HP Color LaserJet Pro MFP 4302fdw
Quicklinx: HJGXWS00 Mfr#: 5HH64F#B19
Functionality: Fax, Copier, Printer, Scanner
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Laser
More than 50 In Stock
£480.07 ex VAT
£576.08 inc VAT
Get a blazing fast colour printer and easy management tools with LaserJet Pro.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
  • Blazing fast speed
    Step up your workflow with blazing fast speed to meet high-demand environments.
  • Self-healing Wi-Fi
    Avoid interruptions with Wi-Fi that intelligently looks for the best connection to stay on-line.
  • True-to-life colours
    Look professional on every page with high-quality printing, true-to-life colours and sharp details.
HP Color LaserJet Pro MFP 4302fdw - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, Spanish, French, Italian / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 4000 pages
Max Copying Speed
Up to 33 ppm (mono) / up to 33 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 203 x 196 dpi, 200 x 100 dpi
Scanning
600 x 600 dpi
Display
4.3"
Original Size
102 x 152 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, glossy paper
Standard Media Capacity
300 sheets
Max Media Capacity
850 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
Gigabit LAN, USB 2.0, USB 2.0 host, Wi-Fi(ac), Bluetooth LE, USB
AirPrint Enabled
Office Machine Features
HP Auto-On/Auto-Off Technology, Mopria certified, scan to e-mail, scan to PDF, Terrajet Cartridge, HP Instant Ink, scan to Cloud, scan to folder, walk-up USB printing, scan to USB drive, Private print, HP Auto Wireless Connect, Instant-on Technology
AC 230 V (50/60Hz)
42.1 cm x 43.5 cm x 38.4 cm
20.4 kg
Environmental Standards
Blue Angel
1-year warranty
Printer Fonts
TrueType x 111
Fax Type
Plain paper
Printing Technology
Laser - colour
50000 pages
750 - 4000 pages
Display Diagonal Size
4.3"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
512 MB
Supported Flash Memory
USB flash drive
Flash Memory
Flash Memory
512 MB (installed) / 512 MB (max)
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Copying Features
Collation copy, margin erase, resize, ID Copy, 2-up, tray selection
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5e, PDF, URF, PWG
Image Enhancement Technology
HP ImageREt 2400, Pantone Calibrated
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
30-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 500 pages
Fax Printing Speed
Up to 12 ppm
PC Faxing
Fax Machine Features
Speed Dialing
1000 station(s)
Telephone / Fax Switch
Delayed Transmission
Fax forwarding, automatic redialing, junk fax barrier, Distinctive Ring Detection (DRD)
Document & Media Handling
Min Original Size
102 x 152 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 100 x 148 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 76 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
300 sheets
Max Media Capacity
850 sheets
50 sheets
150 sheets
ADF - 50 sheets size: 102 x 152 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Input tray - 250 sheets size: 100 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 33 ppm (A4) - B/W (ISO) , Printing: up to 35 ppm (Letter A) - B/W (ISO) , Printing: up to 44 ppm (A5) - B/W portrait , Printing: up to 33 ppm - colour (ISO) , Printing: up to 44 ppm (A5) - colour portrait , Printing: up to 29 ipm (A4) - B/W duplex , Printing: up to 29 ipm (A4) - colour duplex , Printing: up to 31 ipm (Letter A) - B/W duplex , Printing: up to 31 ipm (Letter A) - colour