HP Color LaserJet Pro 3202dw Printer
Quicklinx: HP0WWS00 Mfr#: 499R0F#B19
20 In Stock
£255.02 ex VAT
£306.02 inc VAT
Designed for business work teams that need professional performance with fast, high-quality two-sided colour printing, laser productivity, and award-winning reliability in a space-saving design.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
HP Color LaserJet Pro 3202dw - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
Number of Users
3-10 users
13.8 kg
English, German, Spanish, French, Italian / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 25 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 25 ppm - colour (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 26 ppm - B/W (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm) , Up to 43 ppm - B/W (ISO/IEC 24734) - A5 Landscape , Up to 5 ppm - B/W (ISO/IEC 24734) - A5 Portrait , Up to 15 ipm - duplex - A4 (210 x 297 mm) , Up to 15.5 ipm - duplex - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
600 x 600 dpi
Max Resolution (Colour)
600 x 600 dpi
Automatic Duplexing
Gigabit LAN, USB 2.0, Wi-Fi(ac)
AirPrint Enabled
1.2 GHz
RAM Installed (Max)
256 MB (256 MB)
Language Simulation
PCL 6, PCL 5, PostScript 3, PDF, URF, PWG, PCLm, JPEG
Media Type
Envelopes, labels, plain paper, photo paper, bond paper, recycled paper, preprinted paper, postcards, glossy paper, transparencies, card stock, letterheaded paper
Total Media Capacity
251 sheets
Media Handling
250-sheet input tray, 1-sheet multipurpose tray
Monthly Duty Cycle (max)
40000 pages
Recommended Monthly Volume
150 - 2500 pages
Print server
Printer Features
Auto Power On, Auto Power Off, TerraJet Cartridge, print from mobile device, Print Anywhere, Mopria certified, 55 sec warm-up time
AC 230 V
Windows 11, Windows 10, Apple macOS 12, Apple macOS 13, Apple macOS 14, Android, Apple iOS, Linux, Microsoft Windows Server 2022, Microsoft Windows Server 2019, Microsoft Windows Server 2016
1-year warranty
39 cm x 41.912 cm x 25.419 cm
Printer Type
Number of Users
3-10 users
Printer
Toner Cartridge Configuration
Cyan, magenta, yellow, black
Print Speed
Built-in Devices
2" DFSTN-backlit display, Stacker
Wireless
AirPrint Enabled
600 x 600 dpi
600 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
Language Simulation
Fonts Included
111 x TrueType
Colour Management Features
Mopria
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
256 MB / 256 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 102 x 127 mm, 76 x 127 mm, 195 x 270 mm, 184 x 260 mm, JIS B6 (128 x 182 mm), 197 x 273 mm, Oficio (216 x 343 mm), JIS B5 (182 x 257 mm)
Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
Media Weight
60 g/m² - 200 g/m²
251 sheets
Media Feeders
Multi-purpose tray: 1 x automatic - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , Output tray: 1 x automatic - 100 sheets , Stacker: - 10 envelopes
Output Trays Capacity
100 sheets
Duty Cycle
40000 pages
150 - 2500 pages
Print server
Remote Management Protocol
IPv4, IPv6, DHCP, DNS
Security Protocols & Features
802.1x, WEP, WPA, WPA2, WPA-Enterprise, AES, TKIP, WPS, Wi-Fi Direct
1 x USB 2.0 , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 600 pages , 1 x toner cartridge (cyan) - up to 500 pages , 1 x toner cartridge (magenta) - up to 500 pages , 1 x toner cartridge (yellow) - up to 500 pages
DE-UZ 219, RCM, TUV, GS, BSMI, CCC, BIS, KC, SIRIM, Ukraine, EAC, FCC, UL, EN IEC 61000-3-2:2019+A1:2021, EN 61000-3-3:2021, CISPR 32:2019, CISPR 35: 2016, EN 55032:2015+A11:2020+A1:2020, EN 55035:2017+A11:2020, EN 61000-4-12:2017, FCC CFR 47 Part 15 Class B, ICES-003:2019 Issue 6, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62368-1: 2014, EN 62368-1:2014+A11:2017, IEC 62368-1:2018, EN IEC 62368-1:2020+A11:2020, EN 60825-1:2014 + A11:2021, IEC 60825-1:2014, EN 62479:2010, IEC 62479:2010, CSA C22.2 No. 62368-1:19 Third Edition, CSA C22.2 No. 62368-1:2014 Second Edition, UL 62368-1 Second Edition, UL 62368-1 Third Edition, IEC 60825-1 Third Edition, RED 2014/53/EU, EN 301 489-1 V2.2.3, EN 301 489-17 V3.2.4, EN 300 328 V2.2.2, EN 301 893 V2.1.1, EN 300 440-1 V2.1.1, FCC 47 CFR Part 15 Subpart B Class B, RSS-247 Issue 1, 2015, RSS-102 Issue 5, IEC 62311:2020, EN 62311:2008
Power supply - internal
AC 230 V
Frequency Required
50/60 Hz
415 Watt
Power Consumption Stand by
6.1 Watt
Power Consumption Sleep
0.63 Watt
System Requirements Details
HD 2 GB
Environmental Standards
Blue Angel
Limited warranty - 1 year
10 °C
32.5 °C
10 - 80% RH (non-condensing)
Sound Emission (Idle)
16 dBA
Sound Emission (Operating)
51 dBA
39 cm
41.912 cm
25.419 cm
13.8 kg
Width (Shipping)
49.7 cm
Depth (Shipping)
33.1 cm
Height (Shipping)
51 cm
Weight (Shipping)
16.9 kg
HP0W HP Care Pack Standard Exchange Extended Service Agreement 3 Years Shipment In Stock £40.43
HP0W HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £47.70
Brand: HP
