Get a blazing fast colour printer and easy management tools with LaserJet Pro.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
Business team solution
Support your business workteam with this compact, high-performing, colour printer, ideal for up to 10 users. -
Blazing fast speed
Step up your workflow with blazing fast speed to meet high-demand environments. -
Self-healing Wi-Fi
Avoid interruptions with Wi-Fi that intelligently looks for the best connection to stay on-line. -
True-to-life colours
Look professional on every page with high-quality printing, true-to-life colours and sharp details.
- HP Color LaserJet Pro MFP 4302dw - multifunction printer - colour
- Multifunction printer
- Localisation
- English, German, Spanish, French, Italian / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 50000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Max Copying Speed
- Up to 33 ppm (mono) / up to 33 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Scanning
- 600 x 600 dpi
- Display
- 4.3"
- Original Size
- 102 x 152 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, glossy paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 850 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- Gigabit LAN, USB 2.0, USB 2.0 host, Wi-Fi(ac), Bluetooth LE
- AirPrint Enabled
- Office Machine Features
- HP Auto-On/Auto-Off Technology, Mopria certified, scan to e-mail, scan to PDF, Terrajet Cartridge, HP Instant Ink, scan to Cloud, scan to folder, walk-up USB printing, scan to USB drive, Private print, HP Auto Wireless Connect, Instant-on Technology
- Power
- AC 230 V (50/60Hz)
- 42.1 cm x 43.5 cm x 38.4 cm
- 20.4 kg
- Environmental Standards
- Blue Angel
- 1-year warranty
- Printer Fonts
- TrueType x 111
- Laser - colour
- 50000 pages
- 750 - 4000 pages
- Display Diagonal Size
- 4.3"
- Display Colour Support
- Display Features
- Touch screen, LED display
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 512 MB
- Max Supported Memory
- 512 MB
- Supported Flash Memory
- USB flash drive
Flash Memory
- Flash Memory
- 512 MB (installed) / 512 MB (max)
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Copying Features
- Collation copy, margin erase, resize, ID Copy, 2-up, tray selection
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5e, PDF, URF, PWG
- Image Enhancement Technology
- HP ImageREt 2400, Pantone Calibrated
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 30-bit
Document & Media Handling
- Min Original Size
- 102 x 152 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 100 x 148 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 76 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 300 sheets
- 850 sheets
- 50 sheets
- 150 sheets
- ADF - 50 sheets size: 102 x 152 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² ¦ Input tray - 250 sheets size: 100 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² ¦ Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² ¦ Output tray - 150 sheets
- Speed Details
- Printing: up to 35 ppm (Letter A) - B/W (ISO) ¦ Printing: up to 33 ppm - colour (ISO) ¦ Printing: up to 29 ipm (A4) - B/W duplex ¦ Printing: up to 29 ipm (A4) - colour duplex ¦ Printing: up to 44 ppm (A5) - B/W portrait ¦ Printing: up to 31 ipm (Letter A) - B/W duplex ¦ Copying: up to 35 ppm (Letter A) - B/W normal ¦ Copying: up to 35 ppm (Letter A) - colour normal ¦ Copying: up to 33 ppm (A4) - B/W normal ¦ Copying: up to 33 ppm (A4) - colour normal ¦ Scanning: up to 29 ppm (A4) - B/W normal ¦ Scanning: up to 26 ppm (A4) - colour normal ¦ Scanning: up to 31 ppm (Letter A) - B/W normal ¦ Scanning: up to 28 ppm (Letter A) - colour normal
- 1 x Gigabit LAN - RJ-45 ¦ 1 x USB 2.0 - 4 pin USB Type B ¦ 1 x USB 2.0 host - 4 pin USB Type A
- SSL, Apple Bonjour, WEP, WPA, WPA2, 802.1x, TKIP, AES, Wi-Fi Direct, WPA3, WPS, WPA-Enterprise, IPv6 support, IPv4 support, SNMP 3
- Operating System Support
- Windows 11, Windows 10, MS Windows 7, Android, iOS, macOS 12 Monterey, macOS Big Sur, macOS 10.15, Linux, UNIX, Chrome OS
- Voltage Required
- 585 watt
- Power Consumption Standby
- 18 watt
- Power Consumption Sleep
- 0.8 watt
- Warm-Up Time
- 55 sec
- Included Accessories
- USB cable
- Consumables Included
- 1 x toner cartridge (black) - up to 2000 pages ¦ 1 x toner cartridge (cyan) - up to 1000 pages ¦ 1 x toner cartridge (magenta) - up to 1000 pages ¦ 1 x toner cartridge (yellow) - up to 1000 pages
- UL, cUL, RCM, TUV, GS, BSMI, CCC, BIS, CE/EMC, IT ECO Declaration, CISPR 22:2008 (International) Class B, CISPR 32:2015 (International) Class B, EN 55032:2015 Class B + A11:2020, CISPR 35:2016 (International), EN 55035:2017+A11:2020, EN IEC 61000-3-2:2019, EN 61000-3-3:2013 + A1:2019 + A2:2021, FCC CFR47 Part 15 Class B, ICES-003 issue 7 Class B, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62368-1: 2014, EN 62368-1:2014, EN 60825-1:2014, IEC 60825-1:2014, Laser Class 1, EN 62479:2010, IEC 62479:2010, LVD 2014/35/EU, UL 62368-1-2014 Second Edition, CSA C22.2 No. 62368-1:2014 Second Edition, IEC 62471:2006, EN 62471:2008, 21 CFR 1040.10, 21 CFR 1040.11, DE-UZ 219
- Blue Angel Compliant
- Limited warranty - 1 year - on-site - response time: next business day
- 42.1 cm
- 43.5 cm
- 38.4 cm
- 20.4 kg
- Shipping Width
- 59.7 cm
- Shipping Depth
- 49.7 cm
- Shipping Height
- 49.2 cm
- Shipping Weight
- 23.6 kg
- Sound Emission
- 50 dBA (operating)
- 10 °C
- 32.5 °C
- 10 - 80% RH (non-condensing)
HP 220A - yellow - original - LaserJet - toner cartridge | In Stock | £82.32 |
HP 220A - magenta - original - LaserJet - toner cartridge | In Stock | £82.32 |
HP 220A - cyan - original - LaserJet - toner cartridge | In Stock | £82.32 |
HP 220A - black - original - LaserJet - toner cartridge | In Stock | £68.24 |
HP 220X - High Yield - black - original - LaserJet - toner cartridge | In Stock | £135.21 |
HP 220X - High Yield - cyan - original - LaserJet - toner cartridge | In Stock | £166.11 |
HP 220X - High Yield - yellow - original - LaserJet - toner cartridge | In Stock | £166.11 |
HP 220X Magenta Original LaserJet Toner Cartridge (W2203X) | In Stock | £166.11 |
