HP Compaq Elite 8300 CMT Intel® Core™ i7-3770 Processor,4GB,500GB,DVD±RW,Windows 7 Pro 64-bit
Quicklinx: 85RZWS00 Mfr#: B0F38ET#ABU
  • Core i7
  • Red Hat Enterprise Linux
  • Microsoft Windows 7 Professional 64-bit Edition
The HP Compaq Elite 8300 Business PC, part of HP's professional line of business PCs, boasts outstanding performance and quality with no compromises. The HP Compaq Elite 8300 is eco-friendly and gives you the most choice and expandability with all the manageability features you need. The HP Compaq Elite 8300 Business PC provides premier performance and reliability designed for all of your corporate applications. IT Managers will appreciate the stability and long lifecycle assurance as well as the latest security and remote management technologies and solutions.
The HP Compaq 8300 Business PC meets your business needs. The HP Elite 8300 Business PC is a durable, reliable product. It is easy to access major components with the tool-less hood removal, tool-less drive bays and slots. Fix problems in a snap with the quick release latches, green pull tabs, and color-coordinated cables and connectors inside this elite PC.
  • Protect data, access, and communication
    Every organization needs reliable ways to protect business data, safeguard personal information, and non-authorized access. HP ProtectTools provides a best-in-class suite of security technologies. The custom HP BIOS is designed with leading security, serviceability, deployment and manageability features, and the HP Compaq Elite 8300 comes with a certified TPM.
  • Save on IT costs, and save yourself legwork by reducing deskside visits
    HP Business PCs optimized with professional-grade remote manageability and security solutions that enable you to confidently manage your PCs, all from the IT management console.
HP Compaq Elite 8300 - CMT - Core i7 3770 3.4 GHz - vPro - 4 GB 500 GB
Personal computer - convertible mini tower - system password, power-on password, serial port I/O control, USB port control, DriveLock, Intel Identity Protection Technology (Intel IPT)
Platform Technology
Intel vPro Platform
Intel Core i7 (3rd Gen) 3770 / 3.4 GHz (, up to 3.9 GHz, (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
4 GB (installed) / 32 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s / SATA 3Gb/s)
Hard Drive
500 GB (20 GB cache) - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 4000 Dynamic Video Memory Technology
Audio Output
Stereo - integrated
1GbE
OS Provided
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Software Included
Adobe Flash Player, HP Help and Support, Windows 7 Professional 64-bit recovery DVD, Microsoft Security Essentials, HP ProtectTools Security Software Suite, HP Recovery Manager, HP Support Assistant, Bing Toolbar, Microsoft Office 2010 Starter, PDF Complete Corporate Edition, WinZip Basic, HP Marketplace, HP Wallpaper, HP Setup 9.0
17.8 cm x 44.5 cm x 44.8 cm
11.2 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Personal computer
Recommended Use
Small business, corporate business
Product Form Factor
Convertible mini tower
Built-in Devices
Speaker, solenoid hood lock
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.4 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q77 Express
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
1333 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
4 (Total)
Unbuffered
Hard Drive
1 x 500 GB (20 GB cache)
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Read Speed
40x (CD) / 16x (DVD)
Write Speed
40x (CD) / 16x (DVD±R) / 8x (DVD±R DL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Max Monitors Supported
2
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
SRS Premium Sound, High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Keyboard
PS/2
Mouse
Optical
PS/2
Scroll
Integrated
Ethernet Controller
Intel 82579LM
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
Bays
3 (total) / 2 (free) x external 5.25" x 1/2H , 3 (total) / 2 (free) x internal 3.5" x 1/3H
Slots
3 (total) / 3 (free) x PCI - full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x PCIe 2.0 x16 - full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 2.0 x1 - full-height , 1 (total) / 0 (free) x CPU , 4 DIMM 240-pin
6 x USB 2.0 (4 front, 2 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x DisplayPort , 1 x VGA , 1 x PS/2 mouse , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 4 x USB 3.0
System password, power-on password, serial port I/O control, USB port control, DriveLock, Intel Identity Protection Technology (Intel IPT)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE
HP Smart Buy
Power supply
Power Provided
320 Watt
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
OS Certified
Red Hat Enterprise Linux, SUSE Linux Enterprise Desktop 11
Software
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
17.8 cm
44.5 cm
44.8 cm
11.2 kg
10 °C
35 °C
10 - 90% (non-condensing)
