HP Color LaserJet Pro MFP M282nw
Quicklinx: GZTVWS00 Mfr#: 7KW72A#B19
An efficient, wireless MFP for high-quality colour and business productivity. Save time with Smart Tasks in HP Smart app, and print and scan from your phone. Get seamless connections and strong security designed to help detect and stop attacks.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
  • Best-in-class mobile print app
    Get easy printing and scanning from your mobile device, with HP Smart.
  • Automate scanning tasks and save time
    Eliminate steps in repetitive tasks with customisable shortcuts, using Smart Tasks in HP Smart app.
  • Powerful printing. Energy smart
    Count on high-quality colour and peak printing performance with Original HP Toner cartridges with JetIntelligence.
  • Tackle the essentials – print, scan, copy, fax
    Easily handle tasks and get a lot from one device – print, scan, copy, and fax.
  • Achieve high speeds for all your prints
    Print your business documents quickly with fast print speeds.
HP Color LaserJet Pro MFP M282nw - multifunction printer - colour
Multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
40000 pages
Recommended Monthly Volume
150 - 2500 pages
Max Copying Speed
Up to 21 ppm (mono) / up to 21 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 400 dpi (colour)
Max Printing Speed
Up to 21 ppm (mono) / up to 21 ppm (colour) up to 21 ipm
Max Printing Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Scanning
1200 x 1200 dpi
Display
2.7"
Original Size
102 x 152 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, photo paper, bond paper, heavy-weight paper, card stock, light-weight paper, glossy paper, punched paper, preprinted paper, coloured paper, letterheaded paper
Standard Media Capacity
250 sheets
Max Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, HP Auto Wireless Connect
AC 230 V (50/60Hz)
42 cm x 38.86 cm x 33.41 cm
18 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Printer Fonts
TrueType x 84
Printing Technology
Laser - colour
40000 pages
150 - 2500 pages
Display Diagonal Size
2.7"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
Collation copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, PCLm, PCLms, URF, PWG
Image Enhancement Technology
HP ImageREt 3600
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Min Original Size
102 x 152 mm
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 102 x 152 mm
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
59 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 197 x 273 mm, 76 x 127 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
250 sheets
Max Media Capacity
250 sheets
1 sheet
100 sheets
ADF - 50 sheets size: 102 x 152 mm - Legal (216 x 356 mm) weight: 60 g/m² - 90 g/m²; weight (lbs): 16 lbs - 24 lbs , Bypass tray - 1 sheet size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²; weight (lbs): 16 lbs - 59 lbs , Input tray - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²; weight (lbs): 16 lbs - 59 lbs , Output tray - 100 sheets
Speed Details
Scanning: up to 26 ppm (A4) - B/W normal , Scanning: up to 28 ppm (Letter A) - B/W normal , Scanning: up to 23 ppm (Letter A) - colour normal , Scanning: up to 22 ppm (A4) - colour normal , Printing: up to 21 ppm (A4) - B/W (ISO) , Printing: up to 22 ppm (Letter A) - B/W (ISO) , Printing: up to 38 ppm (A5) - B/W landscape , Printing: up to 5 ppm (A5) - B/W portrait , Printing: up to 21 ppm (A4) - colour (ISO) , Printing: up to 22 ppm (A5) - colour landscape , Printing: up to 5 ppm (A5) - colour portrait , Copying: up to 21 ppm (A4) - B/W (ISO) , Copying: up to 21 ppm (A4) - colour (ISO) , Copying: up to 22 ppm (Letter A) - B/W normal , Copying: up to 22 ppm (Letter A) - colour normal
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, Apple Bonjour, TLS, WPA, WPA2, TKIP, AES, WPS, Wi-Fi Direct
Operating System Support
MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), MS Windows Vista 32-bit Edition, macOS 10.12, macOS 10.13, macOS 10.14, macOS 10.15
AC 230 V (50/60Hz)
361 Watt
Power Consumption Standby
7.8 Watt
Power Consumption Sleep
0.8 Watt
FCC Class B certified, UL, TUV, GS, CCC, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, KC, EAC, EN 62479:2010, RCM, BIS, EN 61000-3-3:2013, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, EN 55024:2010+A1:2015, EN 55032:2012, SIRIM, ICES-003 issue 6, CAN/CSA-C22.2 No. 60950-1-07 Second Edition, CISPR 32:2012, EN 60825-1:2014, Ukraine, IEC 60825-1:2014, CISPR 32:2015, EN 55032:2015+AC:2016 Class B, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
ENERGY STAR Certified
Limited warranty - replacement - 1 year
42 cm
38.86 cm
33.41 cm
18 kg
Shipping Width
49.8 cm
Shipping Depth
39.8 cm
Shipping Height
49 cm
Shipping Weight
20.3 kg
Sound Emission
16 dBA (idle) / 50 dBA (operating)
10 °C
32.5 °C
10 - 80%
Ink (9)
GZTV HP 207A Black Original LaserJet Toner Cartridge In Stock £51.44
GZTV HP 207A Cyan Original LaserJet Toner Cartridge In Stock £60.71
GZTV HP 207A Yellow Original LaserJet Toner Cartridge In Stock £60.71
GZTV HP 207A Magenta Original LaserJet Toner Cartridge In Stock £60.71
GZTV HP 207X High Yield Black Original LaserJet Toner Cartridge In Stock £78.29
GZTV HP 207X High Yield Cyan Original LaserJet Toner Cartridge In Stock £82.56
GZTV HP 207X High Yield Yellow Original LaserJet Toner Cartridge In Stock £82.56
GZTV HP 207X High Yield Magenta Original LaserJet Toner Cartridge In Stock £82.56
GZTV HP Glossy Laser Paper 150GSM 150 SHT/A4 In Stock £15.28
Other bundles (4)
GZTV HP Care Pack Standard Exchange Extended Service Agreement 3 Years Shipment In Stock £40.01
GZTV HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £48.01
GZTV HP Care Pack Standard Exchange Extended Service Agreement 2 Years Shipment In Stock £21.76
GZTV HP 2y Nbd Exch Cons Laserjet MFP-E SVC -HP Consumer Laserjet MF In Stock £27.19
