HP LaserJet 700 M775zm Laser Multifunction Printer - Colour - Plain Paper Print - 30 ppm Mono/30 ppm Color Print - Ethernet - USB
PC Connection: Gigabit LAN, USB 2.0 host, USB 2.0 Printing Output Type: Colour Type of Machine: Fax / copier / printer / scanner - all-in-one Ink type: Laser Printing speed (monochrome): 30 ppm (mono) Printing speed (colour): 30 ppm (color)
- HP LaserJet Managed MFP M775zm - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 180000 pages
- Recommended Monthly Volume
- 2500 - 30000 pages
- Max Copying Speed
- Up to 30 ppm (mono) / up to 30 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 dpi
- Display
- 8"
- Original Size
- A3 (297 x 420 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76 x 127 mm (min) - 320 x 470 mm (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, greeting cards, film, heavy-weight paper, thin paper, thick paper, card stock, glossy paper, matte paper, preprinted paper, semi-gloss paper
- Standard Media Capacity
- 1850 sheets
- Max Media Capacity
- 1850 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Stacker
- Included
- Stapler
- Included
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Hardware Integration Pocket, HP High-Performance Secure Hard Disk
- Power
- AC 230 V (50/60Hz)
- 107.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Laser - colour
- 180000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 1.5 GB
- Max Supported Memory
- 1.5 GB
- Hard Disk Drive
- 320 GB
Copying
- Max Copying Speed
- Maximum Copies
- 9999
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PDF 1.4, PCL 5
- First Print Out Time B/W
- 10.5 sec
- First Print Out Time Colour
- 10.5 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
Document & Media Handling
- Max Original Size
- A3 (297 x 420 mm)
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 297 x 432 mm, 148 x 182 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA3 (320 x 450 mm), SRA4 (225 x 320 mm), 76 x 127 mm, 320 x 470 mm, JIS B6 (128 x 182 mm), A5 Maxi, RA4 (215 x 305 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 1850 sheets
- 1850 sheets
- 100 sheets
- 500 sheets
- RADF - 100 sheets - A3 (297 x 420 mm) , Bypass tray - 100 sheets size: 76 x 127 mm - 320 x 470 mm weight: 60 g/m² - 220 g/m² , Input tray - 250 sheets size: 148 x 182 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 220 g/m² , 3 x input tray - 500 sheets size: A5 (148 x 210 mm) - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 220 g/m² , Stacker / stapler - 500 sheets
- Speed Details
- Printing: up to 30 ppm (A4) - B/W , Printing: up to 30 ppm (A4) - colour , Printing: up to 30 ipm (A4) - B/W duplex , Printing: up to 15 ppm (A3) - B/W , Printing: up to 15 ppm (A3) - colour , Copying: up to 30 ppm (A4) - B/W , Copying: up to 30 ppm (A4) - colour , Scanning: up to 30 ppm - B/W , Scanning: up to 30 ppm - colour , Scanning: up to 14 ppm - B/W duplex , Scanning: up to 14 ppm - colour duplex
Finishing Equipment
- Stacker
- Included
- Stapler
- Included
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x modem - RJ-11
- SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP, WPA2-Enterprise
- Operating System Support
- MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Windows 8, MS Windows Server 2008 (32/64-bits)
- Software Included
- Drivers & Utilities
- Voltage Required
- 703 Watt
- Power Consumption Standby
- 85 Watt
- Power Consumption Sleep
- 14.8 Watt
- Included Accessories
- Phone cable, stand
- Consumables Included
- 1 (black) - up to 13500 pages , 1 (cyan) - up to 16000 pages , 1 (magenta) - up to 16000 pages , 1 (yellow) - up to 16000 pages
- FCC CFR47, GB 9254-2008, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN55024:1998 + A1 + A2, EMC 2004/108/EC, EN55022:2010 Class A, GB 17625.1-2003, CISPR 22:2008
- ENERGY STAR Certified
- Limited warranty - 1 year
- 107.7 kg
- Shipping Weight
- 126.7 kg
- Sound Emission
- 53 dBA (operating)
- 15 °C
- 27 °C
- 30 - 70%
HP Colour LaserJet CE980A Toner Collection Unit | In Stock | £40.27 |
HP LaserJet CE515A 220V Maintenance Kit | In Stock | £302.62 |
HP LaserJet CE516A Transfer Kit | In Stock | £275.84 |
