Increase versatility with a colour MFP
Get fast print speeds and rapid first page out time (FPOT).Breeze through print, scan, copy, and fax tasks, using the automatic document feeder (fax and ADF available on M181fw only).Help save energy with HP Auto-On/Auto-Off Technology.Get quick and easy printing directly at the control panel. -
More
Count on high-quality colour with Original HP Toner cartridges with JetIntelligence.Get the Original HP quality you paid for with anti-fraud technology.Speed through print jobs right out of the box, using preinstalled Original HP Toner cartridges. -
Easy mobile printing and scanning – HP Smart app
Print and scan from your smartphone, and easily order toner, with the HP Smart app.Have confidence in your connection with steady performance from dual band Wi-Fi .Connect your smartphone or tablet directly to your printer – and easily print without accessing a network.Simply tap the print button on your smartphone or tablet to print.
- HP Color LaserJet Pro MFP M181fw - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 150 - 1500 pages
- Max Copying Speed
- Up to 16 ppm (mono) / up to 16 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, heavy-weight paper, light-weight paper, glossy paper
- Standard Media Capacity
- 150 sheets
- Max Media Capacity
- 150 sheets
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to application
- Power
- AC 230 V (50/60Hz)
- 42 cm x 38 cm x 34.12 cm
- 16.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty (Austria, Germany - 3 years with product registration)
- Fax Type
- Plain paper
- Laser - colour
- 30000 pages
- 150 - 1500 pages
- Display
- 2 lines
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF, PCLm, URF
- Image Enhancement Technology
- HP ImageREt 3600
- First Print Out Time B/W
- 11.8 sec
- First Print Out Time Colour
- 13.5 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 1300 pages
- PC Faxing
Fax Machine Features
- Speed Dialing
- 120 station(s)
- Broadcast Transmission
- 119 stations
- Delayed Transmission
- Remote Fax Retrieval (Polling)
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax polling
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 76 x 127 mm, 127 x 203.2 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 150 sheets
- 150 sheets
- 100 sheets
- ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 16 ppm (Letter A) - B/W (ISO) , Printing: up to 16 ppm (Letter A) - colour (ISO) , Printing: up to 16 ppm (A4) - B/W (ISO) , Printing: up to 16 ppm (A4) - colour (ISO) , Copying: up to 16 ppm (Letter A) - B/W normal , Copying: up to 16 ppm (Letter A) - colour normal , Copying: up to 16 ppm (A4) - B/W normal , Copying: up to 16 ppm (A4) - colour normal , Scanning: up to 14 ppm (A4)
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- WEP, WPA, WPA2, TKIP, AES, WPS, Wi-Fi Direct
- Operating System Support
- Linux, MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), MS Windows Server 2008, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 SP1 or later, MS Windows XP 64-bit Edition SP2 or later, MS Windows Server 2012, Windows 8, Windows 8 64-bit, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2003 x64 Edition SP1 or later, MS Windows Server 2008 Enterprise, MS Windows Server 2008 Standard
- Software Included
- Drivers & Utilities
- Voltage Required
- 337 Watt
- Power Consumption Standby
- 8 Watt
- Power Consumption Sleep
- 1 Watt
- First Copy Out Time B/W
- 12.3 sec
- First Copy Out Time Colour
- 18.1 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1100 pages , 1 x toner cartridge (cyan) - up to 900 pages , 1 x toner cartridge (magenta) - up to 900 pages , 1 x toner cartridge (yellow) - up to 900 pages
- FCC Class B certified, UL, cUL, GS, ICES-003, CISPR 22, EN55022 Class B, RSS-210, FCC Part 68, EMC, CS-03, R&TTE, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60825-1, GB 17625.1, LVD, Directive 2004/108/EC, GB 9254-2008, EN 62311, Directive 2006/95/EC, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 300 328 V1.7.1, NOM-151-SCTI-1999, IEC 60825-1:2007, EN 55024:2010, EN 301 489-1, EN 301 489-17, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
- ENERGY STAR Certified
- Limited warranty - 1 year
- Regional Warranty Exceptions
- Austria, Germany - 3 years with product registration
- 42 cm
- 38 cm
- 34.12 cm
- 16.3 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 39.8 cm
- Shipping Height
- 46.6 cm
- Shipping Weight
- 19.5 kg
- Sound Emission
- 50 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80%
Ink (2)
HP 205A Original Black Laserjet Tone | In Stock | £41.44 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £14.44 |
Other bundles (4)
HP Care Pack Standard Exchange Extended Service Agreement 3 Years Shipment | In Stock | £43.74 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment | In Stock | £54.67 |
HP Care Pack Standard Exchange Extended Service Agreement 2 Years Shipment | In Stock | £21.87 |
HP 2y Nbd Exch Cons Laserjet MFP-E SVC -HP Consumer Laserjet MF | In Stock | £27.33 |
