PC Connection Gigabit LAN, USB 2.0 host, USB 2.0, USB 2.0 host (internal)
Printing Output Type Colour
Type of Machine Fax / copier / printer / scanner
- Intuitive 8-inch (20.3 cm) HP Easy Select pivoting color touchscreen control panel
- 200-sheet automatic document feeder with single pass two-sided scanning, and HP EveryPage with ultrasonic double-feed detection
- Home button (returns to home screen)
- Plate glass color scanner handles sizes up to 11 x 17 in/A3
- Easy-access USB port to save and print files directly
- Hardware integration pocket for solution integration
- 500-sheet output bin
- Front door provides convenient access to HP toner cartridges and drums
- Built-in automatic two-sided printing
- Retractable keyboard for easy, accurate data entry
- 100-sheet multipurpose tray handles heavy custom media up to 58 lb bond
- Right-side doors provide access to the fuser and for clearing jams
- 500-sheet input tray supports media up to size 11 x 17 in/A3
- 3,500-sheet high-capacity input tray supports media sizes letter/A4
- HP Jetdirect Gigabit Ethernet print server
- HP high-performance secure hard disk
- Access port for optional Kensington-style lock
- Hi-Speed USB 2.0 port (for connecting third-party devices)
- Hi-Speed USB 2.0 printing port
- 800 MHz processor, 2.5 GB (system memory)
- Foreign interface harness (for connecting external devices)
- Two internal host USB 2.0 type ports for third party solutions
- RJ-11 fax port
- HP Color LaserJet Managed Flow MFP M880zm+ - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 300000 pages
- Recommended Monthly Volume
- 5000 - 50000 pages
- Max Copying Speed
- Up to 46 ppm (mono) / up to 46 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 200 x 200 dpi, 100 x 100 dpi
- Scanning
- 600 dpi
- Display
- 8"
- Original Size
- 147 x 68 mm (min) - A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 200 sheets
- Media Size
- 76.2 x 127 mm (min) - 320 x 457.2 mm (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, photo paper, film, glossy paper
- Standard Media Capacity
- 4100 sheets
- Max Media Capacity
- 4100 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Stacker
- Optional
- Stapler
- Optional
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host, USB 2.0 host (internal)
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to network, Hardware Integration Pocket, Foreign Interface Harness (FIH), HP High-Performance Secure Hard Disk, pull-out keyboard
- Power
- AC 230 V (50Hz)
- 70.4 cm x 63.5 cm x 119.9 cm
- 152.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Laser - colour
- 300000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 2.5 GB
- Max Supported Memory
- 2.5 GB
- Hard Disk Drive
- 320 GB
Copying
- Max Copying Speed
- Maximum Copies
- 9999
Printing
- First Print Out Time B/W
- 11 sec
- First Print Out Time Colour
- 11 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Fax Printing Resolution
- 300 x 300 dpi
Fax Machine Features
- One-Touch Dialing
- 100 station(s)
- Fax forwarding
Document & Media Handling
- Min Original Size
- 147 x 68 mm
- Max Original Size
- Original Type
- Sheets
- 200 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 297 x 432 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA3 (320 x 450 mm), SRA4 (225 x 320 mm), 76.2 x 127 mm, RA3 (305 x 430 mm), JIS B6 (128 x 182 mm), 320 x 457.2 mm, RA4 (215 x 305 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 4100 sheets
- 4100 sheets
- 100 sheets
- 500 sheets
- ADF - 200 sheets size: 147 x 68 mm - A3/Ledger (297 x 432 mm) , Bypass tray - 100 sheets size: 76.2 x 127 mm - 320 x 457.2 mm weight: 60 g/m² - 220 g/m² , Input tray - 500 sheets size: A5 (148 x 210 mm) - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 220 g/m² , Input tray - 1500 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Input tray - 2000 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Output tray - 500 sheets
- Speed Details
- Printing: up to 46 ppm (A4) - B/W , Printing: up to 46 ppm (A4) - colour , Printing: up to 43 ipm (A4) - B/W duplex , Printing: up to 43 ipm (A4) - colour duplex , Printing: up to 22 ppm (A3) - B/W , Printing: up to 22 ppm (A3) - colour , Copying: up to 46 ppm (A4) - B/W , Copying: up to 46 ppm (A4) - colour , Scanning: up to 70 ppm - B/W , Scanning: up to 68 ppm - colour , Scanning: up to 85 ipm - B/W duplex , Scanning: up to 63 ipm - colour duplex
Finishing Equipment
- Stacker
- Optional
- Stapler
- Optional
- 1 x Gigabit LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host (internal) , 1 x modem - RJ-11
- Kerberos, LDAP, SSL, TLS, 802.1x, EAP-TLS, PEAP
- Operating System Support
- MS Windows XP SP2 or later, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6.8, Apple Mac OS X 10.7.5, MS Windows Server 2008 (32/64-bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Windows 8 (32/64-bits)
- Voltage Required
- AC 230 V (50Hz)
- 1100 Watt
- Power Consumption Standby
- 80 Watt
- Power Consumption Sleep
- 8 Watt
- Included Accessories
- Phone cable, stand
- Consumables Included
- 1 x drum (black) - up to 30000 pages , 1 x drum (cyan) - up to 30000 pages , 1 x drum (magenta) - up to 30000 pages , 1 x drum (yellow) - up to 30000 pages , 1 x Cartridge (black) - up to 29500 pages , 1 x Cartridge (cyan) - up to 32000 pages , 1 x Cartridge (magenta) - up to 32000 pages , 1 x Cartridge (yellow) - up to 32000 pages
- EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN55024:2010, EMC 2004/108/EC, EN55022:2010 Class A, CISPR 22:2008
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site - response time: next business day
- 70.4 cm
- 63.5 cm
- 119.9 cm
- 152.9 kg
- Shipping Width
- 85.6 cm
- Shipping Depth
- 79 cm
- Shipping Height
- 156.7 cm
- Shipping Weight
- 175.33 kg
- Sound Emission
- 55 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80%
