You'd never expect this much performance from such a small package. With three distinct functions – print, copy and scan, the HP Color LaserJet Pro MFP M274n gives you the tools you need to get the job done.
Accomplish more with your time
Create the professional-quality colour documents your business depends on – right in the office.Choose the MFP that's the smallest in its class, and prints from sleep mode faster than comparable devices.Access time-saving apps from the 7.6 cm touchscreen, and scan directly to email and the cloud.Easily print Microsoft Word and PowerPoint documents – now directly from your USB drive. -
Stay connected
Quickly connect your Colour MFP to your computer with the Hi-Speed USB 2.0 port.Share your MFP and utilise resources with built-in Fast Ethernet 10/100 Base-TX networking. -
More
Get more pages – using Original HP High-Yield Colour Toner cartridges with JetIntelligence.Count on professional quality at high speeds – HP ColorSphere 3 toner works best with your HP printer.Get the authentic HP quality you paid for with anti-fraud technology.Print right away with preinstalled toner cartridges. Replace them with optional high-yield cartridges. -
Meet everyday IT challenges head-on
Safeguard data and easily manage devices with a suite of essential security and management features.Easily set up, print, and share with built-in Ethernet networking.Increase security, restore control, and help avoid additional expenses – with HP JetAdvantage Private Print.
- HP Color LaserJet Pro MFP M274n - multifunction printer - colour
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 2500 pages
- Max Copying Speed
- Up to 18 ppm (mono) / up to 18 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Scanning
- 1200 x 1200 dpi
- Display
- 3"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, greeting cards, photo paper
- Standard Media Capacity
- 150 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to folder, Instant-on Technology, HP Auto-On/Auto-Off Technology
- Power
- AC 230 V (50Hz)
- 42 cm x 38.4 cm x 32.2 cm
- 17.5 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Laser - colour
- 30000 pages
- 250 - 2500 pages
- Display Diagonal Size
- 3"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF, PCLm, URF
- Image Enhancement Technology
- HP ImageREt 3600
- First Print Out Time B/W
- 11.5 sec
- First Print Out Time Colour
- 13 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 30-bit
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 52 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 101 x 152 mm, B6 (125 x 176 mm), 76.2 x 127 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 150 sheets
- 1 sheet
- 100 sheets
- Bypass tray - 1 sheet , Input tray - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 52 g/m² - 220 g/m² , ADF - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 90 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 18 ppm (A4) - B/W , Printing: up to 18 ppm (A4) - colour , Printing: up to 11 ipm (A4) - B/W duplex , Copying: up to 18 ppm (A4) - B/W , Copying: up to 18 ppm (A4) - colour , Scanning: up to 21 ppm - B/W , Scanning: up to 14 ppm - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host , 1 x LAN - RJ-45
- Apple Bonjour
- Operating System Support
- UNIX, Linux, MS Windows Vista, Ubuntu Linux 10.04, Apple Mac OS X 10.7, Ubuntu Linux 11.10, Ubuntu Linux 12.04, Apple Mac OS X 10.8, Fedora 17, Android, iOS, Fedora 18, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, Apple Mac OS X 10.9, Fedora 19, MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Linux Mint 15, Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Ubuntu Linux 13.10, Windows 10 (32/64-bits), Boss 3.0, Boss 5.0, Ubuntu Linux 14.10, Debian Linux 7.x, Fedora 20, Linux Mint 16, Linux Mint 17, Ubuntu Linux 14.04, Debian Linux 6.0.x
- Software Included
- Drivers & Utilities
- Voltage Required
- AC 230 V (50Hz)
- 365 Watt
- Power Consumption Standby
- 10.5 Watt
- Power Consumption Sleep
- 2.7 Watt
- Consumables Included
- 1 x toner cartridge (black) - up to 1500 pages - HP 201A , 1 x toner cartridge (cyan) - up to 700 pages , 1 x toner cartridge (magenta) - up to 700 pages , 1 x toner cartridge (yellow) - up to 700 pages
- CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 55024:2010, CISPR 22:2008, EN 55022:2010 Class B
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 42 cm
- 38.4 cm
- 32.2 cm
- 17.5 kg
- Shipping Width
- 49.8 cm
- Shipping Depth
- 39.8 cm
- Shipping Height
- 49 cm
- Shipping Weight
- 20.2 kg
- Sound Emission
- 50 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80%
HP 201A Black Original Toner Cartridge | In Stock | £60.22 |
HP 201A Cyan Original Toner Cartridge | In Stock | £71.04 |
HP 201A Magenta Original Toner Cartridge | In Stock | £71.04 |
