Winning in business means working smarter. The HP Color LaserJet Pro M454 printer is designed to let you focus your time where it's most effective-helping to grow your business and staying ahead of the competition.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
- HP Color LaserJet Pro M454dw - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- Number of Users
- 3-10 users
- 18.9 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 27 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 27 ppm - color (ISO) - A4 (210 x 297 mm) , Up to 28 ppm - B/W (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm) , Up to 28 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 49 ppm - black landscape - A5 (148 x 210 mm) , Up to 49 ppm - colour landscape - A5 (148 x 210 mm) , Up to 7 ppm - black portrait - A5 (148 x 210 mm) , Up to 7 ppm - colour portrait - A5 (148 x 210 mm) , Up to 24 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 24 ipm - colour duplex - A4 (210 x 297 mm) , Up to 25 ipm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 25 ipm - colour duplex - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 38400 x 600 dpi
- Max Resolution (Colour)
- 38400 x 600 dpi
- Image Enhancement Technology
- HP ImageREt 3600
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Preview Screen Size
- 2.7"
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 512 MB (512 MB)
- Flash Memory Installed (Max)
- 512 MB (512 MB)
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PDF, URF, PWG
- Media Type
- Envelopes, labels, plain paper, photo paper, bond paper, recycled paper, punched paper, preprinted paper, postcards, glossy paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 50000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Networking
- Print server
- Printer Features
- HP ePrint, PANTONE calibrated, Instant-on Technology
- System Requirements
- UNIX, Android, Microsoft Windows Vista (32/64 bits), Ubuntu 10.04, Microsoft Windows XP (32/64 bits) SP3, Apple MacOS X Lion 10.7, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Apple OS X 10.8 Mountain Lion, openSUSE 12.2, Red Hat Fedora 17, Ubuntu 12.10, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Red Hat Fedora 18, openSUSE 12.3, Linux Mint 13, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, openSUSE 13.1, Windows 10 (32/64 bits), Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x, Microsoft Windows 7 / 8 (32/64 bits)
- Environmental Standards
- EPEAT Silver
- 1-year warranty
- 41.2 cm x 46.9 cm x 29.5 cm
- Printer Type
- Number of Users
- 3-10 users
- Localisation
Printer
- Print Speed
- Built-in Devices
- Touch screen
- 2.7"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 38400 x 600 dpi
- 38400 x 600 dpi
- HP ImageREt 3600
- PostScript Support
- Standard
- First Print Out Time B/W
- 9.7 sec
- First Print Out Time Colour
- 11.3 sec
- Fonts Included
- 84 x TrueType
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 512 MB / 512 MB (max)
Flash Memory
- Flash Memory
- 512 MB (installed) / 512 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 100 x 148 mm, JIS B5 (182 x 257 mm), 197 x 273 mm, 76 x 127 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm
- Envelope Sizes
- International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- Media Weight
- 60 g/m² - 200 g/m²
- Media Weight (lbs)
- 16 lbs - 52 lbs
- 300 sheets
- Media Feeders
- Input tray: 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² - (16 lbs (min) - 52 lbs (max)) , Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² - (16 lbs (min) - 52 lbs (max)) , Output tray: 1 x automatic - 150 sheets
- Max Media Capacity
- 850 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 50000 pages
- 750 - 4000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, SNMP 2, SNMP 3, HTTP, HTTPS, SLP, IPv4, IPv6
- SSL, Apple Bonjour, WEP, TLS, WPA, WPA2, 802.1x, TKIP, AES, WPS, Wi-Fi Direct, WPA-Enterprise
- Connections
- 1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- FCC Class B certified, UL, CISPR 22 Class B, cUL, GS, EMC, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, CECP, EN 61000-3-3:2008, IECEE CB, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, ICES-003 issue 5 Class B, EN 62479:2010, LVD 2006/95/EC, 21 CFR 1040.10, 21 CFR 1040.11, CoC, EN 55024:2010, IEC 60950-1:2005 + A1:2009, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN 55022:2010 Class B
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 550 Watt
- Power Consumption Stand by
- 17 Watt
- Power Consumption Sleep
- 0.9 Watt
- Software Included
- Drivers & Utilities, HP Update, HP Software Installer, HP Software Uninstaller, HP Device Experience (DXP), HP Connected, HP Product Improvement Study, Product Registration Assist, HP Device Toolbox
- OS Required
- EPEAT Compliant
- EPEAT Silver
- Blue Angel
- ENERGY STAR
- Limited warranty - 1 year
- 15 °C
- 30 °C
- 10 - 80% (non-condensing)
- Sound Emission (Idle)
- 14 dBA
- Sound Emission (Operating)
- 48 dBA
- 41.2 cm
- 46.9 cm
- 29.5 cm
- 18.9 kg
- Width (Shipping)
- 49.7 cm
- Depth (Shipping)
- 37.9 cm
- Height (Shipping)
- 58.3 cm
- Weight (Shipping)
- 22.1 kg
HP 415A Black Original LaserJet Toner Cartridge | In Stock | £70.74 |
HP 415A Cyan Original LaserJet Toner Cartridge | In Stock | £90.97 |
HP 415A Yellow Original LaserJet Toner Cartridge | In Stock | £91.54 |
HP 415A Magenta Original LaserJet Toner Cartridge | In Stock | £90.97 |
HP 415X High Yield Cyan Original LaserJet Toner Cartridge | In Stock | £196.22 |
HP 415X High Yield Yellow Original LaserJet Toner Cartridge | In Stock | £197.49 |
HP 415X High Yield Magenta Original LaserJet Toner Cartridge | In Stock | £197.49 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £15.18 |
