HP Compaq Pro 6300 SFF PC Intel® Core™ i5-3470 Processor,4GB,500GB,DVD±RW,Win 7 Pro 64-bit
Quicklinx: 85RRWS00 Mfr#: B0F57ET#ABU
  • Core i5
  • Red Hat Enterprise Linux
  • Microsoft Windows 7 Professional 64-bit Edition
Solid PC performance. The HP Compaq Pro 6300 Small Form Factor is a versatile and powerful PC featuring customizable security and expansion features to help your business excel.
  • Proven performance, intelligent design
    Give performance a boost with the new, Intel Q75 Express chipset and the power of a 3rd generation Intel Core processor family. Get the most out of graphic-intensive applications with integrated Intel HD Graphics.Take advantage of customizable expansion options with PCI and PCI Express slots to support a variety of accessory cards. Transfer data with noticeable speed through the new USB 3.0 ports.Configure the system memory with up to 32GB of DDR3-1600 SDRAM. Multiple storage drive configurations can double your storage space or provide a convenient back-up solution.Improve productivity with independent dual monitor support. With an optional discrete graphics card, the HP Compaq Pro 6300 Small Form Factor can support up to four independent displays.Access major components with the tool-less hood removal, tool-less drive bays and slots. Upgrade components in a snap with quick release latches, green pull tabs and color coordinated cables and connectors inside PC.
  • Simplified management
    Protect your business-sensitive data with HP's certified and embedded Trusted Platform Module (TPM). Disable USB ports and slots for added security.HP BIOS and Intel Standard Manageability help control your PC fleet with features for easy management and trouble shooting.A minimum of 15 months of platform stability enables long-range planning, maintains a consistent work environment and helps minimize support costs.Rely on world-class service and support with a standard, 3-year limited warranty from HP. Additional coverage is available through HP Care Pack Services.
  • Save energy, reduce impact
    Help lower your operational costs and overall eco-footprint with an HP business PC that's ENERGY STAR qualified, EPEAT Gold registered and designed with low halogen materials.Easily optimize and maintain your PC's power settings with HP Power Assistant software, enabling you to set up custom schedules for when the machine goes into low power states.
HP Compaq 6300 Pro - SFF - Core i5 3470 3.2 GHz - 4 GB - HDD 500 GB
Personal computer - small form factor - system password, power-on password, serial port I/O control, USB port control, DriveLock
Intel Core i5 (3rd Gen) 3470 / 3.2 GHz (, up to 3.6 GHz, (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 32 GB (max) - DDR3 SDRAM - non-ECC - PC3-8500
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
22 in 1
Graphics Controller
Intel HD Graphics 2500 Dynamic Video Memory Technology
Audio Output
Stereo - integrated
1GbE
OS Provided
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Software Included
Adobe Flash Player, HP Help and Support, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, PDF Complete Corporate Edition, WinZip Basic, HP Marketplace, HP Wallpaper, Microsoft Advantage Program
33.8 cm x 37.9 cm x 10 cm
7.6 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Personal computer
Recommended Use
Small business, corporate business
Product Form Factor
Small form factor
Built-in Devices
Speaker, solenoid hood lock
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q75 Express
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
1066 MHz
Rated Memory Speed
1066 MHz
Memory Specification Compliance
PC3-8500
DIMM 240-pin
Slots
4 (Total)
Unbuffered, dual channel memory architecture
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Native Command Queuing (NCQ)
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Read Speed
40x (CD) / 16x (DVD)
Write Speed
40x (CD) / 16x (DVD±R) / 8x (DVD-R DL) / 12x (DVD+R DL)
CD / DVD Rewrite Speed
32x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM)
Card Reader
22 in 1 card reader
Supported Flash Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo, miniSD, RS-MMC, microSD, MultiMediaCardplus, SDHC Memory Card, miniSDHC, microSDHC, Memory Stick PRO-HG Duo
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Integrated
Ethernet Controller
Intel 82579LM
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" , 1 (total) / 0 (free) x external 3.5" , 1 (total) / 0 (free) x internal 3.5"
Slots
1 (total) / 1 (free) x PCI - low-profile , 2 (total) / 2 (free) x PCIe 2.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 0 (free) x CPU , 4 DIMM 240-pin
6 x USB 2.0 (4 front, 2 rear) , 1 x serial , 1 x PS/2 mouse , 1 x PS/2 keyboard , 1 x VGA , 1 x DisplayPort , 1 x audio line-in/microphone (1 in front) , 1 x audio line-out/headphones (1 in front) , 1 x audio line-out , 1 x audio line-in , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.0
System password, power-on password, serial port I/O control, USB port control, DriveLock
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE
HP Smart Buy
Power supply
Power Provided
240 Watt
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
OS Certified
Red Hat Enterprise Linux, SUSE Linux Enterprise Desktop 11
Software
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
33.8 cm
37.9 cm
10 cm
7.6 kg
10 °C
35 °C
10 - 90% (non-condensing)