duplex , Copying: up to 33 ppm (A4) - B/W normal , Copying: up to 33 ppm (A4) - colour normal , Copying: up to 35 ppm (Letter A) - B/W normal , Copying: up to 35 ppm (Letter A) - colour normal , Copying: up to 29 ppm (A4) - B/W duplex , Copying: up to 29 ppm (A4) - colour duplex , Copying: up to 31 ppm (Letter A) - B/W duplex , Copying: up to 31 ppm (Letter A) - colour duplex , Scanning: up to 29 ppm (A4) - B/W normal , Scanning: up to 26 ppm (A4) - colour normal , Scanning: up to 31 ppm (Letter A) - B/W normal , Scanning: up to 31 ppm (Letter A) - colour normal , Scanning: up to 44 ipm (A4) - B/W duplex normal , Scanning: up to 35 ipm (A4) - colour duplex normal , Scanning: up to 46 ipm (Letter A) - B/W duplex normal , Scanning: up to 37 ipm (Letter A) - colour duplex normal
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 host - 4 pin USB Type A , 1 x USB - 4 pin USB Type A , 1 x modem - RJ-11
Security Protocols & Features
SSL, Apple Bonjour, WEP, WPA, WPA2, 802.1x, TKIP, AES, Wi-Fi Direct, WPA3, WPS, WPA-Enterprise, IPv6 support, IPv4 support, SNMP 3
Operating System Support
Windows 11, Windows 10, MS Windows 7, Android, iOS, macOS 12 Monterey, macOS Big Sur, macOS 10.15, Linux, UNIX, Chrome OS
AC 230 V (50/60Hz)
585 Watt
Power Consumption Standby
18 Watt
Power Consumption Sleep
0.8 Watt
Warm-Up Time
55 sec
Consumables Included
1 x toner cartridge (black) - up to 2000 pages , 1 x toner cartridge (cyan) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages
UL, cUL, RCM, TUV, GS, BSMI, CCC, BIS, CE/EMC, IT ECO Declaration, CISPR 22:2008 (International) Class B, CISPR 32:2015 (International) Class B, EN 55032:2015 Class B + A11:2020, CISPR 35:2016 (International), EN 55035:2017+A11:2020, EN IEC 61000-3-2:2019, EN 61000-3-3:2013 + A1:2019 + A2:2021, FCC CFR47 Part 15 Class B, ICES-003 issue 7 Class B, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62368-1: 2014, EN 62368-1:2014, EN 60825-1:2014, IEC 60825-1:2014, Laser Class 1, EN 62479:2010, IEC 62479:2010, LVD 2014/35/EU, UL 62368-1-2014 Second Edition, CSA C22.2 No. 62368-1:2014 Second Edition, IEC 62471:2006, EN 62471:2008, 21 CFR 1040.10, 21 CFR 1040.11, DE-UZ 219, FCC CFR47 Part 15 C, FCC CFR47 Part 15 E, RSS-Gen Issue 4, RSS-247 Issue 2, RSS-102 Issue 5, EN 301 489-1 V2.2.3, EN 301 489-17 V3.2.4, EN 300 440-1 V2.1.1, EN 300 328 V2.2.2, EN 301 893 V2.1.1, FCC CFR47 Part 68, ES 203 021-1 V2.1.1, ES 203 021-2 V2.1.2, ES 203 021-3 V2.1.2
Blue Angel Compliant
Limited warranty - 1 year - on-site - response time: next business day
42.1 cm
43.5 cm
38.4 cm
20.4 kg
Shipping Width
59.7 cm
Shipping Depth
49.7 cm
Shipping Height
49.2 cm
Shipping Weight
23.6 kg
Sound Emission
50 dBA (operating)
10 °C
32.5 °C
10 - 80% RH (non-condensing)
HJGX HP 220A - yellow - original - LaserJet - toner cartridge In Stock £82.54
HJGX HP 220A - magenta - original - LaserJet - toner cartridge In Stock £82.54
HJGX HP 220A - cyan - original - LaserJet - toner cartridge In Stock £82.54
HJGX HP 220A - black - original - LaserJet - toner cartridge In Stock £68.42
HJGX HP 220X - High Yield - black - original - LaserJet - toner cartridge In Stock £135.57
HJGX HP 220X - High Yield - cyan - original - LaserJet - toner cartridge In Stock £166.54
HJGX HP 220X - High Yield - yellow - original - LaserJet - toner cartridge In Stock £166.54
Functionality: Fax
Functionality: Copier
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Wireless Capability: Wireless
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
