HP Colour Laserjet Pro M479fdn Multifunction Printer
Quicklinx: FCX2WS00 Mfr#: W1A79A#B19
Winning in business means working smarter. The HP Color LaserJet Pro MFP M479 is designed to let you focus your time where it's most effective-growing your business and staying ahead of the competition.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
  • Built to keep you – and your business – moving forward
    Scan files directly to local Microsoft SharePoint, email, USB, and network folders.Help save time by automating all the steps in a complicated workflow and apply saved settings.Print effortlessly from any device, virtually anywhere, to any HP printer – securely through the cloud.
  • Best-in-class security – detect and stop attacks
    A suite of embedded security features help protect your MFP from being an entry point for attacks.Help ensure security of confidential information with optional PIN/Pull printing to retrieve print jobs.Optional HP JetAdvantage Security Manager lets you set configuration.Thwart potential attacks and take immediate action with instant notification of security issues.
  • Simply designed to uncomplicate your day
    Set up this MFP fast, and easily manage device settings to help increase overall printing efficiency.Tackle tasks quickly and easily – with the simple 10.9 cm colour touchscreen.Print Microsoft office formatted files in addition to PDFs right off your USB drive.Avoid interruptions with an HP LaserJet MFP designed to be streamlined for maximum productivity.
  • Sustainability is smart business
    Avoid frustrating reprints, wasted supplies, and service calls using Original HP toner cartridges.Help save paper right out of the box. The duplex print setting is set at default paper savings mode.Saves up to 18% energy over prior products.Help save energy with HP Auto-on/Auto-off technology.
HP Color LaserJet Pro MFP M479fdn - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 4000 pages
Max Copying Speed
Up to 27 ppm (mono) / up to 27 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 38400 x 600 dpi (mono) / up to 38400 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 196 dpi, 300 x 300 dpi, 203 x 96 dpi
Scanning
1200 x 1200 dpi
Display
4.3"
Original Size
102 x 152 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, glossy paper
Standard Media Capacity
300 sheets
Max Media Capacity
850 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network, scan to Cloud, Mopria certified
AC 220 V (50/60Hz)
41.6 cm x 47.2 cm x 40 cm
23.4 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Printer Fonts
TrueType x 84
Fax Type
Plain paper
Printing Technology
Laser - colour
50000 pages
750 - 4000 pages
Display Diagonal Size
4.3"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
512 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Copying Features
Collation copy, margin erase, resize, ID Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, URF, PWG
Image Enhancement Technology
HP ImageREt 3600, Pantone Calibrated
Automatic Duplexing
First Print Out Time B/W
9.7 sec
First Print Out Time Colour
11.3 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
30-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 400 pages
PC Faxing
Yes (send only)
Fax Machine Features
Speed Dialing
120 station(s)
Delayed Transmission
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax memory backup, delayed sending, fax polling, block fax, poll receive, fax activity reports, print fax log
Document & Media Handling
Min Original Size
102 x 152 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 100 x 148 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 76 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
300 sheets
Max Media Capacity
850 sheets
50 sheets
150 sheets
