This top-of-the-line enterprise MFP helps streamline workflows and accelerate document tasks with advanced finishing options and file sharing. Give users simple, direct access to this MFP through mobile printing and touch-to-print capabilities.
20.3 cm colour touchscreen (printer)
Manage jobs directly at the MFP, using the HP colour touchscreen.
- HP LaserJet Enterprise Flow MFP M880z+ - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 200000 impressions
- Recommended Monthly Volume
- 5000 - 25000 pages
- Max Printing Speed
- Up to 46 ppm (mono) / up to 46 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 200 x 100 dpi
- Scanning
- 600 x 600 dpi
- Display
- 8"
- Original Size
- A3 (297 x 420 mm), Ledger (279 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76 x 127 mm (min) - 320 x 470 mm (max)
- Media Type
- Transparencies, plain paper, labels, recycled paper, bond paper, card stock
- Standard Media Capacity
- 4100 sheets
- Max Media Capacity
- 4100 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Stacker
- Optional
- Stapler
- Optional
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host, USB host (internal)
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network, save to network folder, HP EveryPage, HP High-Performance Secure Hard Disk, pull-out keyboard, scan to Cloud, HP EasyColor, Instant-on Technology
- Power
- AC 230 V (60Hz)
- 70.4 cm x 63.5 cm x 119.9 cm
- 152.9 kg
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified, Blue Angel
- Fax Type
- Plain paper
- Laser - colour
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 1.5 GB
- Max Supported Memory
- 1.5 GB
- Hard Disk Drive
- 320 GB
- Supported Flash Memory
- USB flash drive
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Copying Features
- Auto colour select, Edge Erase
Printing
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF 1.4
- Image Enhancement Technology
- HP FastRes 1200, HP ImageREt 4800, HP ProRes 1200
- First Print Out Time B/W
- 11 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Broadcast Transmission
- 100 stations
- Remote Fax Retrieval (Polling)
- Fax forwarding, automatic redialing, auto reduction, fax polling
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A3
- Min Media Weight
- 45 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), ARCH B (304.8 x 457.2 mm), JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA3 (320 x 450 mm), SRA4 (225 x 320 mm), Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 197 x 273 mm, 76.2 x 127 mm, RA3 (305 x 430 mm), 127 x 177.8 mm, 279.4 x 431.8 mm, 216 x 355.6 mm, 216 x 340 mm, Oficio (216 x 343 mm), 320 x 470 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm), 270 x 390 mm, 260 x 368 mm, 273 x 394 mm, 195 x 270 mm, 184 x 260 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm), Japanese postcard (100 x 148 mm), Japanese Postcard Double (148 x 200 mm)
- 4100 sheets
- 4100 sheets
- 100 sheets
- 500 sheets
- ADF - 200 sheets size: B6 (125 x 176 mm) - A3/Ledger (297 x 432 mm) weight: 45 g/m² - 199 g/m² , Input tray - 100 sheets size: 76 x 127 mm - 320 x 457 mm weight: 60 g/m² - 220 g/m² , Input tray - 500 sheets size: 148 x 210 mm - 297 x 431.8 mm weight: 60 g/m² - 199 g/m² , Input tray - 3500 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 199 g/m² , Output tray - 500 sheets
- Speed Details
- Printing: up to 46 ppm (A4) - B/W normal , Printing: up to 46 ppm (A4) - colour , Printing: up to 22 ppm (A3) - B/W , Printing: up to 22 ppm (A3) - colour , Scanning: up to 70 ppm (A4) - B/W , Scanning: up to 85 ipm (A4) - B/W duplex , Scanning: up to 68 ppm (A4) - colour , Scanning: up to 63 ipm (A4) - colour duplex
Finishing Equipment
- Stacker
- Optional
- Stapler
- Optional
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 2 x USB host (internal) , 1 x Gigabit LAN - RJ-45
- Kerberos, LDAP, Secure Print, SSL, Apple Bonjour, TLS, IPsec, 802.1x
- Operating System Support
- MS Windows 7, MS Windows XP SP3, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, Windows 8, MS Windows Server 2003 SP2, MS Windows Server 2012 x64 Edition
- Software Included
- Drivers & Utilities
- Voltage Required
- AC 230 V (60Hz)
- 1100 Watt
- Power Consumption Standby
- 80 Watt
- Power Consumption Sleep
- 8 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 29500 pages , 1 x toner cartridge (cyan) - up to 32000 pages , 1 x toner cartridge (magenta) - up to 32000 pages , 1 x toner cartridge (yellow) - up to 32000 pages
- UL, CISPR 22 Class A, cUL, EN 61000-3-2, GS, ICES-003, EN 61000-3-3, EN55024, FCC Part 68 / CS03 Issue 8, EMC, R&TTE, FCC CFR47 Part 15, IEC 60950-1, IEC 60825-1, GB 17625.1-2003 EMC, IEC 62479
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Blue Angel Compliant
- 70.4 cm
- 63.5 cm
- 119.9 cm
- 152.9 kg
- Shipping Width
- 156.7 cm
- Shipping Depth
- 85.6 cm
- Shipping Height
- 79 cm
- Shipping Weight
- 175.3 kg
- Sound Emission
- 54 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80%
HP LaserJet D7H14A Transfer and Roller Kit | In Stock | £559.30 |
HP LaserJet ADF Roller Replacement Kit | In Stock | £69.27 |
HP LaserJet C1N58A 220V Maintenance Kit | In Stock | £380.10 |
HP 827A Black Original LaserJet Toner Cartridge | In Stock | £101.62 |
HP 827A Magenta Original LaserJet Toner Cartridge | In Stock | £448.62 |
