Your basket is empty
HP Colour LaserJet Managed Flow MFP M577cm
Quicklinx: C789WS00 Mfr#: B5L50A#B19
Functionality: Copier, Fax, Printer, Scanner
Output Type: Colour
Technology: Laser
Hurry, only 1 left in stock!
£1,499.07 ex VAT
£1,798.88 inc VAT
Conserve energy without sacrificing productivity. Built-in, multi-level device security helps guard your printing fleet. This color MFP produces more vibrant, professional-quality pages. It is ideal for enterprises and medium businesses that need a secure, highly productive, energy-efficient color MFP.
HP Color LaserJet Managed Flow MFP M577cm - multifunction printer (colour)
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
120000 pages
Recommended Monthly Volume
2000 - 15000 pages
Max Copying Speed
Up to 38 ppm (mono) / up to 38 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 dpi
Display
8"
Original Size
76 x 127 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, glossy paper, punched paper, preprinted paper
Standard Media Capacity
650 sheets
Max Media Capacity
2300 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Stapler
Included
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, HP ePrint, Hardware Integration Pocket, Hard Disk Drive Encryption, save to network folder, Foreign Interface Harness (FIH), HP EveryPage, HP High-Performance Secure Hard Disk, pull-out keyboard, Mopria certified, automatic cutter, scan to SharePoint, scan to OCR, Google Cloud Print 2.0, security lock slot
AC 230 V (50Hz)
48.2 cm x 50.4 cm x 58.3 cm
38.6 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1 year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
120000 pages
2000 - 15000 pages
Display Diagonal Size
8"
Display Features
Touch screen, pivoting
PC Connection
AirPrint Enabled
Standard Memory
1.75 GB
Hard Disk Drive
320 GB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
ID Card Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF 1.7, PCL
Image Enhancement Technology
HP ImageREt 3600
Automatic Duplexing
First Print Out Time B/W
9.1 sec
First Print Out Time Colour
9.1 sec
Colour Management Features
PANTONE Digital Color
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Document & Media Handling
Min Original Size
76 x 127 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, JIS B5 (182 x 257 mm), 76 x 127 mm, JIS B6 (128 x 182 mm), 102 x 148 mm, RA4 (215 x 305 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
650 sheets
Max Media Capacity
2300 sheets
100 sheets
250 sheets
ADF - 100 sheets size: 105 x 127 mm - Legal (216 x 356 mm) weight: 45 g/m² - 199 g/m² , Input tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 75 g/m² - 216 g/m² , Input tray - 550 sheets size: 102 x 148 mm - 216 x 297 mm weight: 75 g/m² - 163 g/m² , Output tray - 250 sheets
Speed Details
Scanning: up to 45 ppm - B/W , Scanning: up to 45 ppm - colour , Printing: up to 38 ppm (A4) - B/W , Printing: up to 38 ppm (A4) - colour , Printing: up to 38 ipm (A4) - B/W duplex , Copying: up to 38 ppm (A4) - B/W , Copying: up to 38 ppm (A4) - colour
Finishing Equipment
Stapler
Included
2 x USB 2.0 host (internal) - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x modem - RJ-11
Security Protocols & Features
Kerberos, LDAP, SSL, NDS Authentication over IP, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
Operating System Support
UNIX, Linux, Novell NetWare 6.5, Ubuntu Linux 10.04, Ubuntu Linux 11.10, Ubuntu Linux 12.04, Apple Mac OS X 10.8, Novell Open Enterprise Server, Fedora 17, Fedora 18, Ubuntu Linux 12.10, Apple Mac OS X 10.9, Fedora 19, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Ubuntu Linux 13.10, Linux Mint 13 - 17, Windows 10 (32/64-bits), SuSe Linux 12.2, SuSe Linux 12.3, SuSe Linux 13.1, Boss 3.0, Boss 5.0, Ubuntu Linux 14.10, Debian Linux 7.x, Fedora 20, Ubuntu Linux 14.04, Debian Linux 6.0.x
Software Included
Drivers & Utilities, HP Web Jetadmin, HP Update, HP Device Experience (DXP), HP Send Fax, HP Web Services Assist
AC 230 V (50Hz)
592 Watt
Power Consumption Standby
47.3 Watt
Power Consumption Sleep
3.48 Watt
Phone cable
Consumables Included
1 x Cartridge (black) - up to 6000 pages - HP 508A , 1 x Cartridge (yellow) - up to 5000 pages - HP 508A , 1 x Cartridge (magenta) - up to 5000 pages - HP 508A , 1 x Cartridge (cyan) - up to 5000 pages - HP 508A
CISPR 22 Class A, EMC, FIPS 140-2, IPv6 Ready, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 55024:2010, EN 55022:2010 Class A, CISPR 22:2008
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year - on-site - response time: next business day
48.2 cm
50.4 cm
58.3 cm
38.6 kg
Shipping Width
77.5 cm
Shipping Depth
60 cm
Shipping Height
65 cm
Shipping Weight
45 kg
Sound Emission
51 dBA (operating)
15 °C
30 °C
30 - 70%
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Technology: Laser
Brand: HP
Price Range Ex VAT: 1000 - 1500
