HP Colour LaserJet Enterprise Flow M880z+ Multifunction Printer
Quicklinx: 9HFBWS00 Mfr#: A2W76A#B19
Functionality: Printer, Copier, Fax, Scanner
Output Type: Colour
Wireless Capability: Wireless, Wired
Technology: Laser
£5,777.78 ex VAT
£6,933.33 inc VAT
This top-of-the-line enterprise MFP helps streamline workflows and accelerate document tasks with advanced finishing options and file sharing. Give users simple, direct access to this MFP through mobile printing and touch-to-print capabilities.
  • 20.3 cm colour touchscreen (printer)
    Manage jobs directly at the MFP, using the HP colour touchscreen.
HP LaserJet Enterprise Flow MFP M880z+ - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
200000 impressions
Recommended Monthly Volume
5000 - 25000 pages
Max Printing Speed
Up to 46 ppm (mono) / up to 46 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 100 dpi
Scanning
600 x 600 dpi
Display
8"
Original Size
A3 (297 x 420 mm), Ledger (279 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
76 x 127 mm (min) - 320 x 470 mm (max)
Media Type
Transparencies, plain paper, labels, recycled paper, bond paper, card stock
Standard Media Capacity
4100 sheets
Max Media Capacity
4100 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Stacker
Optional
Stapler
Optional
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host, USB host (internal)
AirPrint Enabled
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to network, save to network folder, HP EveryPage, HP High-Performance Secure Hard Disk, pull-out keyboard, scan to Cloud, HP EasyColor, Instant-on Technology
AC 230 V (60Hz)
70.4 cm x 63.5 cm x 119.9 cm
152.9 kg
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified, Blue Angel
Fax Type
Plain paper
Printing Technology
Laser - colour
200000 impressions
5000 - 25000 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1.5 GB
Max Supported Memory
1.5 GB
Hard Disk Drive
320 GB
Supported Flash Memory
USB flash drive
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Automatic Duplexing
Copying Features
Auto colour select, Edge Erase
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF 1.4
Image Enhancement Technology
HP FastRes 1200, HP ImageREt 4800, HP ProRes 1200
Automatic Duplexing
First Print Out Time B/W
11 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Fax Machine Features
Speed Dialing
100 station(s)
Broadcast Transmission
100 stations
Remote Fax Retrieval (Polling)
Fax forwarding, automatic redialing, auto reduction, fax polling
Document & Media Handling
Max Original Size
Original Type
Sheets
100 sheets
Min Media Size
76 x 127 mm
Max Media Size
A3
Min Media Weight
45 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), ARCH B (304.8 x 457.2 mm), JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA3 (320 x 450 mm), SRA4 (225 x 320 mm), Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 197 x 273 mm, 76.2 x 127 mm, RA3 (305 x 430 mm), 127 x 177.8 mm, 279.4 x 431.8 mm, 216 x 355.6 mm, 216 x 340 mm, Oficio (216 x 343 mm), 320 x 470 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm), 270 x 390 mm, 260 x 368 mm, 273 x 394 mm, 195 x 270 mm, 184 x 260 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm), Japanese postcard (100 x 148 mm), Japanese Postcard Double (148 x 200 mm)
4100 sheets
Max Media Capacity
4100 sheets
100 sheets
500 sheets
ADF - 200 sheets size: B6 (125 x 176 mm) - A3/Ledger (297 x 432 mm) weight: 45 g/m² - 199 g/m² , Input tray - 100 sheets size: 76 x 127 mm - 320 x 457 mm weight: 60 g/m² - 220 g/m² , Input tray - 500 sheets size: 148 x 210 mm - 297 x 431.8 mm weight: 60 g/m² - 199 g/m² , Input tray - 3500 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 199 g/m² , Output tray - 500 sheets
Speed Details
Printing: up to 46 ppm (A4) - B/W normal , Printing: up to 46 ppm (A4) - colour , Printing: up to 22 ppm (A3) - B/W , Printing: up to 22 ppm (A3) - colour , Scanning: up to 70 ppm (A4) - B/W , Scanning: up to 85 ipm (A4) - B/W duplex , Scanning: up to 68 ppm (A4) - colour , Scanning: up to 63 ipm (A4) - colour duplex
Finishing Equipment
Stacker
Optional
Stapler
Optional
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 2 x USB host (internal) , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
Kerberos, LDAP, Secure Print, SSL, Apple Bonjour, TLS, IPsec, 802.1x
Operating System Support
MS Windows 7, MS Windows XP SP3, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, Windows 8, MS Windows Server 2003 SP2, MS Windows Server 2012 x64 Edition
Software Included
Drivers & Utilities
AC 230 V (60Hz)
1100 Watt
Power Consumption Standby
80 Watt
Power Consumption Sleep
8 Watt
Phone cable
Consumables Included
1 x toner cartridge (black) - up to 29500 pages , 1 x toner cartridge (cyan) - up to 32000 pages , 1 x toner cartridge (magenta) - up to 32000 pages , 1 x toner cartridge (yellow) - up to 32000 pages
UL, CISPR 22 Class A, cUL, EN 61000-3-2, GS, ICES-003, EN 61000-3-3, EN55024, FCC Part 68 / CS03 Issue 8, EMC, R&TTE, FCC CFR47 Part 15, IEC 60950-1, IEC 60825-1, GB 17625.1-2003 EMC, IEC 62479
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Blue Angel Compliant
70.4 cm
63.5 cm
119.9 cm
152.9 kg
Shipping Width
156.7 cm
Shipping Depth
85.6 cm
Shipping Height
79 cm
Shipping Weight
175.3 kg
Sound Emission
54 dBA (operating)
15 °C
30 °C
10 - 80%
9HFB HP LaserJet D7H14A Transfer and Roller Kit In Stock £561.25
9HFB HP LaserJet ADF Roller Replacement Kit In Stock £69.51
9HFB HP LaserJet C1N58A 220V Maintenance Kit In Stock £381.42
9HFB HP 827A Yellow Original LaserJet Toner Cartridge In Stock £450.18
9HFB HP 827A Cyan Original LaserJet Toner Cartridge In Stock £450.18
9HFB HP 827A Black Original LaserJet Toner Cartridge In Stock £101.02
9HFB HP 827A Magenta Original LaserJet Toner Cartridge In Stock £450.18
9HFB HP 828A Yellow LaserJet Image Drum In Stock £243.02
9HFB HP 828A Black LaserJet Image Drum In Stock £87.84
9HFB HP 828A Cyan LaserJet Image Drum In Stock £243.02
9HFB HP 828A Magenta LaserJet Image Drum In Stock £243.02
9HFB HP Glossy Laser Paper 150GSM 150 SHT/A4 In Stock £16.86
Functionality: Copier
Functionality: Fax
Functionality: Scanner
Output Type: Colour
Wireless Capability: Wired
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: 320 x 470 mm
Brand: HP
Price Range Ex VAT: £1500+
