Use a color touchscreen to print, copy, scan and fax. Connect this MFP to a wired or wireless network and give your office high-quality prints with vivid color and sharp black. Save energy and reduce your impact. Use the 3.5-inch color touchscreen to access and print information. Spend more time on business and less time on setup and maintenance. Easily copy both sides of an ID card onto a single-sided document.
Bring easy, touchscreen printing to your office.
Use business apps and the 8.9 cm (3.5-inch) colour touchscreen to access and print information from the Web[1].
Print from anywhere, anytime, with a smartphone, notebook PC or other mobile device, using HP ePrint[2] and print wirelessly from your iPad®, iPhone® and iPod touch® with AirPrint™[9].
Spend more time on business: install and set up your MFP with just a few clicks, and enjoy easy maintenance.HP LaserJet print cartridges are easy to order and install, and HP SureSupply[4] helps you shop for supplies.
Produce professional-quality marketing materials.
Make the most of your printed images with HP ImageREt 3600 which enhances print resolution to deliver crisp detail and consistent colour.
Enhance the quality of your copied images, text and graphics with automatic copy optimisation.
Print crisp text and vivid colour images - use Original HP LaserJet print cartridges with HP ColorSphere toner.
Print black text affordably - at the same cost per page as a black-and-white HP LaserJet printer[5].
Increase productivity - share the MFP on a network.
Connect wirelessly to the MFP and print from virtually anywhere in your office, using 802.11b/g/n wireless[3].Boost office efficiency by sharing printing resources using built-in 10/100 Ethernet.
Start and finish printing sooner from low-power or Ready modes, using Instant-on Technology.
Copy and scan documents with multiple pages, unattended, using the 35-page automatic document feeder.
Print quickly and conveniently with a front-panel USB port.
Minimise your environmental impact.
Conserve energy with Instant-on Technology[6] and Instant-on Copy[7].
Save space and resources with the compact size of this colour laser MFP.
Get free and easy recycling - cartridges returned through HP Planet Partners are recycled responsibly[8].
[1] Requires an Internet connection to the printer. Services may require registration. Applications availability varies by country and requires a firmware upgrade. For details, www.hp.com/go/ePrintCenter.
[2] May require an Internet connection to the printer. Feature works with any Internet and e-mail-capable device and requires a firmware upgrade. For details, www.hp.com/go/ePrintCenter.
[3] Built-in wireless is available on the HP LaserJet Pro CM1415fnw Color MFP. Wireless performance is dependent upon physical environment and distance from access point, and may be limited during active VPN connections.
[4] Programme features and availability may vary by country. For more information, visit www.hp.com/learn/suresupply.
[5] Compared with HP LaserJet Pro P1566/ P1606dn printer (single function) and HP LaserJet Pro M1536dnf MFP. Assuming customer is printing at least 30 percent of total pages in colour with content similar to the colour ISO/IEC 19798 test suite (www.iso.org/jtc1/sc28) and overall average job length of three pages. Yields established using ISO/IEC test standards. Actual yields and costs vary considerably depending on images printed, number of colour pages printed, and other factors.
[6] Energy savings based on HP testing using the ENERGY STAR® program's Typical Electricity Consumption (TEC) method on HP LaserJet products with Instant-on Technology vs. top competitive models as of March 2009.
[7] When compared with fluorescent tubes, Instant-on Copy with LED technology drops energy use by 4 times in idle mode and 1.4 times in copy mode.
[8] Programme availability varies. HP print cartridge return and recycling is currently available in more than 49 countries, territories and regions in Europe, Asia, and North and South America through the HP Planet Partners programme. For more information, visit www.hp.com/recycle.
