Print, copy, scan – in colour, and fax, with the first HP LaserJet that prints from the Web and mobile devices. Connect to a wired or wireless network. Use a colour touchscreen to print vivid documents.
Bring easy, touchscreen printing to your office
Use business apps and the 8.9 cm (3.5-inch) colour touchscreen to access and print information from the Web.Print from anywhere, anytime, with a smartphone, notebook PC or other mobile device, using HP ePrint and print wirelessly from your iPad , iPhone and iPod touch with AirPrint .Easily copy both sides of an ID card onto a single-sided document.Spend more time on business: install and set up your MFP with just a few clicks, and enjoy easy maintenance.HP LaserJet print cartridges are easy to order and install, and HP SureSupply helps you shop for supplies. -
Produce professional-quality marketing materials
Make the most of your printed images with HP ImageREt 3600 which enhances print resolution to deliver crisp detail and consistent colour.Enhance the quality of your copied images, text and graphics with automatic copy optimisation.Print crisp text and vivid colour images – use Original HP LaserJet print cartridges with HP ColorSphere toner.Print black text affordably – at the same cost per page as a black-and-white HP LaserJet printer. -
Increase productivity – share the MFP on a network
Connect wirelessly to the MFP and print from virtually anywhere in your office, using 802.11b/g/n wireless.Boost office efficiency by sharing printing resources using built-in 10/100 Ethernet.Start and finish printing sooner from low-power or Ready modes, using Instant-on Technology.Copy and scan documents with multiple pages, unattended, using the 35-page automatic document feeder.Print quickly and conveniently with a front-panel USB port. -
Minimise your environmental impact
Conserve energy with Instant-on Technology and Instant-on Copy.Save space and resources with the compact size of this colour laser MFP.Get free and easy recycling – cartridges returned through HP Planet Partners are recycled responsibly.
- HP LaserJet Pro CM1415fnw - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 30000 impressions
- Recommended Monthly Volume
- 300 - 1500 pages
- Max Copying Speed
- Up to 12 ppm (mono) / up to 8 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 196 dpi
- Scanning
- 1200 dpi
- Display
- 3.5"
- Original Size
- 76 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 125 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- Power
- AC 110/230 V (50/60Hz)
- 44.3 cm x 47.2 cm x 41.5 cm
- 22.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - colour
- 30000 impressions
- 300 - 1500 pages
- Display Diagonal Size
- 3.5"
- Display Features
- Touch screen
- Interface
- Standard Memory
- 160 MB 160 MB
- Max Supported Memory
- 160 MB 160 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c
- First Print Out Time B/W
- 26 sec
- First Print Out Time Colour
- 32 sec
Scanning
- Optical Resolution
- 1200 dpi
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 196 dpi
- Total Memory Capacity
- Up to 250 pages
Fax Machine Features
- Speed Dialing
- 120 station(s)
- Broadcast Transmission
- 120 stations
- Remote Fax Retrieval (Polling)
- Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing
Document & Media Handling
- Min Original Size
- 76 x 127 mm
- Max Original Size
- 35 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Supported Media Type
- 150 sheets
- 125 sheets
- Output tray - 125 sheets size: 76 x 127 mm - Legal (216 x 356 mm) , Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm)
- Speed Details
- Copying: up to 12 ppm - B/W , Printing: up to 12 ppm - B/W , Copying: up to 8 ppm - colour , Printing: up to 8 ppm - colour
- 1 x USB 2.0 , 1 x USB host , 1 x LAN
- Network Protocols
- TCP/IP
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.5.8, MS Windows Vista
- Voltage Required
- 285 Watt
- Power Consumption Standby
- 17.5 Watt
- Power Consumption Sleep
- 9 Watt
- ENERGY STAR Certified
- Limited warranty - 1 year
- 44.3 cm
- 47.2 cm
- 41.5 cm
- 22.7 kg
- Shipping Width
- 61 cm
- Shipping Depth
- 60 cm
- Shipping Height
- 50 cm
- Shipping Weight
- 25.9 kg
- 17 °C
- 25 °C
- 20 - 80%
HP 128A Black Original LaserJet Toner Cartridge | In Stock | £66.66 |
HP 128A Cyan Original LaserJet Toner Cartridge | In Stock | £63.47 |
HP 128A Magenta Original LaserJet Toner Cartridge | In Stock | £63.41 |
HP 128A Yellow Original LaserJet Toner Cartridge | In Stock | £63.47 |
