HP Colour LaserJet Pro MFP M176n Multifunction Printer
Quicklinx: 9D2RWS00 Mfr#: CF547A#B19
  • Small size, big value – get a lot from just one device
    Set up and start printing fast with an easy-to-use, intuitive control panel.Speed through document tasks: get the first print out in a matter of seconds. Set the pace for success with an MFP that prints, copies and scans fast.
  • Handle your document essentials with a single, affordable HP Color LaserJet MFP
    Easily copy both sides of a two-sided ID or other small document onto the front of a single-page.Help save energy with HP Auto-On/Auto-Off Technology – intelligence that can turn your printer on when you need it and off when you don't.
  • Print on your terms
    Print from virtually anywhere with HP ePrint and Apple AirPrint .Share printing resources with an Ethernet network.Easily connect the MFP directly to a PC via the included Hi-speed USB 2.0 port.
HP Color LaserJet Pro MFP M176n - multifunction printer - colour
Multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
20000 pages
Recommended Monthly Volume
250 - 950 pages
Max Copying Speed
Up to 16 ppm (mono) / up to 4 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 2400 dpi (mono) / up to 2400 dpi (colour)
Scanning
1200 x 1200 dpi
Original Size
216 x 297 mm (max)
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, film, glossy paper
Standard Media Capacity
150 sheets
Max Media Capacity
150 sheets
Output Trays Capacity
50 sheets
Connection Availability
USB 2.0, LAN
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to folder, scan to application
AC 230 V (50/60Hz)
42.3 cm x 42.5 cm x 28 cm
15 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Laser - colour
20000 pages
250 - 950 pages
Display
2 lines x 16 characters
USB 2.0, LAN
AirPrint Enabled
Standard Memory
128 MB
Max Supported Memory
128 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Printer Drivers / Emulations
PCLm, PCLms
Image Enhancement Technology
HP ImageREt 2400
First Print Out Time B/W
16 sec
First Print Out Time Colour
27.5 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 101.6 x 152.4 mm, 76 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
150 sheets
Max Media Capacity
150 sheets
50 sheets
Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 50 sheets
Speed Details
Printing: up to 17 ppm (Letter A) - B/W normal , Printing: up to 4 ppm (Letter A) - colour normal , Printing: up to 16 ppm (A4) - B/W normal , Printing: up to 4 ppm (A4) - colour normal , Copying: up to 17 ppm (Letter A) - B/W normal , Copying: up to 4 ppm (Letter A) - colour normal , Copying: up to 16 ppm (A4) - B/W normal , Copying: up to 4 ppm - colour normal , Scanning: up to 7.5 ipm - B/W , Scanning: up to 5.5 ipm - colour
1 x USB 2.0 - 4 pin USB Type B ¦ 1 x LAN - RJ-45
Operating System Support
Linux, MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), MS Windows Server 2008, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 SP1 or later, MS Windows XP 64-bit Edition SP2 or later, MS Windows Server 2012, Windows 8, Windows 8 64-bit, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2003 x64 Edition SP1 or later, MS Windows Server 2008 Enterprise, MS Windows Server 2008 Standard
Software Included
Drivers & Utilities, Readiris, HP LaserJet Scan
AC 230 V (50/60Hz)
300 watt
Power Consumption Standby
8.3 watt
Power Consumption Sleep
1 watt
Consumables Included
1 x toner cartridge (black) - up to 500 pages , 1 x toner cartridge (cyan) - up to 500 pages , 1 x toner cartridge (magenta) - up to 500 pages , 1 x toner cartridge (yellow) - up to 500 pages
FCC Class B certified, UL, cUL, GS, ICES-003, CISPR 22, EN55022 Class B, EMC, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60825-1, GB 17625.1, LVD, GB 9254-2008, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, EN 55024:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
ENERGY STAR Certified
42.3 cm
42.5 cm
28 cm
15 kg
Shipping Width
59.8 cm
Shipping Depth
39.8 cm
Shipping Height
40.9 cm
Shipping Weight
18.2 kg
Sound Emission
49 dBA (operating)
15 °C
30 °C
10 - 80%
