HP Colour Laserjet Pro M454DW Printer
Quicklinx: FFM6WS00 Mfr#: W1Y45A#B19
  • Windows 8.1 (32/64 bits)
Winning in business means working smarter. The HP Color LaserJet Pro M454 printer is designed to let you focus your time where it's most effective-helping to grow your business and staying ahead of the competition.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
HP Color LaserJet Pro M454dw - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
Number of Users
3-10 users
18.9 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 27 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 27 ppm - color (ISO) - A4 (210 x 297 mm) , Up to 28 ppm - B/W (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm) , Up to 28 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 49 ppm - black landscape - A5 (148 x 210 mm) , Up to 49 ppm - colour landscape - A5 (148 x 210 mm) , Up to 7 ppm - black portrait - A5 (148 x 210 mm) , Up to 7 ppm - colour portrait - A5 (148 x 210 mm) , Up to 24 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 24 ipm - colour duplex - A4 (210 x 297 mm) , Up to 25 ipm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 25 ipm - colour duplex - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
38400 x 600 dpi
Max Resolution (Colour)
38400 x 600 dpi
Image Enhancement Technology
HP ImageREt 3600
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Preview Screen Size
2.7"
1.2 GHz
RAM Installed (Max)
512 MB (512 MB)
Flash Memory Installed (Max)
512 MB (512 MB)
Language Simulation
PCL 5C, PostScript 3, PCL 6, PDF, URF, PWG
Media Type
Envelopes, labels, plain paper, photo paper, bond paper, recycled paper, punched paper, preprinted paper, postcards, glossy paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 4000 pages
Print server
Printer Features
HP ePrint, PANTONE calibrated, Instant-on Technology
UNIX, Android, Microsoft Windows Vista (32/64 bits), Ubuntu 10.04, Microsoft Windows XP (32/64 bits) SP3, Apple MacOS X Lion 10.7, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Apple OS X 10.8 Mountain Lion, openSUSE 12.2, Red Hat Fedora 17, Ubuntu 12.10, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Red Hat Fedora 18, openSUSE 12.3, Linux Mint 13, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, openSUSE 13.1, Windows 10 (32/64 bits), Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x, Microsoft Windows 7 / 8 (32/64 bits)
Environmental Standards
EPEAT Silver
1-year warranty
41.2 cm x 46.9 cm x 29.5 cm
Printer Type
Number of Users
3-10 users
Printer
Print Speed
Built-in Devices
Touch screen
Preview Screen Size
2.7"
Wireless
AirPrint Enabled
38400 x 600 dpi
38400 x 600 dpi
HP ImageREt 3600
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
9.7 sec
First Print Out Time Colour
11.3 sec
Language Simulation
Fonts Included
84 x TrueType
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
512 MB / 512 MB (max)
Flash Memory
Flash Memory
512 MB (installed) / 512 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 100 x 148 mm, JIS B5 (182 x 257 mm), 197 x 273 mm, 76 x 127 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm
Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
Media Weight
60 g/m² - 200 g/m²
Media Weight (lbs)
16 lbs - 52 lbs
300 sheets
Media Feeders
Input tray: 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² - (16 lbs (min) - 52 lbs (max)) , Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² - (16 lbs (min) - 52 lbs (max)) , Output tray: 1 x automatic - 150 sheets
Max Media Capacity
850 sheets
Output Trays Capacity
150 sheets
Duty Cycle
50000 pages
750 - 4000 pages
Print server
Remote Management Protocol
SNMP 1, SNMP 2, SNMP 3, HTTP, HTTPS, SLP, IPv4, IPv6
Security Protocols & Features
SSL, Apple Bonjour, WEP, TLS, WPA, WPA2, 802.1x, TKIP, AES, WPS, Wi-Fi Direct, WPA-Enterprise
1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
FCC Class B certified, UL, CISPR 22 Class B, cUL, GS, EMC, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, CECP, EN 61000-3-3:2008, IECEE CB, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, ICES-003 issue 5 Class B, EN 62479:2010, LVD 2006/95/EC, 21 CFR 1040.10, 21 CFR 1040.11, CoC, EN 55024:2010, IEC 60950-1:2005 + A1:2009, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN 55022:2010 Class B
Power supply - internal
Frequency Required
50/60 Hz
550 watt
Power Consumption Stand by
17 watt
Power Consumption Sleep
0.9 watt
Software Included
Drivers & Utilities, HP Update, HP Software Installer, HP Software Uninstaller, HP Device Experience (DXP), HP Connected, HP Product Improvement Study, Product Registration Assist, HP Device Toolbox
EPEAT Compliant
EPEAT Silver
Blue Angel
ENERGY STAR
Limited warranty - 1 year
15 °C
30 °C
10 - 80% (non-condensing)
Sound Emission (Idle)
14 dBA
Sound Emission (Operating)
48 dBA
41.2 cm
46.9 cm
29.5 cm
18.9 kg
Width (Shipping)
49.7 cm
Depth (Shipping)
37.9 cm
Height (Shipping)
58.3 cm
Weight (Shipping)
22.1 kg
FFM6 HP 415A Black Original LaserJet Toner Cartridge In Stock £71.39
FFM6 HP 415A Cyan Original LaserJet Toner Cartridge In Stock £91.76
FFM6 HP 415A Yellow Original LaserJet Toner Cartridge In Stock £91.76
FFM6 HP 415A Magenta Original LaserJet Toner Cartridge In Stock £91.76
FFM6 HP 415X High Yield Black Original LaserJet Toner Cartridge In Stock £144.89
FFM6 HP 415X High Yield Cyan Original LaserJet Toner Cartridge In Stock £197.96
FFM6 HP 415X High Yield Yellow Original LaserJet Toner Cartridge In Stock £197.96
FFM6 HP 415X High Yield Magenta Original LaserJet Toner Cartridge In Stock £197.96
FFM6 HP Glossy Laser Paper 150GSM 150 SHT/A4 In Stock £16.54
