Designed for business work teams that need professional performance with fast, high-quality two-sided printing and scanning with copying and fax, plus award-winning reliability in a compact design.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
Business team solution
Support your business work team with this compact laser printer for blazing fast high-quality colour printing, scanning, copying, and faxing. -
Fast, automatic single-pass two-sided colour printing, scanning, and copying plus faxing
Experience high-speed, automatic two-sided colour printing, scanning, and copying at up to 25 pages per minute plus faxing. -
True-to-life colours
Bring your business to life with next-generation HP TerraJet Toner designed for more true-to-life, vibrant colours. -
Compact Design
Streamline your workspace, reduce clutter, and help boost your team's efficiency with a compact laser printer. -
Advanced productivity features
Create an HP account to maximise productivity with advanced features. -
HP Web Jetadmin
Centralise your printer management. HP Web Jetadmin easily adds and updates devices, solutions, and policies.
- HP Color LaserJet Pro MFP 3302fdw - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, Spanish, French, Italian / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 40000 pages
- Recommended Monthly Volume
- 150 - 2500 pages
- Max Copying Speed
- Up to 25 ppm (mono) / up to 25 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 400 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 203 x 196 dpi, 203 x 98 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 4.3"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, glossy paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- Gigabit LAN, USB 2.0, USB 2.0 host, Wi-Fi(ac)
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to PDF, Terrajet Cartridge, scan to network, scan to SharePoint, scan to USB drive, scan to PC, HP Universal Scan, HP Auto-On/Auto-Off Technology, scan to Cloud, walk-up USB printing, Mopria certified
- Power
- AC 230 V (50/60Hz)
- 41.8 cm x 41.912 cm x 34.132 cm
- 17.1 kg
- Environmental Standards
- Blue Angel
- 1-year warranty
- Printer Fonts
- TrueType x 111
- Fax Type
- Plain paper
- Laser - colour
- 40000 pages
- 150 - 2500 pages
- Display Diagonal Size
- 4.3"
- Display Colour Support
- Display Features
- Capacitive touchscreen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 512 MB
- Max Supported Memory
- 512 MB
Flash Memory
- Flash Memory
- 512 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Copying Features
- ID Copy, two-sided copy, N-up, binding margin, booklet creation
Printing
- Printer Drivers / Emulations
- PCL 5, PCL 6, PDF, URF, PWG, PCLm, JPEG, PostScript 3
- First Print Out Time B/W
- 10.8 sec
- First Print Out Time Colour
- 10.9 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 500 pages
- PC Faxing
Fax Machine Features
- Speed Dialing
- 200 station(s)
- Telephone / Fax Switch
- Delayed Transmission
- Distinctive Ring Detection (DRD), junk fax barrier, fax forwarding, automatic redialing
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 100 x 148 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 76 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 250 sheets
- 50 sheets
- 100 sheets
- ADF - 50 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets size: 100 x 148 mm - Legal (216 x 356 mm) , Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm) , Output tray - 100 sheets
- Speed Details
- Printing: up to 25 ppm (A4) - B/W (ISO) , Printing: up to 26 ppm (Letter A) - B/W (ISO) , Printing: up to 5 ppm (A5) - B/W portrait , Printing: up to 25 ppm - colour (ISO) , Printing: up to 5 ppm (A5) - colour portrait , Printing: up to 15 ipm (A4) - B/W duplex , Printing: up to 15.5 ipm (Letter A) - B/W duplex , Printing: up to 43 ppm (A5) - B/W landscape , Printing: up to 26 ppm (A5) - colour landscape , Copying: up to 13 ppm (A4) - B/W normal , Copying: up to 13 ppm (A4) - colour normal , Copying: up to 13 ppm (A4) - B/W duplex , Copying: up to 13 ppm (A4) - colour duplex , Copying: up to 13 ppm (Letter A) - B/W normal , Copying: up to 13 ppm (Letter A) - colour normal , Copying: up to 13 ppm (Letter A) - B/W duplex , Copying: up to 13 ppm (Letter A) - colour duplex , Scanning: up to 19 ppm (A4) - B/W normal , Scanning: up to 8 ppm (A4) - colour normal , Scanning: up to 20 ppm (Letter A) - B/W normal , Scanning: up to 9 ppm (Letter A) - colour normal
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 host - 4 pin USB Type A , 2 x modem - RJ-11
- WEP, WPA, WPA2, AES, TKIP, WPS
- Operating System Support
- Windows 11, Windows 10, Android, iOS, macOS 13, macOS 12 Monterey, macOS 11, Linux, MS Windows Server 2022, MS Windows Server 2019, MS Windows Server 2016
- Software Included
- HP Web Jetadmin
- Voltage Required
- 416 watt
- Power Consumption Standby
- 7.6 watt
- Power Consumption Sleep
- 0.95 watt
- Warm-Up Time
- 55 sec
- First Copy Out Time B/W
- 9.6 sec
- First Copy Out Time Colour
- 13.5 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 600 pages , 1 x toner cartridge (cyan) - up to 500 pages , 1 x toner cartridge (magenta) - up to 500 pages , 1 x toner cartridge (yellow) - up to 500 pages
- FCC Class B certified, CISPR 22 Class B, EN55022 Class B, RSS-210, FCC CFR47 Part 68, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, FCC CFR47 Part 15 C, GB 9254 Class B, GB 17625.1, EN 62311, EN 61000-3-3:2008, ICES-003 issue 4 Class B, EN 61000-3-2:2006+A1:2009+A2:2009, EN 300 328 V1.7.1, IEC 62479, IEC 60825-1:2007, EN 62479:2010, IEC 62311, EN 55024:2010, EN 301 489-1, GB 4943.1-2011, EN 301 489-17
- Blue Angel Compliant
- Limited warranty - 1 year
- 41.8 cm
- 41.912 cm
- 34.132 cm
- 17.1 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 39.8 cm
- Shipping Height
- 53.2 cm
- Shipping Weight
- 20.6 kg
- Sound Emission
- 16 dBA (idle) / 51 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80% RH (non-condensing)
HP 219X - High Yield - black - original - LaserJet - toner cartridge | In Stock | £76.69 |
HP 219X - High Yield - cyan - original - LaserJet - toner cartridge | In Stock | £88.08 |
HP 219X - High Yield - magenta - original - LaserJet - toner cartridge | In Stock | £88.08 |
HP 219X - High Yield - yellow - original - LaserJet - toner cartridge | In Stock | £88.08 |
