Small size, big value – get a lot from just one device
Set up and start printing fast with an easy-to-use, intuitive control panel.Speed through document tasks: get the first print out in a matter of seconds. Set the pace for success with an MFP that prints, copies and scans fast. -
Handle your document essentials with a single, affordable HP Color LaserJet MFP
Easily copy both sides of a two-sided ID or other small document onto the front of a single-page.Help save energy with HP Auto-On/Auto-Off Technology – intelligence that can turn your printer on when you need it and off when you don't. -
Print on your terms
Print from virtually anywhere with HP ePrint and Apple AirPrint .Share printing resources with an Ethernet network.Easily connect the MFP directly to a PC via the included Hi-speed USB 2.0 port.
- HP Color LaserJet Pro MFP M176n - multifunction printer - colour
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 20000 pages
- Recommended Monthly Volume
- 250 - 950 pages
- Max Copying Speed
- Up to 16 ppm (mono) / up to 4 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 2400 dpi (mono) / up to 2400 dpi (colour)
- Scanning
- 1200 x 1200 dpi
- Original Size
- 216 x 297 mm (max)
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, film, glossy paper
- Standard Media Capacity
- 150 sheets
- Max Media Capacity
- 150 sheets
- Output Trays Capacity
- 50 sheets
- Connection Availability
- Interface
- USB 2.0, LAN
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to folder, scan to application
- Power
- AC 230 V (50/60Hz)
- 42.3 cm x 42.5 cm x 28 cm
- 15 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Laser - colour
- 20000 pages
- 250 - 950 pages
- Display
- 2 lines x 16 characters
- Interface
- USB 2.0, LAN
- AirPrint Enabled
- Localisation
- Standard Memory
- 128 MB
- Max Supported Memory
- 128 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Printer Drivers / Emulations
- PCLm, PCLms
- Image Enhancement Technology
- HP ImageREt 2400
- First Print Out Time B/W
- 16 sec
- First Print Out Time Colour
- 27.5 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 101.6 x 152.4 mm, 76 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 150 sheets
- 150 sheets
- 50 sheets
- Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 50 sheets
- Speed Details
- Printing: up to 17 ppm (Letter A) - B/W normal , Printing: up to 4 ppm (Letter A) - colour normal , Printing: up to 16 ppm (A4) - B/W normal , Printing: up to 4 ppm (A4) - colour normal , Copying: up to 17 ppm (Letter A) - B/W normal , Copying: up to 4 ppm (Letter A) - colour normal , Copying: up to 16 ppm (A4) - B/W normal , Copying: up to 4 ppm - colour normal , Scanning: up to 7.5 ipm - B/W , Scanning: up to 5.5 ipm - colour
- 1 x USB 2.0 - 4 pin USB Type B ¦ 1 x LAN - RJ-45
- Operating System Support
- Linux, MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), MS Windows Server 2008, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 SP1 or later, MS Windows XP 64-bit Edition SP2 or later, MS Windows Server 2012, Windows 8, Windows 8 64-bit, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2003 x64 Edition SP1 or later, MS Windows Server 2008 Enterprise, MS Windows Server 2008 Standard
- Software Included
- Drivers & Utilities, Readiris, HP LaserJet Scan
- Voltage Required
- 300 watt
- Power Consumption Standby
- 8.3 watt
- Power Consumption Sleep
- 1 watt
- Consumables Included
- 1 x toner cartridge (black) - up to 500 pages , 1 x toner cartridge (cyan) - up to 500 pages , 1 x toner cartridge (magenta) - up to 500 pages , 1 x toner cartridge (yellow) - up to 500 pages
- FCC Class B certified, UL, cUL, GS, ICES-003, CISPR 22, EN55022 Class B, EMC, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60825-1, GB 17625.1, LVD, GB 9254-2008, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, EN 55024:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
- ENERGY STAR Certified
- 42.3 cm
- 42.5 cm
- 28 cm
- 15 kg
- Shipping Width
- 59.8 cm
- Shipping Depth
- 39.8 cm
- Shipping Height
- 40.9 cm
- Shipping Weight
- 18.2 kg
- Sound Emission
- 49 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80%
