HP Color LaserJet Pro MFP 3302fdw Multifunction Printer
Quicklinx: HT15WS00 Mfr#: 499Q8F#B19
More than 50 In Stock
£415.55 ex VAT
£498.66 inc VAT
Designed for business work teams that need professional performance with fast, high-quality two-sided printing and scanning with copying and fax, plus award-winning reliability in a compact design.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
  • Business team solution
    Support your business work team with this compact laser printer for blazing fast high-quality colour printing, scanning, copying, and faxing.
  • Fast, automatic single-pass two-sided colour printing, scanning, and copying plus faxing
    Experience high-speed, automatic two-sided colour printing, scanning, and copying at up to 25 pages per minute plus faxing.
  • True-to-life colours
    Bring your business to life with next-generation HP TerraJet Toner designed for more true-to-life, vibrant colours.
  • Compact Design
    Streamline your workspace, reduce clutter, and help boost your team's efficiency with a compact laser printer.
  • Advanced productivity features
    Create an HP account to maximise productivity with advanced features.
  • HP Web Jetadmin
    Centralise your printer management. HP Web Jetadmin easily adds and updates devices, solutions, and policies.
HP Color LaserJet Pro MFP 3302fdw - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, Spanish, French, Italian / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
40000 pages
Recommended Monthly Volume
150 - 2500 pages
Max Copying Speed
Up to 25 ppm (mono) / up to 25 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 400 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 203 x 196 dpi, 203 x 98 dpi
Scanning
1200 x 1200 dpi
Display
4.3"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, glossy paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
Gigabit LAN, USB 2.0, USB 2.0 host, Wi-Fi(ac)
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to PDF, Terrajet Cartridge, scan to network, scan to SharePoint, scan to USB drive, scan to PC, HP Universal Scan, HP Auto-On/Auto-Off Technology, scan to Cloud, walk-up USB printing, Mopria certified
AC 230 V (50/60Hz)
41.8 cm x 41.912 cm x 34.132 cm
17.1 kg
Environmental Standards
Blue Angel
1-year warranty
Printer Fonts
TrueType x 111
Fax Type
Plain paper
Printing Technology
Laser - colour
40000 pages
150 - 2500 pages
Display Diagonal Size
4.3"
Display Colour Support
Display Features
Capacitive touchscreen
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
512 MB
Flash Memory
Flash Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Copying Features
ID Copy, two-sided copy, N-up, binding margin, booklet creation
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 5, PCL 6, PDF, URF, PWG, PCLm, JPEG, PostScript 3
Automatic Duplexing
First Print Out Time B/W
10.8 sec
First Print Out Time Colour
10.9 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 500 pages
PC Faxing
Fax Machine Features
Speed Dialing
200 station(s)
Telephone / Fax Switch
Delayed Transmission
Distinctive Ring Detection (DRD), junk fax barrier, fax forwarding, automatic redialing
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 100 x 148 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 76 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
250 sheets
50 sheets
100 sheets
ADF - 50 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets size: 100 x 148 mm - Legal (216 x 356 mm) , Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm) , Output tray - 100 sheets
Speed Details
Printing: up to 25 ppm (A4) - B/W (ISO) , Printing: up to 26 ppm (Letter A) - B/W (ISO) , Printing: up to 5 ppm (A5) - B/W portrait , Printing: up to 25 ppm - colour (ISO) , Printing: up to 5 ppm (A5) - colour portrait , Printing: up to 15 ipm (A4) - B/W duplex , Printing: up to 15.5 ipm (Letter A) - B/W duplex , Printing: up to 43 ppm (A5) - B/W landscape , Printing: up to 26 ppm (A5) - colour landscape , Copying: up to 13 ppm (A4) - B/W normal , Copying: up to 13 ppm (A4) - colour normal , Copying: up to 13 ppm (A4) - B/W duplex , Copying: up to 13 ppm (A4) - colour duplex , Copying: up to 13 ppm (Letter A) - B/W normal , Copying: up to 13 ppm (Letter A) - colour normal , Copying: up to 13 ppm (Letter A) - B/W duplex , Copying: up to 13 ppm (Letter A) - colour duplex , Scanning: up to 19 ppm (A4) - B/W normal , Scanning: up to 8 ppm (A4) - colour normal , Scanning: up to 20 ppm (Letter A) - B/W normal , Scanning: up to 9 ppm (Letter A) - colour normal
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 host - 4 pin USB Type A , 2 x modem - RJ-11
Security Protocols & Features
WEP, WPA, WPA2, AES, TKIP, WPS
Operating System Support
Windows 11, Windows 10, Android, iOS, macOS 13, macOS 12 Monterey, macOS 11, Linux, MS Windows Server 2022, MS Windows Server 2019, MS Windows Server 2016
Software Included
HP Web Jetadmin
AC 230 V (50/60Hz)
416 Watt
Power Consumption Standby
7.6 Watt
Power Consumption Sleep
0.95 Watt
Warm-Up Time
55 sec
First Copy Out Time B/W
9.6 sec
First Copy Out Time Colour
13.5 sec
Consumables Included
1 x toner cartridge (black) - up to 600 pages , 1 x toner cartridge (cyan) - up to 500 pages , 1 x toner cartridge (magenta) - up to 500 pages , 1 x toner cartridge (yellow) - up to 500 pages
FCC Class B certified, CISPR 22 Class B, EN55022 Class B, RSS-210, FCC CFR47 Part 68, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, FCC CFR47 Part 15 C, GB 9254 Class B, GB 17625.1, EN 62311, EN 61000-3-3:2008, ICES-003 issue 4 Class B, EN 61000-3-2:2006+A1:2009+A2:2009, EN 300 328 V1.7.1, IEC 62479, IEC 60825-1:2007, EN 62479:2010, IEC 62311, EN 55024:2010, EN 301 489-1, GB 4943.1-2011, EN 301 489-17
Blue Angel Compliant
Limited warranty - 1 year
41.8 cm
41.912 cm
34.132 cm
17.1 kg
Shipping Width
49.7 cm
Shipping Depth
39.8 cm
Shipping Height
53.2 cm
Shipping Weight
20.6 kg
Sound Emission
16 dBA (idle) / 51 dBA (operating)
15 °C
30 °C
10 - 80% RH (non-condensing)
HT15 HP 219X - High Yield - black - original - LaserJet - toner cartridge In Stock £70.11
HT15 HP 219X - High Yield - cyan - original - LaserJet - toner cartridge In Stock £80.52
HT15 HP 219X - High Yield - magenta - original - LaserJet - toner cartridge In Stock £80.52
HT15 HP 219X - High Yield - yellow - original - LaserJet - toner cartridge In Stock £80.52
Functionality: Scanner
Functionality: Fax
Functionality: Copier
Functionality: Printer
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
