Cover all your colour business printing needs from postcards to oversize documents, with this versatile and affordable A3 desktop printer. Get superior print quality with HP ColorSphere toner, fast speeds and ease of use, with unrivalled reliability.
Handle all your business printing with this affordable, versatile A3 colour printer
This versatile A3 colour printer enables you to print everyday business documents, wide-format projects and marketing materials affordably, in house. Easily print on different types of paper: plain, premium and glossy, with expandable paper trays.Easily print on different types of paper-plain, premium, and glossy-with adjustable paper trays. The printer supports sizes from 3 by 5 in up to 12 by 18 in and weights up to 220 g/m .Use the HP Print Cost Estimator-available in the included HP Print View Software-to compare the cost of printing internally versus at a copy shop. -
Achieve consistently high-quality output with HP ColorSphere toner on a range of business documents
Create high-quality output thanks to HP ColorSphere toner and HP ImageREt 3600. Achieve consistent results at speeds of up to 20 ppm black and colour A4. Get a first page out in less than 18 seconds from low-power mode with Instant-on Technology.HP ImageREt 3600 is image resolution technology that creates smooth colors, sharp images, and crisp text. Original HP cartridges with HP ColorSphere toner deliver consistent, print shop-quality results for professional office printing.Achieve consistent results at speeds of up to 20 ppm and a first page out in as fast as 14.5 seconds.With Instant-on Technology warm-up time from Low-power mode is up to 50% faster. In fact, your print job may be finished before many printers have started printing. -
Simple to use, share, and maintain with an intuitive control panel and easily replaced supplies
Easy to use and maintain with an intuitive control panel, and simple-to-replace supplies. Enjoy versatile High-speed USB 2.0 connectivity and easy workteam sharing.Access the technology, services, solutions, and support you need to manage and grow your business with HP Total Care.
- HP Color LaserJet Professional CP5225dn - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 40.9 kg
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- Print Speed
- Up to 20 ppm - B/W - A4 (210 x 297 mm) ¦ Up to 20 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 600 dpi
- Max Resolution (Colour)
- 600 dpi
- Image Enhancement Technology
- HP ImageREt 3600
- Automatic Duplexing
- Interface
- USB, LAN
- Processor
- 540 MHz
- RAM Installed (Max)
- 192 MB (448 MB)
- Language Simulation
- PCL 5, PostScript 3, PCL 6
- Media Type
- Envelopes, transparencies, labels, plain paper, cards, recycled paper, glossy paper
- Total Media Capacity
- 350 sheets
- Monthly Duty Cycle (max)
- 75000 pages
- Networking
- Print server - Ethernet, Fast Ethernet - integrated
- System Requirements
- Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Apple MacOS X 10.3 or later, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008
- Microsoft Certification
- Works with Windows Vista
- Environmental Standards
- EPEAT Silver
- 1-year warranty
- 54.5 cm x 59.9 cm x 33.8 cm
- Printer Type
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 600 dpi
- 600 dpi
- HP ImageREt 3600
- PostScript Support
- Standard
- Processor
- 540 MHz
RAM
- 192 MB / 448 MB (max)
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- Media Sizes
- Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), C5 (162 x 229 mm), JIS B5 (182 x 257 mm)
- Max Printing Width
- 297 mm
- Max Printing Length
- 432 mm
- Media Weight
- 60 g/m² - 220 g/m²
- 350 sheets
- Max Media Capacity
- 850 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 75000 pages
- Networking
- Print server - integrated
- Data Link Protocol
- Connections
- 1 x USB 2.0 - 4 pin USB Type B ¦ 1 x LAN - RJ-45
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- Power Device
- Power supply - internal
- 440 Watt
- Power Consumption Stand by / Sleep
- 30 Watt
- OS Required
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR
- Limited warranty - 1 year - on-site - response time: next business day
- 15 °C
- 27 °C
- 10 - 80%
- 54.5 cm
- 59.9 cm
- 33.8 cm
- 40.9 kg
- Width (Shipping)
- 71.8 cm
- Depth (Shipping)
- 70.2 cm
- Height (Shipping)
- 47.8 cm
- Weight (Shipping)
- 43 kg
Ink (3)
HP 307A Black Original LaserJet Toner Cartridge | In Stock | £145.82 |
HP 307A Cyan Original LaserJet Toner Cartridge | In Stock | £256.86 |
HP 307A Yellow Original LaserJet Toner Cartridge | In Stock | £256.86 |
Other bundles (1)
HP LASERJET 1X500 TRAY | In Stock | £235.86 |
