HP Color LaserJet Pro MFP 4302fdn
Quicklinx: HJGZWS00 Mfr#: 4RA84F#B19
Functionality: Printer, Copier, Fax, Scanner
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Laser
£345.36 ex VAT
£414.43 inc VAT
Get a blazing fast colour printer and easy management tools with LaserJet Pro.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
  • Blazing fast speed
    Step up your workflow with blazing fast speed to meet high-demand environments.
  • True-to-life colours
    Look professional on every page with high-quality printing, true-to-life colours and sharp details.
HP Color LaserJet Pro MFP 4302fdn - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, Spanish, French, Italian / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 4000 pages
Max Copying Speed
Up to 35 ppm (mono) / up to 35 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 35 ppm (mono) / up to 33 ppm (colour)
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 196 dpi, 300 x 300 dpi, 200 x 100 dpi
Scanning
600 x 600 dpi
Display
4.3"
Original Size
102 x 152 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, glossy paper
Standard Media Capacity
300 sheets
Max Media Capacity
850 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN
AirPrint Enabled
Office Machine Features
HP Auto-On/Auto-Off Technology, Instant-on Technology, save to USB flash drive, print from USB flash drive, scan to e-mail, scan to folder, Mopria certified, save to network folder
AC 120 V (50Hz)
42.1 cm x 43.5 cm x 38.4 cm
20.4 kg
1-year warranty
Printer Fonts
TrueType x 111
Fax Type
Plain paper
Printing Technology
Laser - colour
50000 pages
750 - 4000 pages
Display Diagonal Size
4.3"
Display Colour Support
Display Features
Touch screen, LED display
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
512 MB
Supported Flash Memory
USB flash drive
Flash Memory
Flash Memory
512 MB (installed) / 512 MB (max)
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Copying Features
Collation copy, margin erase, resize, ID Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5e, PDF, URF, PWG
Image Enhancement Technology
HP ImageREt 2400, Pantone Calibrated
Automatic Duplexing
First Print Out Time B/W
9.1 sec
First Print Out Time Colour
9.7 sec
Scanning
Scan Element
CIS
Optical Resolution
600 x 600 dpi
Colour Depth
30-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 500 pages
PC Faxing
Yes (send only)
Fax Machine Features
Speed Dialing
100 station(s)
Delayed Transmission
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax memory backup, delayed sending, fax polling, block fax, poll receive, fax activity reports, print fax log
Document & Media Handling
Min Original Size
102 x 152 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
52 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 100 x 148 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 76 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
300 sheets
Max Media Capacity
850 sheets
50 sheets
150 sheets
ADF - 50 sheets size: 102 x 152 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Input tray - 250 sheets size: 100 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 35 ppm (Letter A) - B/W (ISO) , Printing: up to 33 ppm (Letter A) - colour (ISO) , Printing: up to 29 ipm (A4) - duplex normal , Printing: up to 44 ppm (A5) - B/W portrait , Printing: up to 31 ipm (Letter A) - duplex normal , Printing: up to 44 ppm (A5) - colour portrait , Copying: up to 35 ppm (Letter A) - B/W normal , Copying: up to 35 ppm (Letter A) - colour normal , Copying: up to 33 ppm (A4) - B/W normal , Copying: up to 33 ppm (A4) - colour normal , Scanning: up to 29 ppm (A4) - B/W normal , Scanning: up to 26 ppm (A4) - colour normal , Scanning: up to 31 ipm (Letter A) - B/W normal , Scanning: up to 28 ppm (Letter A) - B/W normal
1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x USB - 4 pin USB Type A
Security Protocols & Features
SSL, Apple Bonjour, WEP, WPA, WPA2, 802.1x, TKIP, AES, Wi-Fi Direct, WPA3, WPS, WPA-Enterprise, IPv6 support, IPv4 support, SNMP 3
Operating System Support
Windows 11, Windows 10 (32/64-bits), MS Windows 7 (32/64 bits), Android, iOS, macOS 12 Monterey, macOS Big Sur, macOS 10.15, Linux, UNIX, Chrome OS, MS Windows Server 2008 R2, MS Windows Server 2012 x64 Edition, MS Windows Server 2012 R2 x64 Edition, MS Windows Server 2008 (32/64-bits), MS Windows Server 2016 x64 Edition, MS Windows Server 2019 x64 Edition, MS Windows Server 2022, MS Windows 7 Ultimate
Software Included
Drivers & Utilities, HP Web Jetadmin
AC 120 V (50Hz)
585 Watt
Power Consumption Standby
18 Watt
Power Consumption Sleep
0.8 Watt
First Copy Out Time B/W
7.5 sec
First Copy Out Time Colour
8.4 sec
Consumables Included
1 x toner cartridge (black) - up to 2000 pages , 1 x toner cartridge (cyan) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages
CSA, UL, TUV GS, BSMI, NOM, CCC, FCC, FCC CFR47 Part 68, KCC, FCC CFR47 Part 15 C, S Mark, KC, CECP, EN 62479:2010, BIS, ETSI ES203 021, EN 61000-3-3:2013, EN 62311:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, IEC 62311:2007, FCC CFR47 Part 15 B Class B, EN 55024:2010+A1:2015, RSS-102 Issue 5, RSS-247 Issue 1, FCC CFR47 Part 15 E, ICES-003 issue 6, IEC/EN 60825-1:2014 Class 1, Directive 2014/53/EU, CISPR 32:2012, EN 300 328 V2.1.1, EN 55032:2015 Class B, EN 301 489-1 V2.1.1, EN 55032:2012 Class B, IEC 60825-1:2014, EN 301 489-17 V3.1.1, CISPR 32:2015, Mercury-free, EN 301 893 V2.1.1, DE-UZ 205, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, IEEE 802.1x
Limited warranty - 1 year - on-site - response time: next business day
42.1 cm
43.5 cm
38.4 cm
20.4 kg
Shipping Width
59.7 cm
Shipping Depth
49.7 cm
Shipping Height
49.2 cm
Shipping Weight
23.6 kg
Sound Emission
50 dBA (operating)
10 °C
32.5 °C
10 - 80% RH (non-condensing)
HJGZ HP 220A - yellow - original - LaserJet - toner cartridge In Stock £82.54
HJGZ HP 220A - magenta - original - LaserJet - toner cartridge In Stock £82.54
HJGZ HP 220A - cyan - original - LaserJet - toner cartridge In Stock £82.54
HJGZ HP 220A - black - original - LaserJet - toner cartridge In Stock £68.88
HJGZ HP 220X - High Yield - black - original - LaserJet - toner cartridge In Stock £135.57
HJGZ HP 220X - High Yield - cyan - original - LaserJet - toner cartridge In Stock £166.54
HJGZ HP 220X - High Yield - yellow - original - LaserJet - toner cartridge In Stock £166.54
Functionality: Copier
Functionality: Fax
Functionality: Scanner
Output Type: Colour
Wireless Capability: Wireless
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
