Tackle high-volume jobs with this high-performance colour MFP. Print and copy, plus scan and fax. Enhanced scanning features and a 20cm (8-inch) colour touchscreen smooth workflows. Mobile printing options help you stay productive on the go.
20.3 cm colour touchscreen (printer)
Manage jobs directly at the MFP, using the HP colour touchscreen.
- HP Color LaserJet Enterprise MFP M680dn - multifunction printer - colour
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 120000 pages
- Recommended Monthly Volume
- 3000 - 17000 pages
- Max Copying Speed
- Up to 42 ppm (mono) / up to 42 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 43 ppm (mono) / up to 42 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Scanning
- 600 dpi
- Display
- 8"
- Original Size
- 68 x 148 mm (min) - Legal (216 x 356 mm) (max)
- Document Feeder Capacity
- 100 sheets
- Media Size
- 101.6 x 152.4 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Standard Media Capacity
- 600 sheets
- Max Media Capacity
- 3100 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Power
- AC 230 V (50Hz)
- 84 cm x 63.2 cm x 58.5 cm
- 56.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Laser - colour
- 120000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Max Supported Memory
- 2 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
Printing
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PDF
- Image Enhancement Technology
- HP ImageREt 4800, HP ProRes 1200
- First Print Out Time B/W
- 18.5 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
Document & Media Handling
- Min Original Size
- 68 x 148 mm
- Max Original Size
- 100 sheets
- Min Media Size
- 101.6 x 152.4 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), JIS B6 (128 x 182 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm), 101.6 x 152.4 mm
- 600 sheets
- 3100 sheets
- 100 sheets
- 500 sheets
- ADF - 100 sheets size: 68 x 148 mm - Legal (216 x 356 mm) , Input tray - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Bypass tray - 100 sheets , Output tray - 500 sheets
- Speed Details
- Printing: up to 43 ppm (A4) - B/W normal , Printing: up to 42 ppm (A4) - colour normal , Printing: up to 45 ppm (Letter A) - B/W normal , Copying: up to 42 ppm (A4) - colour normal , Copying: up to 38 ipm (A4) - colour duplex , Copying: up to 40 ipm (Letter A) - B/W duplex , Copying: up to 40 ppm (Letter A) - colour duplex , Copying: up to 45 ppm (Letter A) - B/W normal , Scanning: up to 60 ppm (Letter A) - B/W normal , Scanning: up to 45 ppm (Letter A) - colour normal
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A
- IPsec
- Operating System Support
- MS Windows 7, MS Windows XP SP3, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, MS Windows Server 2008 R2, IBM AIX 3.2.5 or later, Apple Mac OS X 10.7, HP-UX 10.20, Apple Mac OS X 10.8, MS Windows Server 2012, Windows 8, Apple Mac OS X 10.9
- Software Included
- Drivers & Utilities
- Voltage Required
- AC 230 V (50Hz)
- 797 Watt
- Power Consumption Standby
- 83 Watt
- Power Consumption Sleep
- 7 Watt
- First Copy Out Time B/W
- 10.5 sec
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site
- 84 cm
- 63.2 cm
- 58.5 cm
- 56.5 kg
- Shipping Width
- 76.4 cm
- Shipping Depth
- 76.9 cm
- Shipping Height
- 73.3 cm
- Shipping Weight
- 61.6 kg
- Sound Emission
- 36 dBA (idle) / 56 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80%
HP 652A Black Original LaserJet Toner Cartridge | In Stock | £182.07 |
HP 653A Cyan Original Toner Cartridge | In Stock | £295.78 |
HP 653A Yellow Original Toner Cartridge | In Stock | £295.78 |
HP 653A Magenta Original Toner Cartridge | In Stock | £295.78 |
