Do more colour business printing and in-house marketing with the powerful HP Color LaserJet CP2020 Printer series. Easy to use, with fast speeds up to 20 ppm A4 black and colour, and exceptional colour print quality with HP ColorSphere toner.
Enhances productivity
Enjoy color printing without sacrificing speed with the HP Color LaserJet CP2025 printer series. Get your output and return to work quickly with fast black and color print speeds of up to 21 pages per minute (ppm) on letter-size paper. Start fast and finish sooner. Typical office print job time to completion can be nearly three times faster with Instant-on technology. -
Easy to use and affordable
Print professional-quality brochures and more at your desk. With free HP marketing tools, you can easily create high-impact marketing materials on your own, without a design agency or copy shop. HP Print View allows you to see various print settings applied to your document before you print - saving money and preventing waste by eliminating unnecessary test drafts. Now you can control your marketing materials and your budget. By taking care of the simpler projects and revisions right in your office, you'll save money so you can dedicate your marketing budget to more complex promotions. -
Print-shop quality color
Immediately see the difference in your documents with sharper text and graphics and vibrant, attention-grabbing color. Count on consistently outstanding color with the printer's HP ImageREt 3600 technology; it's the difference between color that looks good, and color that looks exceptional. -
Simple and intuitive operation
Get the results you want every time you print with the print driver's new, radically simple task-based interface. See optimized output quality for each of the many supported media types. With a single click, select from a collection of pre-configured Printing Shortcuts - including settings for general everyday printing, envelopes, cardstock, glossy paper, and more. -
Budget-friendly printing
You can print black pages for the same cost as printing black pages on a black-and-white HP laser device. And you can still print in color! When you create your professional documents right in your office, you'll spend a fraction of what you would at a copy shop.
- HP Color LaserJet CP2025 - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 22.7 kg
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 20 ppm - B/W , Up to 20 ppm - colour
- Max Resolution (B&W)
- 600 dpi
- Max Resolution (Colour)
- 600 dpi
- Image Enhancement Technology
- HP ImageREt 3600
- Interface
- USB
- Processor
- Motorola 540 MHz
- RAM Installed (Max)
- 128 MB (384 MB) SO-DIMM 200-pin
- Language Simulation
- PCL 5C, PostScript 3, PCL 6
- Media Type
- Envelopes, transparencies, labels, plain paper, cards, recycled paper, glossy paper
- Total Media Capacity
- 300 sheets
- Monthly Duty Cycle (max)
- 40000 pages
- Recommended Monthly Volume
- 750 - 2000 pages
- Printer Features
- HP ColourSphere Toner
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Apple MacOS X 10.3, Apple MacOS X 10.2.8, Apple MacOS X 10.4, Apple MacOS X 10.4 or later, Microsoft Windows Vista
- 1-year warranty
- 40.5 cm x 45.4 cm x 32.2 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB
- 600 dpi
- 600 dpi
- HP ImageREt 3600
- PostScript Support
- Standard
- Printer Features
- Processor
- Motorola 540 MHz
RAM
- 128 MB / 384 MB (max)
- Technology / Form Factor
- SO-DIMM 200-pin
- Slots Qty
- 1
- Empty Slots
- 1
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), C5 (162 x 229 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 300 sheets
- Max Media Capacity
- 550 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 40000 pages
- 750 - 2000 pages
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
- Power Device
- Power supply - internal
- 445 Watt
- Power Consumption Stand by / Sleep
- 6.7 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- 15 °C
- 27 °C
- 20 - 70%
- 40.5 cm
- 45.4 cm
- 32.2 cm
- 22.7 kg
- Width (Shipping)
- 60 cm
- Depth (Shipping)
- 50 cm
- Height (Shipping)
- 47.9 cm
- Weight (Shipping)
- 26.4 kg
