An efficient, wireless MFP for high-quality colour and business productivity. Save time with Smart Tasks in HP Smart app, and print and scan from your phone. Get seamless connections and strong security designed to help detect and stop attacks.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
Best-in-class mobile print app
Get easy printing and scanning from your mobile device, with HP Smart. -
Automate scanning tasks and save time
Eliminate steps in repetitive tasks with customisable shortcuts, using Smart Tasks in HP Smart app. -
Powerful printing. Energy smart
Count on high-quality colour and peak printing performance with Original HP Toner cartridges with JetIntelligence. -
Tackle the essentials – print, scan, copy, fax
Easily handle tasks and get a lot from one device – print, scan, copy, and fax. -
Achieve high speeds for all your prints
Print your business documents quickly with fast print speeds.
- HP Color LaserJet Pro MFP M282nw - multifunction printer - colour
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 40000 pages
- Recommended Monthly Volume
- 150 - 2500 pages
- Max Copying Speed
- Up to 21 ppm (mono) / up to 21 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 400 dpi (colour)
- Max Printing Speed
- Up to 21 ppm (mono) / up to 21 ppm (colour) up to 21 ipm
- Max Printing Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Scanning
- 1200 x 1200 dpi
- Display
- 2.7"
- Original Size
- 102 x 152 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, photo paper, bond paper, heavy-weight paper, card stock, light-weight paper, glossy paper, punched paper, preprinted paper, coloured paper, letterheaded paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, HP Auto Wireless Connect
- Power
- AC 230 V (50/60Hz)
- 42 cm x 38.86 cm x 33.41 cm
- 18 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Printer Fonts
- TrueType x 84
- Laser - colour
- 40000 pages
- 150 - 2500 pages
- Display Diagonal Size
- 2.7"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- Collation copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF, PCLm, PCLms, URF, PWG
- Image Enhancement Technology
- HP ImageREt 3600
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Min Original Size
- 102 x 152 mm
- Max Original Size
- Supported Original Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 102 x 152 mm
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Min Media Weight (lb)
- 16 lbs
- Max Media Weight (lb)
- 59 lbs
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 197 x 273 mm, 76 x 127 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- 250 sheets
- 1 sheet
- 100 sheets
- ADF - 50 sheets size: 102 x 152 mm - Legal (216 x 356 mm) weight: 60 g/m² - 90 g/m²; weight (lbs): 16 lbs - 24 lbs , Bypass tray - 1 sheet size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²; weight (lbs): 16 lbs - 59 lbs , Input tray - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²; weight (lbs): 16 lbs - 59 lbs , Output tray - 100 sheets
- Speed Details
- Scanning: up to 26 ppm (A4) - B/W normal , Scanning: up to 28 ppm (Letter A) - B/W normal , Scanning: up to 23 ppm (Letter A) - colour normal , Scanning: up to 22 ppm (A4) - colour normal , Printing: up to 21 ppm (A4) - B/W (ISO) , Printing: up to 22 ppm (Letter A) - B/W (ISO) , Printing: up to 38 ppm (A5) - B/W landscape , Printing: up to 5 ppm (A5) - B/W portrait , Printing: up to 21 ppm (A4) - colour (ISO) , Printing: up to 22 ppm (A5) - colour landscape , Printing: up to 5 ppm (A5) - colour portrait , Copying: up to 21 ppm (A4) - B/W (ISO) , Copying: up to 21 ppm (A4) - colour (ISO) , Copying: up to 22 ppm (Letter A) - B/W normal , Copying: up to 22 ppm (Letter A) - colour normal
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL, Apple Bonjour, TLS, WPA, WPA2, TKIP, AES, WPS, Wi-Fi Direct
- Operating System Support
- MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), MS Windows Vista 32-bit Edition, macOS 10.12, macOS 10.13, macOS 10.14, macOS 10.15
- Voltage Required
- 361 Watt
- Power Consumption Standby
- 7.8 Watt
- Power Consumption Sleep
- 0.8 Watt
- FCC Class B certified, UL, TUV, GS, CCC, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, KC, EAC, EN 62479:2010, RCM, BIS, EN 61000-3-3:2013, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, EN 55024:2010+A1:2015, EN 55032:2012, SIRIM, ICES-003 issue 6, CAN/CSA-C22.2 No. 60950-1-07 Second Edition, CISPR 32:2012, EN 60825-1:2014, Ukraine, IEC 60825-1:2014, CISPR 32:2015, EN 55032:2015+AC:2016 Class B, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- ENERGY STAR Certified
- Limited warranty - replacement - 1 year
- 42 cm
- 38.86 cm
- 33.41 cm
- 18 kg
- Shipping Width
- 49.8 cm
- Shipping Depth
- 39.8 cm
- Shipping Height
- 49 cm
- Shipping Weight
- 20.3 kg
- Sound Emission
- 16 dBA (idle) / 50 dBA (operating)
- 10 °C
- 32.5 °C
- 10 - 80%
Ink (6)
HP 207A Yellow Original LaserJet Toner Cartridge | In Stock | £60.86 |
HP 207A Magenta Original LaserJet Toner Cartridge | In Stock | £59.07 |
HP 207X High Yield Cyan Original LaserJet Toner Cartridge | In Stock | £82.84 |
HP 207X High Yield Yellow Original LaserJet Toner Cartridge | In Stock | £80.32 |
HP 207X High Yield Magenta Original LaserJet Toner Cartridge | In Stock | £80.32 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £14.44 |
Other bundles (4)
HP Care Pack Standard Exchange Extended Service Agreement 3 Years Shipment | In Stock | £43.74 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment | In Stock | £54.67 |
HP Care Pack Standard Exchange Extended Service Agreement 2 Years Shipment | In Stock | £21.87 |
HP 2y Nbd Exch Cons Laserjet MFP-E SVC -HP Consumer Laserjet MF | In Stock | £27.33 |
