HP Colour LaserJet Managed Flow MFP M880zm+ Printer
Quicklinx: C78GWS00 Mfr#: L3U52A#B19
PC Connection Gigabit LAN, USB 2.0 host, USB 2.0, USB 2.0 host (internal)
Printing Output Type Colour
Type of Machine Fax / copier / printer / scanner
  • Intuitive 8-inch (20.3 cm) HP Easy Select pivoting color touchscreen control panel
  • 200-sheet automatic document feeder with single pass two-sided scanning, and HP EveryPage with ultrasonic double-feed detection
  • Home button (returns to home screen)
  • Plate glass color scanner handles sizes up to 11 x 17 in/A3
  • Easy-access USB port to save and print files directly
  • Hardware integration pocket for solution integration
  • 500-sheet output bin
  • Front door provides convenient access to HP toner cartridges and drums
  • Built-in automatic two-sided printing
  • Retractable keyboard for easy, accurate data entry
  • 100-sheet multipurpose tray handles heavy custom media up to 58 lb bond
  • Right-side doors provide access to the fuser and for clearing jams
  • 500-sheet input tray supports media up to size 11 x 17 in/A3
  • 3,500-sheet high-capacity input tray supports media sizes letter/A4
  • HP Jetdirect Gigabit Ethernet print server
  • HP high-performance secure hard disk
  • Access port for optional Kensington-style lock
  • Hi-Speed USB 2.0 port (for connecting third-party devices)
  • Hi-Speed USB 2.0 printing port
  • 800 MHz processor, 2.5 GB (system memory)
  • Foreign interface harness (for connecting external devices)
  • Two internal host USB 2.0 type ports for third party solutions
  • RJ-11 fax port
HP Color LaserJet Managed Flow MFP M880zm+ - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
300000 pages
Recommended Monthly Volume
5000 - 50000 pages
Max Copying Speed
Up to 46 ppm (mono) / up to 46 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi, 100 x 100 dpi
Scanning
600 dpi
Display
8"
Original Size
147 x 68 mm (min) - A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
200 sheets
Media Size
76.2 x 127 mm (min) - 320 x 457.2 mm (max)
Media Type
Transparencies, envelopes, plain paper, labels, photo paper, film, glossy paper
Standard Media Capacity
4100 sheets
Max Media Capacity
4100 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Stacker
Optional
Stapler
Optional
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host, USB 2.0 host (internal)
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to network, Hardware Integration Pocket, Foreign Interface Harness (FIH), HP High-Performance Secure Hard Disk, pull-out keyboard
AC 230 V (50Hz)
70.4 cm x 63.5 cm x 119.9 cm
152.9 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
300000 pages
5000 - 50000 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
2.5 GB
Max Supported Memory
2.5 GB
Hard Disk Drive
320 GB
Copying
Max Copying Speed
Maximum Copies
9999
Automatic Duplexing
Printing
Max Printing Speed
Automatic Duplexing
First Print Out Time B/W
11 sec
First Print Out Time Colour
11 sec
Scanning
Scan Element
CCD
Automatic Duplexing
Optical Resolution
600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Fax Printing Resolution
300 x 300 dpi
Fax Machine Features
One-Touch Dialing
100 station(s)
Fax forwarding
Document & Media Handling
Min Original Size
147 x 68 mm
Max Original Size
Original Type
Sheets
200 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A3/Ledger
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 297 x 432 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA3 (320 x 450 mm), SRA4 (225 x 320 mm), 76.2 x 127 mm, RA3 (305 x 430 mm), JIS B6 (128 x 182 mm), 320 x 457.2 mm, RA4 (215 x 305 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
4100 sheets
Max Media Capacity
4100 sheets
100 sheets
500 sheets
ADF - 200 sheets size: 147 x 68 mm - A3/Ledger (297 x 432 mm) , Bypass tray - 100 sheets size: 76.2 x 127 mm - 320 x 457.2 mm weight: 60 g/m² - 220 g/m² , Input tray - 500 sheets size: A5 (148 x 210 mm) - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 220 g/m² , Input tray - 1500 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Input tray - 2000 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Output tray - 500 sheets
Speed Details
Printing: up to 46 ppm (A4) - B/W , Printing: up to 46 ppm (A4) - colour , Printing: up to 43 ipm (A4) - B/W duplex , Printing: up to 43 ipm (A4) - colour duplex , Printing: up to 22 ppm (A3) - B/W , Printing: up to 22 ppm (A3) - colour , Copying: up to 46 ppm (A4) - B/W , Copying: up to 46 ppm (A4) - colour , Scanning: up to 70 ppm - B/W , Scanning: up to 68 ppm - colour , Scanning: up to 85 ipm - B/W duplex , Scanning: up to 63 ipm - colour duplex
Finishing Equipment
Stacker
Optional
Stapler
Optional
1 x Gigabit LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host (internal) , 1 x modem - RJ-11
Security Protocols & Features
Kerberos, LDAP, SSL, TLS, 802.1x, EAP-TLS, PEAP
Operating System Support
MS Windows XP SP2 or later, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6.8, Apple Mac OS X 10.7.5, MS Windows Server 2008 (32/64-bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Windows 8 (32/64-bits)
AC 230 V (50Hz)
1100 Watt
Power Consumption Standby
80 Watt
Power Consumption Sleep
8 Watt
Phone cable, stand
Consumables Included
1 x drum (black) - up to 30000 pages , 1 x drum (cyan) - up to 30000 pages , 1 x drum (magenta) - up to 30000 pages , 1 x drum (yellow) - up to 30000 pages , 1 x Cartridge (black) - up to 29500 pages , 1 x Cartridge (cyan) - up to 32000 pages , 1 x Cartridge (magenta) - up to 32000 pages , 1 x Cartridge (yellow) - up to 32000 pages
EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN55024:2010, EMC 2004/108/EC, EN55022:2010 Class A, CISPR 22:2008
ENERGY STAR Certified
Limited warranty - 1 year - on-site - response time: next business day
70.4 cm
63.5 cm
119.9 cm
152.9 kg
Shipping Width
85.6 cm
Shipping Depth
79 cm
Shipping Height
156.7 cm
Shipping Weight
175.33 kg
Sound Emission
55 dBA (operating)
15 °C
30 °C
10 - 80%
