Get productive print performance – world's smallest colour laser in it's class. Print, and scan, produce high-quality colour results, and print and scan from your phone.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
Uncompromising laser quality
This surprisingly small laser delivers exceptional quality, page after page. -
Sharp black text, high-quality colour
Produce sharp text, bold blacks, and crisp color graphics. -
The right price
Rely on a high-performance laser printer at an affordable price. -
The power of your printer in the palm of your hand
Get simple setup, and print and scan from your phone, with the HP Smart app. -
Your device, your choice
Easily print from a variety of smartphones and tablets. -
Extend your printing reach
Easily share resources – access and print with wireless and Ethernet networking.
- HP Color Laser 150nw - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- Number of Users
- 1-5 users
- 10.04 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 19 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 18 ppm - B/W - A4 (210 x 297 mm) , Up to 4 ppm - color (ISO) - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 600 x 600 dpi
- Max Resolution (Colour)
- 600 x 600 dpi
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Processor
- 400 MHz
- RAM Installed (Max)
- 64 MB (64 MB)
- Language Simulation
- SPL (Samsung Printer Language)
- Media Type
- Envelopes, transparencies, labels, plain paper, cards, recycled paper, glossy paper
- Total Media Capacity
- 150 sheets
- Monthly Duty Cycle (max)
- 20000 pages
- Recommended Monthly Volume
- 100 - 500 pages
- Networking
- Print server
- Printer Features
- Wireless Direct Print, Rendering Engine for Clean Page (ReCP) Technology, Mopria certified, Auto Power Off
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Apple MacOS X 10.3, Apple MacOS X 10.2.8, Apple MacOS X 10.4, Apple MacOS X 10.4 or later, Microsoft Windows Vista
- 1-year warranty
- 38.2 cm x 30.9 cm x 21.15 cm
- Printer Type
- Number of Users
- 1-5 users
- Localisation
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 600 x 600 dpi
- 600 x 600 dpi
- PostScript Support
- Standard
- Printer Features
- Processor
- 400 MHz
RAM
- 64 MB / 64 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 150 sheets
- Output Trays Capacity
- 50 sheets
Duty Cycle
- 20000 pages
- 100 - 500 pages
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
- Mercury free
- Plug and Play, UL, cUL, GS, ANSI C63.4-2009, CECP, GB 9254-2008, EN 62479:2010, CNS 13438, LVD 2006/95/EC, GB 17625.1-2012, EN 61000-3-3:2013, CoC, EN 55024:2010, CISPR 22:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, ICES-003 issue 5, KN32, KN35, EN 55032:2012+AC:2013 Class A, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2014-10, IEC/EN 60825-1:2014 Class 1, CISPR 32:2012, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 282 Watt
- Power Consumption Stand by
- 27 Watt
- Power Consumption Sleep
- 1 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- Blue Angel
- Limited warranty - 1 year
- 10 °C
- 30 °C
- 10 - 80% (non-condensing)
- 38.2 cm
- 30.9 cm
- 21.15 cm
- 10.04 kg
- Width (Shipping)
- 47.1 cm
- Depth (Shipping)
- 41.3 cm
- Height (Shipping)
- 30.5 cm
- Weight (Shipping)
- 12.52 kg
HP 117A Black Original Laser Toner Cartridge | In Stock | £35.00 |
HP 117A Cyan Original Toner Cartridge | In Stock | £38.71 |
HP 117A Yellow Original Toner Cartridge | In Stock | £40.02 |
HP 117A Magenta Original Toner Cartridge | In Stock | £38.71 |
HP 120A Original Laser Imaging Drum | In Stock | £84.37 |
