HP Color LaserJet Pro M277dw Multifunction Printer
Quicklinx: B670WS00 Mfr#: B3Q11A#B19
You'd never expect this much performance from such a small package. This loaded MFP and Original HP Toner cartridges with JetIntelligence combine to give you the tools you need to get the job done.
  • Colour touchscreen (printer)
    Manage jobs directly at the MFP, using the HP colour touchscreen.
  • Only the power you need
    Help save energy with HP Auto-On/Auto-Off Technology.
  • 2-sided printing
    Allows you to print on both sides of the page, cutting your paper use by up to 50%.
  • Mobile printing at a touch
    Enable touch-to-print convenience from mobile devices.
  • Unleash your printing
    Print wirelessly from your mobile device without a Wi-Fi code or password.
  • Automatic document feeder
    Allows multiple pages to be copied or scanned at one time.
HP Color LaserJet Pro MFP M277dw - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 2500 pages
Max Copying Speed
Up to 18 ppm (mono) / up to 18 ppm (colour)
Max Copying Resolution
Up to 300 x 420 dpi (mono) / up to 300 x 420 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 203 x 96 dpi, 203 x 192 dpi
Scanning
1200 x 1200 dpi
Display
3"
Original Size
101.6 x 152.4 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, greeting cards, photo paper
Standard Media Capacity
150 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to Cloud, Instant-on Technology, touch-to-print
AC 230 V (50Hz)
42 cm x 41.7 cm x 32.2 cm
16.3 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - colour
30000 pages
250 - 2500 pages
Display Diagonal Size
3"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
Fit to page, ID Card Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, PCLm
Image Enhancement Technology
HP ImageREt 3600
Automatic Duplexing
First Print Out Time B/W
11.5 sec
First Print Out Time Colour
13 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
30-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 400 pages
PC Faxing
Yes (send only)
Fax Machine Features
Speed Dialing
100 station(s)
Broadcast Transmission
119 stations
Delayed Transmission
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), poll receive
Document & Media Handling
Min Original Size
101.6 x 152.4 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
52 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 101.6 x 152.4 mm, B6 (125 x 176 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, 127 x 203.2 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
150 sheets
1 sheet
100 sheets
Bypass tray - 1 sheet , Input tray - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 52 g/m² - 220 g/m² , ADF - 50 sheets size: 101.6 x 152.4 mm - Legal (216 x 356 mm) weight: 60 g/m² - 90 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 18 ppm (A4) - B/W normal , Printing: up to 18 ppm (A4) - colour normal , Printing: up to 19 ppm (Letter A) - B/W normal , Printing: up to 19 ppm (Letter A) - colour normal , Copying: up to 18 ppm (A4) - B/W normal , Copying: up to 18 ppm (A4) - colour normal , Copying: up to 19 ppm (Letter A) - B/W normal , Copying: up to 19 ppm (Letter A) - colour normal , Copying: up to 11 ipm (A4) - B/W duplex , Copying: up to 11 ipm (A4) - colour duplex , Copying: up to 11 ipm (Letter A) - B/W duplex , Copying: up to 11 ipm (Letter A) - colour duplex , Scanning: up to 21 ppm (A4) - B/W normal , Scanning: up to 14 ppm (A4) - colour normal , Scanning: up to 21 ppm (Letter A) - B/W normal , Scanning: up to 14 ppm (Letter A) - colour normal
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x modem - RJ-11
Security Protocols & Features
WEP, WPA, WPA2, TKIP, AES
Operating System Support
Sun Solaris 8, MS Windows XP SP3, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows XP 64-bit Edition, SuSe Linux 10.3, HP-UX 11.0, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Apple Mac OS X 10.7, Debian Linux 5.0, Red Hat Enterprise Linux 5, SuSe Linux 11.0, SuSe Linux 11.1, SuSe Linux 11.2, Debian Linux 5.0.1, Debian Linux 5.0.2, Debian Linux 5.0.3, Ubuntu Linux 8.04, Oracle Solaris 9, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, Android, iOS, Apple Mac OS X 10.9, Windows 8.1 64-bit, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Linux 9.4, Linux 9.5, Ubuntu Linux 8.04.1, Ubuntu Linux 8.04.2, Windows RT 8, Windows 8 Pro, Windows 8 Pro 64-bit, Windows 8 Enterprise, Windows 8 Enterprise 64-bit, Windows 8 Enterprise N, Windows 8 Enterprise N 64-bit
Software Included
Drivers & Utilities
AC 230 V (50Hz)
365 Watt
Power Consumption Standby
10.5 Watt
Power Consumption Sleep
2.7 Watt
First Copy Out Time B/W
13.5 sec
First Copy Out Time Colour
16 sec
USB cable
Consumables Included
1 x toner cartridge (black) - up to 1500 pages , 1 x toner cartridge (cyan) - up to 700 pages , 1 x toner cartridge (magenta) - up to 700 pages , 1 x toner cartridge (yellow) - up to 700 pages
FCC Class B certified, CISPR 22 Class B, Laser Class 1, FCC CFR47 Part 15, TBR21, EN 60825-1, CECP, EN 61000-3-3:2008, CSA C22.2 No. 60950-1-07 Second Edition, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, ICES-003 issue 5 Class B, EN 62479:2010, IEC60950-1:2005+A1:2009, EN 55024:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN 55022:2010 Class B
ENERGY STAR Certified
42 cm
41.7 cm
32.2 cm
16.3 kg
Shipping Width
53.2 cm
Shipping Depth
49.8 cm
Shipping Height
39.8 cm
Shipping Weight
21.2 kg
Sound Emission
50 dBA (operating)
15 °C
30 °C
10 - 80% (non-condensing)
B670 HP 201A Black Original Toner Cartridge In Stock £64.99
B670 HP 201A Cyan Original Toner Cartridge In Stock £75.98
B670 HP 201A Yellow Original Toner Cartridge In Stock £76.66
B670 HP 201A Magenta Original Toner Cartridge In Stock £76.66
B670 HP 201X High Yield Black Original Toner Cartridge In Stock £86.52
B670 HP 201X High Yield Cyan Original Toner Cartridge In Stock £96.99
B670 HP 201X High Yield Yellow Original Toner Cartridge In Stock £96.99
B670 HP 201X High Yield Magenta Original Toner Cartridge In Stock £95.98
