HP Color LaserJet Pro CM1415fnw ( fax / copier / printer / scanner ) - Colour Laser - Hi-Speed USB
HP LaserJet Pro CM1415fnw Color Multifunction Printer
Quicklinx: 772JWS00 Mfr#: CE862A#B19
Print, copy, scan – in colour, and fax, with the first HP LaserJet that prints from the Web and mobile devices. Connect to a wired or wireless network. Use a colour touchscreen to print vivid documents.
  • Bring easy, touchscreen printing to your office
    Use business apps and the 8.9 cm (3.5-inch) colour touchscreen to access and print information from the Web.Print from anywhere, anytime, with a smartphone, notebook PC or other mobile device, using HP ePrint and print wirelessly from your iPad , iPhone and iPod touch with AirPrint .Easily copy both sides of an ID card onto a single-sided document.Spend more time on business: install and set up your MFP with just a few clicks, and enjoy easy maintenance.HP LaserJet print cartridges are easy to order and install, and HP SureSupply helps you shop for supplies.
  • Produce professional-quality marketing materials
    Make the most of your printed images with HP ImageREt 3600 which enhances print resolution to deliver crisp detail and consistent colour.Enhance the quality of your copied images, text and graphics with automatic copy optimisation.Print crisp text and vivid colour images – use Original HP LaserJet print cartridges with HP ColorSphere toner.Print black text affordably – at the same cost per page as a black-and-white HP LaserJet printer.
  • Increase productivity – share the MFP on a network
    Connect wirelessly to the MFP and print from virtually anywhere in your office, using 802.11b/g/n wireless.Boost office efficiency by sharing printing resources using built-in 10/100 Ethernet.Start and finish printing sooner from low-power or Ready modes, using Instant-on Technology.Copy and scan documents with multiple pages, unattended, using the 35-page automatic document feeder.Print quickly and conveniently with a front-panel USB port.
  • Minimise your environmental impact
    Conserve energy with Instant-on Technology and Instant-on Copy.Save space and resources with the compact size of this colour laser MFP.Get free and easy recycling – cartridges returned through HP Planet Partners are recycled responsibly.
HP LaserJet Pro CM1415fnw - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
30000 impressions
Recommended Monthly Volume
300 - 1500 pages
Max Copying Speed
Up to 12 ppm (mono) / up to 8 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 196 dpi
Scanning
1200 dpi
Display
3.5"
Original Size
76 x 127 mm (min) - Legal (216 x 356 mm) (max)
Document Feeder Capacity
35 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper
Standard Media Capacity
150 sheets
Output Trays Capacity
125 sheets
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AC 110/230 V (50/60Hz)
44.3 cm x 47.2 cm x 41.5 cm
22.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - colour
30000 impressions
300 - 1500 pages
Display Diagonal Size
3.5"
Display Features
Touch screen
Standard Memory
160 MB 160 MB
Max Supported Memory
160 MB 160 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c
First Print Out Time B/W
26 sec
First Print Out Time Colour
32 sec
Scanning
Optical Resolution
1200 dpi
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 196 dpi
Total Memory Capacity
Up to 250 pages
Fax Machine Features
Speed Dialing
120 station(s)
Broadcast Transmission
120 stations
Remote Fax Retrieval (Polling)
Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing
Document & Media Handling
Min Original Size
76 x 127 mm
Max Original Size
35 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Supported Media Type
150 sheets
125 sheets
Output tray - 125 sheets size: 76 x 127 mm - Legal (216 x 356 mm) , Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm)
Speed Details
Copying: up to 12 ppm - B/W , Printing: up to 12 ppm - B/W , Copying: up to 8 ppm - colour , Printing: up to 8 ppm - colour
1 x USB 2.0 , 1 x USB host , 1 x LAN
Network Protocols
TCP/IP
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.5.8, MS Windows Vista
285 Watt
Power Consumption Standby
17.5 Watt
Power Consumption Sleep
9 Watt
ENERGY STAR Certified
Limited warranty - 1 year
44.3 cm
47.2 cm
41.5 cm
22.7 kg
Shipping Width
61 cm
Shipping Depth
60 cm
Shipping Height
50 cm
Shipping Weight
25.9 kg
17 °C
25 °C
20 - 80%
772J HP 128A Black Original LaserJet Toner Cartridge In Stock £66.43
772J HP 128A Cyan Original LaserJet Toner Cartridge In Stock £63.63
772J HP 128A Magenta Original LaserJet Toner Cartridge In Stock £63.21
772J HP 128A Yellow Original LaserJet Toner Cartridge In Stock £63.63
