See productivity soar with this high performing Color LaserJet MFP. Create A3 colour documents with excellent line and image quality. Enjoy fast print speeds; print, copy, scan, fax and digital sending functionality plus exceptional ease of use.
- HP Color LaserJet CM6040f MFP - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 220000 impressions
- Max Copying Speed
- Up to 40 ppm (mono) / up to 40 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi
- Scanning
- 600 dpi
- Original Size
- A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels
- Standard Media Capacity
- 2100 sheets
- Max Media Capacity
- 2100 sheets
- Output Trays Capacity
- 500 sheets
- Stacker
- Optional
- Stapler
- Optional
- Automatic Duplexing
- Yes (copying)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Security lock slot
- Power
- AC 230 V (50Hz)
- 70.4 cm x 63.5 cm x 119.4 cm
- 144.9 kg
- Microsoft Certification
- Works with Windows Vista
- Environmental Standards
- EPEAT Bronze, ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - colour
- Interface
- Standard Memory
- 512 MB 512 MB
- Max Supported Memory
- 1 GB 1 GB
- Hard Disk Drive
- 80 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 200%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c
Scanning
- Optical Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi
Fax Machine Features
- Broadcast Transmission
- 100 stations
- Automatic redialing
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A3/Ledger
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- 2100 sheets
- 2100 sheets
- 500 sheets
- ADF - 50 sheets , 4 x input tray - 250 sheets , Input tray - 500 sheets , Input tray - 100 sheets
Finishing Equipment
- Stacker
- Optional
- Stapler
- Optional
- 1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
- Operating System Support
- MS Windows XP, MS Windows 2000, MS Windows Server 2003, Apple Mac OS X 10.3, Apple Mac OS X 10.2.8, Apple MacOS X 10.4 or later, MS Windows Vista
- Voltage Required
- AC 230 V (50Hz)
- 920 Watt
- Power Consumption Standby
- 230 Watt
- Power Consumption Sleep
- 24.5 Watt
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- Security Slot Type
- Kensington security slot
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR Certified
- 70.4 cm
- 63.5 cm
- 119.4 cm
- 144.9 kg
- 15 °C
- 27 °C
HP 825A Black Original LaserJet Toner Cartridge | In Stock | £55.92 |
HP 824A Black LaserJet Image Drum | In Stock | £69.07 |
HP 824A Yellow Original LaserJet Toner Cartridge | In Stock | £218.47 |
HP Colour LaserJet CB458A 220V Fuser Kit | In Stock | £291.62 |
HP 824A Magenta LaserJet Image Drum | In Stock | £194.21 |
