HP Color LaserJet Pro M255dw - Printer - colour - Duplex - l
Quicklinx: G4K5WS00 Mfr#: 7KW64A#B19
  • Windows 8 (32/64 bits)
Impress with colour and increase efficiency. Get high-quality colour and fast two-sided print speeds. Save time with Smart Task shortcuts in HP Smart app, and print and scan from your phone. Get seamless connections and strong security solutions.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
  • Best-in-class mobile print app
    Get easy printing and scanning from your mobile device, with HP Smart.
  • Automate scanning tasks and save time
    Eliminate steps in repetitive tasks with customisable shortcuts, using Smart Tasks in HP Smart app.
  • Powerful printing. Energy smart
    Count on high-quality colour and peak printing performance with Original HP Toner cartridges with JetIntelligence.
  • Automatic two-sided printing
    Speed through multipage documents with automatic two-sided printing.
  • The right touch for business tasks
    Easily manage tasks at the device with an intuitive touchscreen.
HP Color LaserJet Pro M255dw - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
Number of Users
1-5 users
14.8 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 21 ppm - B/W - A4 (210 x 297 mm) , Up to 22 ppm - black normal - ANSI A (Letter) (216 x 279 mm) , Up to 21 ppm - colour - A4 (210 x 297 mm) , Up to 22 ppm - colour normal - ANSI A (Letter) (216 x 279 mm) , Up to 12 ppm - duplex - A4 (210 x 297 mm) , Up to 13 ipm - duplex - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
600 x 600 dpi
Max Resolution (Colour)
600 x 600 dpi
Image Enhancement Technology
HP ImageREt 3600
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Preview Screen Size
2.7"
800 MHz
RAM Installed (Max)
256 MB (256 MB)
Flash Memory Installed (Max)
256 MB (256 MB)
Language Simulation
PCL 5C, PostScript 3, PCL 6, PDF, PCLm, URF, PWG
Media Type
Envelopes, transparencies, labels, plain paper, photo paper, bond paper, recycled paper, brochure paper, card stock, light-weight paper, preprinted paper, glossy paper
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray, priority feed tray
Monthly Duty Cycle (max)
40000 pages
Recommended Monthly Volume
150 - 2500 pages
Print server
Printer Features
Instant-on Technology
SunSoft Solaris 8, HP-UX 11, Red Hat Fedora Core 9, Red Hat Fedora Core 10, Ubuntu 8.10, Ubuntu 9.04, SuSE Linux 11, Debian GNU/Linux 5.0, Red Hat Enterprise Linux 5, SuSE Linux 10.3, Android, Ubuntu 8.04, Microsoft Windows Vista (32/64 bits), Ubuntu 9.10, Debian GNU/Linux 5.0.1, Ubuntu 10.04, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Red Hat Fedora 11, Red Hat Fedora 12, Apple MacOS X Lion 10.7, Apple iOS, SuSE Linux 11.1, SuSE Linux 11.2, Ubuntu 8.04.1, Ubuntu 8.04.2, Debian GNU/Linux 5.0.2, Debian GNU/Linux 5.0.3, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 8 Enterprise (32/64 bits), Windows 8 Pro (32/64 bits), Oracle Solaris 9, Apple OS X 10.9 Mavericks, Microsoft Windows RT 8, Windows 8 Enterprise N (32/64 bits), Linux 9.4, Linux 9.5
Environmental Standards
EPEAT Silver
1-year warranty
39.2 cm x 41.9 cm x 24.75 cm
Printer Type
Number of Users
1-5 users
Printer
Print Speed
Built-in Devices
Touch screen
Preview Screen Size
2.7"
Wireless
AirPrint Enabled
600 x 600 dpi
600 x 600 dpi
HP ImageREt 3600
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
10.5 sec
First Print Out Time Colour
12.2 sec
Language Simulation
Fonts Included
84 x TrueType
Printer Features
Media Handling
800 MHz
RAM
RAM Installed (Max)
256 MB / 256 MB (max)
Flash Memory
Flash Memory
256 MB (installed) / 256 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 76 x 127 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 220 g/m²
250 sheets
Media Feeders
1 x automatic - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Output Trays Capacity
100 sheets
Duty Cycle
40000 pages
150 - 2500 pages
Print server
Remote Management Protocol
SNMP 1, SNMP 3, HTTP, HTTPS, SLP
Security Protocols & Features
Apple Bonjour, WEP, WPA, WPA2, 802.1x, TKIP, AES, WPS, Wi-Fi Direct, IPv6 support
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
IEC 60950-1, FCC CFR47 Part 15 B, EN 62479:2010, EN 61000-3-3:2013, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, EN 55024:2010+A1:2015, EN 55032:2012, ICES-003 issue 6, CAN/CSA-C22.2 No. 60950-1-07 Second Edition, CISPR 32:2012, EN 60825-1:2014, IEC 60825-1:2014, CISPR 32:2015, EN 55032:2015+AC:2016 Class B, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Power supply - internal
Frequency Required
50/60 Hz
337 watt
Power Consumption Stand by
7.2 watt
Power Consumption Sleep
0.8 watt
Software Included
Drivers & Utilities
EPEAT Compliant
EPEAT Silver
Blue Angel
ENERGY STAR
Limited warranty - parts - 1 year
10 °C
32.5 °C
10 - 80%
Sound Emission (Idle)
16 dBA
Sound Emission (Operating)
50 dBA
39.2 cm
41.9 cm
24.75 cm
14.8 kg
Width (Shipping)
49.8 cm
Depth (Shipping)
29.8 cm
Height (Shipping)
51 cm
Weight (Shipping)
17.4 kg
Ink (9)
G4K5 HP 207A Black Original LaserJet Toner Cartridge In Stock £51.92
G4K5 HP 207A Cyan Original LaserJet Toner Cartridge In Stock £61.28
G4K5 HP 207A Yellow Original LaserJet Toner Cartridge In Stock £61.28
G4K5 HP 207A Magenta Original LaserJet Toner Cartridge In Stock £61.28
G4K5 HP 207X High Yield Black Original LaserJet Toner Cartridge In Stock £79.01
G4K5 HP 207X High Yield Cyan Original LaserJet Toner Cartridge In Stock £82.74
G4K5 HP 207X High Yield Yellow Original LaserJet Toner Cartridge In Stock £82.74
G4K5 HP 207X High Yield Magenta Original LaserJet Toner Cartridge In Stock £82.74
G4K5 HP Glossy Laser Paper 150GSM 150 SHT/A4 In Stock £16.54
Other bundles (2)
G4K5 HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £33.60
G4K5 HP Care Pack Standard Exchange Extended Service Agreement 3 Years Shipment for LaserJet 1018s In Stock £28.19
