Your basket is empty
HP Colour LaserJet Enterprise M651xh Printer
Trade in your old printer!
Limited Time Offer
Quicklinx: 9HDPWS00 Mfr#: CZ257A#B19
  • Windows 8 (32/64 bits)
Performance you can count on: high-volume, professional-quality, two-sided colour documents with outstanding reliability. Efficient one-touch printing and mobile printing options plus simple management help you be productive wherever work takes you.
HP Color LaserJet Enterprise M651xh - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
69.6 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 42 ppm - black normal - A4 (210 x 297 mm) , Up to 42 ppm - colour normal - A4 (210 x 297 mm) , Up to 45 ppm - black normal - ANSI A (Letter) (216 x 279 mm) , Up to 45 ppm - colour normal - ANSI A (Letter) (216 x 279 mm) , Up to 38 ppm - duplex - A4 (210 x 297 mm) , Up to 40 ppm - duplex - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
1200 x 1200 dpi
Image Enhancement Technology
HP ImageREt 4800 / HP ProRes 1200
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
800 MHz
RAM Installed (Max)
1.5 GB (1.5 GB)
Language Simulation
PCL 5, PostScript 3, PCL 6, PDF, URF
Media Type
Envelopes, transparencies, labels, plain paper, heavy-weight paper, heavy-weight glossy paper, bond paper, recycled paper, opaque film, card stock, extra heavy-weight paper, light-weight paper
Total Media Capacity
3100 sheets
Media Handling
2x 500-sheet input trays, 100-sheet multipurpose tray, 1500-sheet high-capacity feeder
Monthly Duty Cycle (max)
120000 pages
Recommended Monthly Volume
2500 - 17000 pages
Print server
Printer Features
Hard Disk Drive Encryption, on paper calibration technology
AC 230V
HP-UX 10.20, SunSoft Solaris 2.5 or later, IBM AIX 3.2.5 or later, Microsoft Windows 2000, HP-UX 11.x, HP MPE/iX, HP-UX 11i, Novell NetWare 5.1 or later, Microsoft Windows Server 2003 x64 Edition SP2 or later, Apple MacOS X 10.6, Microsoft Windows XP SP3 or later, Microsoft Windows Server 2003 SP2 or later, Citrix MetaFrame, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows XP Professional x64 Edition SP3 or later, Apple MacOS X 10.7 Lion, Microsoft Windows 7 (32/64 bits) SP1 or later, Red Hat Linux 7.x or later, SuSE Linux 8.x or later, Windows 8 (32/64 bits), Apple MacOS X 10.8, Microsoft Windows Server 2008 R2 (64-bits), Microsoft Windows Server 2012 x64 Edition, Apple MacOS X 10.9
66 cm x 66.5 cm x 100 cm
Printer Type
Printer
Print Speed
Built-in Devices
HP Secure High Performance hard disk, 4.3 inch LCD touch screen
Wired
1200 x 1200 dpi
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
9 sec
First Print Out Time Colour
9 sec
Language Simulation
Fonts Included
105 x TrueType , 92 x scalable PostScript
Printer Features
Media Handling
800 MHz
RAM
RAM Installed (Max)
1.5 GB / 1.5 GB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm)
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
Media Weight
60 g/m² - 220 g/m²
3100 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 3 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 1500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Max Media Capacity
3100 sheets
Output Trays Capacity
500 sheets
Duty Cycle
120000 pages
2500 - 17000 pages
Print server
Network Controller Name
HP Jetdirect
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, NDPS, NDS, HTTPS, TFTP, IPPS
Security Protocols & Features
Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
FCC Class A certified, UL, CISPR 22 Class A, cUL, GS, ICES-003, EN55022 Class A, EMC, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60825-1, LVD, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 62479, IEC 60825-1:2007, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN 62479:2010, EN55024:2010
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
650 Watt
Power Consumption Stand by
67 Watt
Power Consumption Sleep
8.5 Watt
Software Included
Drivers & Utilities, HP Web JetAdmin
Environmental Standards
Blue Angel
ENERGY STAR
10 °C
30 °C
10 - 80%
Sound Emission (Idle)
34 dBA
Sound Emission (Operating)
55 dBA
66 cm
66.5 cm
100 cm
69.6 kg
Width (Shipping)
76 cm
Depth (Shipping)
86 cm
Height (Shipping)
137.3 cm
Weight (Shipping)
86 kg
9HDP HP 652A Black Original LaserJet Toner Cartridge In Stock £152.28
9HDP HP 654A Cyan Original LaserJet Toner Cartridge In Stock £283.37
9HDP HP 654A Magenta Original LaserJet Toner Cartridge In Stock £279.08
9HDP HP 654X High Yield Black Original LaserJet Toner Cartridge In Stock £198.37