[9] Supports iOS 4.2 devices (iPad, iPhone 4, iPhone 3GS, and 3rd and 4th generation iPod touch) that support multitasking. Works with HP ePrint-enabled printers and all-in-ones. AirPrint and iOS 4.2 devices require an 802.11 wireless network connection to the printer. Wireless performance is dependent upon physical environment and distance from the access point. AirPrint and the AirPrint Logo are trademarks of Apple Inc. iPad, iPhone, and iPod touch are trademarks of Apple Inc., registered in the U.S. and other countries
Use business apps and the 8.9 cm (3.5-inch) colour touchscreen to access and print information from the Web.Print from anywhere, anytime, with a smartphone, notebook PC or other mobile device, using HP ePrint and print wirelessly from your iPad , iPhone and iPod touch with AirPrint .Easily copy both sides of an ID card onto a single-sided document.Spend more time on business: install and set up your MFP with just a few clicks, and enjoy easy maintenance.HP LaserJet print cartridges are easy to order and install, and HP SureSupply helps you shop for supplies. -
Make the most of your printed images with HP ImageREt 3600 which enhances print resolution to deliver crisp detail and consistent colour.Enhance the quality of your copied images, text and graphics with automatic copy optimisation.Print crisp text and vivid colour images – use Original HP LaserJet print cartridges with HP ColorSphere toner.Print black text affordably – at the same cost per page as a black-and-white HP LaserJet printer. -
Increase productivity – share the MFP on a network
Connect wirelessly to the MFP and print from virtually anywhere in your office, using 802.11b/g/n wireless.Boost office efficiency by sharing printing resources using built-in 10/100 Ethernet.Start and finish printing sooner from low-power or Ready modes, using Instant-on Technology.Copy and scan documents with multiple pages, unattended, using the 35-page automatic document feeder.Print quickly and conveniently with a front-panel USB port. -
Conserve energy with Instant-on Technology and Instant-on Copy.Save space and resources with the compact size of this colour laser MFP.Get free and easy recycling – cartridges returned through HP Planet Partners are recycled responsibly.
- HP LaserJet Pro CM1415fn - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 30000 impressions
- Recommended Monthly Volume
- 300 - 1500 pages
- Max Copying Speed
- Up to 12 ppm (mono) / up to 8 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 196 dpi
- Scanning
- 1200 dpi
- Display
- 3.5"
- Original Size
- 76 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 125 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, USB host
- Power
- AC 110/230 V (50/60Hz)
- 44.3 cm x 47.2 cm x 41.5 cm
- 22.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - colour
- 30000 impressions
- 300 - 1500 pages
- Display Diagonal Size
- 3.5"
- Display Features
- Touch screen
- Interface
- Standard Memory
- 160 MB 160 MB
- Max Supported Memory
- 160 MB 160 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c
- First Print Out Time B/W
- 26 sec
- First Print Out Time Colour
- 32 sec
Scanning
- Optical Resolution
- 1200 dpi
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 196 dpi
- Total Memory Capacity
- Up to 250 pages
Fax Machine Features
- Speed Dialing
- 120 station(s)
- Broadcast Transmission
- 120 stations
- Remote Fax Retrieval (Polling)
- Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing
Document & Media Handling
- Min Original Size
- 76 x 127 mm
- Max Original Size
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Supported Media Type
- 150 sheets
- 125 sheets
- Output tray - 125 sheets size: 76 x 127 mm - A4 (210 x 297 mm) , Input tray - 150 sheets size: 76 x 127 mm - A4 (210 x 297 mm)
- Speed Details
- Copying: up to 12 ppm - B/W , Printing: up to 12 ppm - B/W , Copying: up to 8 ppm - colour , Printing: up to 8 ppm - colour
- 1 x USB 2.0 , 1 x USB host , 1 x LAN
- Network Protocols
- TCP/IP
- Operating System Support
- MS Windows XP, SuSe Linux, MS Windows Server 2003, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.5.8, MS Windows Vista
- Voltage Required
- 285 Watt
- Power Consumption Standby
- 17.5 Watt
- Power Consumption Sleep
- 9 Watt
- ENERGY STAR Certified
- Limited warranty - 1 year
- 44.3 cm
- 47.2 cm
- 41.5 cm
- 22.7 kg
- Shipping Width
- 61 cm
- Shipping Depth
- 60 cm
- Shipping Height
- 50 cm
- Shipping Weight
- 25.9 kg
- 20 - 80%
HP 128A Cyan Original LaserJet Toner Cartridge | In Stock | £63.63 |
HP 128A Yellow Original LaserJet Toner Cartridge | In Stock | £63.63 |
HP 128A 3-pack Cyan/Magenta/Yellow Original LaserJet Toner Cartridges | In Stock | £180.59 |
