print in color! When you create your professional documents right in your office, you'll spend a fraction of what you would at a copy shop.
HP Color LaserJet CP2025 - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
22.7 kg
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 20 ppm - B/W , Up to 20 ppm - colour
Max Resolution (B&W)
600 dpi
Max Resolution (Colour)
600 dpi
Image Enhancement Technology
HP ImageREt 3600
USB
Motorola 540 MHz
RAM Installed (Max)
128 MB (384 MB) SO-DIMM 200-pin
Language Simulation
PCL 5C, PostScript 3, PCL 6
Media Type
Envelopes, transparencies, labels, plain paper, cards, recycled paper, glossy paper
Total Media Capacity
300 sheets
Monthly Duty Cycle (max)
40000 pages
Recommended Monthly Volume
750 - 2000 pages
Printer Features
HP ColourSphere Toner
Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Apple MacOS X 10.3, Apple MacOS X 10.2.8, Apple MacOS X 10.4, Apple MacOS X 10.4 or later, Microsoft Windows Vista
1-year warranty
40.5 cm x 45.4 cm x 32.2 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB
600 dpi
600 dpi
HP ImageREt 3600
PostScript Support
Standard
Language Simulation
Printer Features
Motorola 540 MHz
RAM
RAM Installed (Max)
128 MB / 384 MB (max)
Technology / Form Factor
SO-DIMM 200-pin
Slots Qty
1
Empty Slots
1
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), C5 (162 x 229 mm)
Media Weight
60 g/m² - 220 g/m²
300 sheets
Max Media Capacity
550 sheets
Output Trays Capacity
150 sheets
Duty Cycle
40000 pages
750 - 2000 pages
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
Power supply - internal
445 Watt
Power Consumption Stand by / Sleep
6.7 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
15 °C
27 °C
20 - 70%
40.5 cm
45.4 cm
32.2 cm
22.7 kg
Width (Shipping)
60 cm
Depth (Shipping)
50 cm
Height (Shipping)
47.9 cm
Weight (Shipping)
26.4 kg