ADF - 50 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets size: 100 x 148 mm - Legal (216 x 356 mm) , Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm) , Output tray - 150 sheets
Speed Details
Printing: up to 28 ppm (Letter A) - B/W normal , Printing: up to 28 ppm (Letter A) - colour normal , Printing: up to 27 ppm (A4) - B/W normal , Printing: up to 27 ppm (A4) - colour normal , Printing: up to 25 ipm (Letter A) - B/W duplex , Printing: up to 25 ipm (Letter A) - colour duplex , Printing: up to 24 ipm (A4) - B/W duplex , Printing: up to 24 ipm (A4) - colour duplex , Copying: up to 28 ppm (Letter A) - B/W normal , Copying: up to 28 ppm (Letter A) - colour normal , Copying: up to 27 ppm (A4) - B/W normal , Copying: up to 27 ppm (A4) - colour normal , Copying: up to 25 ipm (Letter A) - colour duplex , Copying: up to 25 ipm (Letter A) - B/W duplex , Copying: up to 24 ipm (A4) - B/W duplex , Copying: up to 24 ipm (A4) - colour duplex , Scanning: up to 29 ppm (A4) - B/W normal , Scanning: up to 46 ipm (A4) - B/W normal , Scanning: up to 20 ppm - colour normal , Scanning: up to 35 ipm - colour normal , Scanning: up to 46 ipm - B/W duplex , Scanning: up to 34 ipm - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
LDAP, SSL, Apple Bonjour, TLS, 802.1x, EAP-TLS, PEAP, IPv6 support, SNMP 3
Operating System Support
HP-UX 11.x, SunSoft Solaris 2.5 or later, MS Windows Server 2008 x64 Edition, Sun Solaris 8, MS Windows 7, Ubuntu Linux 8.04 LTS, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows 2000 Server, MS Windows Vista (64-bit versions), SuSe Linux 10.3, HP-UX 11i, Apple Mac OS X 10.6, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Ubuntu Linux 8.04.1 LTS, Ubuntu Linux 8.04.2 LTS, Red Hat Linux 7.x or later, SUSE Linux 8.x or later, IBM AIX 3.2.5 or later, Apple Mac OS X 10.7, Debian Linux 5.0, Red Hat Enterprise Linux 5, MS Windows Server 2008 R2 x64 Edition, SuSe Linux 11.0, SuSe Linux 11.1, SuSe Linux 11.2, Debian Linux 5.0.1, Debian Linux 5.0.2, Debian Linux 5.0.3, Oracle Solaris 9, HP-UX 10.20, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, MS Windows Server 2003 SP2 or later, MS Windows Server 2003 x64 Edition SP2 or later, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit, MS Windows Server 2008 (32/64-bits)
Software Included
Drivers & Utilities, HP Web Jetadmin
AC 220 V (50/60Hz)
550 watt
Power Consumption Standby
20 watt
Power Consumption Sleep
0.7 watt
First Copy Out Time B/W
9.9 sec
First Copy Out Time Colour
12.4 sec
FCC Class B certified, CISPR 22 Class B, EN55022 Class B, RSS-210, FCC CFR47 Part 68, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, FCC CFR47 Part 15 C, GB 9254 Class B, GB 17625.1, EN 62311, EN 61000-3-3:2008, ICES-003 issue 4 Class B, EN 61000-3-2:2006+A1:2009+A2:2009, EN 300 328 V1.7.1, IEC 62479, IEC 60825-1:2007, EN 62479:2010, IEC 62311, EN 55024:2010, EN 301 489-1, GB 4943.1-2011, EN 301 489-17
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year - on-site - response time: next business day
41.6 cm
47.2 cm
40 cm
23.4 kg
Shipping Width
59.7 cm
Shipping Depth
49.7 cm
Shipping Height
49 cm
Shipping Weight
26.7 kg
Sound Emission
49 dBA (operating)
15 °C
30 °C
10 - 80% (non-condensing)
FCX2 HP 415A Black Original LaserJet Toner Cartridge In Stock £71.51
FCX2 HP 415A Cyan Original LaserJet Toner Cartridge In Stock £92.78
FCX2 HP 415A Yellow Original LaserJet Toner Cartridge In Stock £92.80
FCX2 HP 415A Magenta Original LaserJet Toner Cartridge In Stock £92.80
FCX2 HP 415X High Yield Black Original LaserJet Toner Cartridge In Stock £146.10
FCX2 HP 415X High Yield Cyan Original LaserJet Toner Cartridge In Stock £199.63
FCX2 HP 415X High Yield Yellow Original LaserJet Toner Cartridge In Stock £200.14
FCX2 HP 415X High Yield Magenta Original LaserJet Toner Cartridge In Stock £199.63
FCX2 HP Glossy Laser Paper 150GSM 150 SHT/A4 In Stock £16.68
