Designed for business work teams that need professional performance with fast, high-quality two-sided colour printing, laser productivity, and award-winning reliability in a space-saving design.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
                Business team solutionSupport your business work team with this compact laser printer for high-quality colour printing.
                Fast two-sided colour printingExperience high-speed two-sided colour printing at up to 25 pages per minute.
                True-to-life coloursBring your business to life with next-generation HP TerraJet Toner designed for more true-to-life, vibrant colours.
                Compact DesignStreamline your workspace, reduce clutter, and help boost your team's efficiency with a compact laser printer.
                Advanced productivity featuresCreate an HP account to maximise productivity with advanced features.
                HP Web JetadminCentralise your printer management. HP Web Jetadmin easily adds and updates devices, solutions, and policies.
- HP Color LaserJet Pro 3202dw - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- Number of Users
- 3-10 users
- 13.8 kg
- Localisation
- English, German, Spanish, French, Italian / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 25 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 25 ppm - colour (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 26 ppm - B/W (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm) , Up to 43 ppm - B/W (ISO/IEC 24734) - A5 Landscape , Up to 5 ppm - B/W (ISO/IEC 24734) - A5 Portrait , Up to 15 ipm - duplex - A4 (210 x 297 mm) , Up to 15.5 ipm - duplex - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 600 x 600 dpi
- Max Resolution (Colour)
- 600 x 600 dpi
- Automatic Duplexing
- Interface
- Gigabit LAN, USB 2.0, Wi-Fi(ac)
- AirPrint Enabled
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 256 MB (256 MB)
- Language Simulation
- PCL 6, PCL 5, PostScript 3, PDF, URF, PWG, PCLm, JPEG
- Media Type
- Envelopes, labels, plain paper, photo paper, bond paper, recycled paper, preprinted paper, postcards, glossy paper, transparencies, card stock, letterheaded paper
- Total Media Capacity
- 251 sheets
- Media Handling
- 250-sheet input tray, 1-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 40000 pages
- Recommended Monthly Volume
- 150 - 2500 pages
- Networking
- Print server
- Printer Features
- Auto Power On, Auto Power Off, TerraJet Cartridge, print from mobile device, Print Anywhere, Mopria certified, 55 sec warm-up time
- Power
- AC 230 V
- System Requirements
- Windows 11, Windows 10, Apple macOS 12, Apple macOS 13, Apple macOS 14, Android, Apple iOS, Linux, Microsoft Windows Server 2022, Microsoft Windows Server 2019, Microsoft Windows Server 2016
- 1-year warranty
- 39 cm x 41.912 cm x 25.419 cm
- Printer Type
- Number of Users
- 3-10 users
- Localisation
Printer
- Toner Cartridge Configuration
- Cyan, magenta, yellow, black
- Print Speed
- Built-in Devices
- 2" DFSTN-backlit display, Stacker
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 600 x 600 dpi
- 600 x 600 dpi
- PostScript Support
- Standard
- Fonts Included
- 111 x TrueType
- Colour Management Features
- Mopria
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 256 MB / 256 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 102 x 127 mm, 76 x 127 mm, 195 x 270 mm, 184 x 260 mm, JIS B6 (128 x 182 mm), 197 x 273 mm, Oficio (216 x 343 mm), JIS B5 (182 x 257 mm)
- Envelope Sizes
- International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- Media Weight
- 60 g/m² - 200 g/m²
- 251 sheets
- Media Feeders
- Multi-purpose tray: 1 x automatic - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , Output tray: 1 x automatic - 100 sheets , Stacker: - 10 envelopes
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 40000 pages
- 150 - 2500 pages
- Networking
- Print server
- Remote Management Protocol
- IPv4, IPv6, DHCP, DNS
- 802.1x, WEP, WPA, WPA2, WPA-Enterprise, AES, TKIP, WPS, Wi-Fi Direct
- Connections
- 1 x USB 2.0 , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 600 pages , 1 x toner cartridge (cyan) - up to 500 pages , 1 x toner cartridge (magenta) - up to 500 pages , 1 x toner cartridge (yellow) - up to 500 pages
- DE-UZ 219, RCM, TUV, GS, BSMI, CCC, BIS, KC, SIRIM, Ukraine, EAC, FCC, UL, EN IEC 61000-3-2:2019+A1:2021, EN 61000-3-3:2021, CISPR 32:2019, CISPR 35: 2016, EN 55032:2015+A11:2020+A1:2020, EN 55035:2017+A11:2020, EN 61000-4-12:2017, FCC CFR 47 Part 15 Class B, ICES-003:2019 Issue 6, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62368-1: 2014, EN 62368-1:2014+A11:2017, IEC 62368-1:2018, EN IEC 62368-1:2020+A11:2020, EN 60825-1:2014 + A11:2021, IEC 60825-1:2014, EN 62479:2010, IEC 62479:2010, CSA C22.2 No. 62368-1:19 Third Edition, CSA C22.2 No. 62368-1:2014 Second Edition, UL 62368-1 Second Edition, UL 62368-1 Third Edition, IEC 60825-1 Third Edition, RED 2014/53/EU, EN 301 489-1 V2.2.3, EN 301 489-17 V3.2.4, EN 300 328 V2.2.2, EN 301 893 V2.1.1, EN 300 440-1 V2.1.1, FCC 47 CFR Part 15 Subpart B Class B, RSS-247 Issue 1, 2015, RSS-102 Issue 5, IEC 62311:2020, EN 62311:2008
- Power Device
- Power supply - internal
- Voltage Required
- AC 230 V
- Frequency Required
- 50/60 Hz
- 415 Watt
- Power Consumption Stand by
- 6.1 Watt
- Power Consumption Sleep
- 0.63 Watt
- OS Required
- System Requirements Details
- HD 2 GB
Environmental Standards
- Blue Angel
- Limited warranty - 1 year
- 10 °C
- 32.5 °C
- 10 - 80% RH (non-condensing)
- Sound Emission (Idle)
- 16 dBA
- Sound Emission (Operating)
- 51 dBA
- 39 cm
- 41.912 cm
- 25.419 cm
- 13.8 kg
- Width (Shipping)
- 49.7 cm
- Depth (Shipping)
- 33.1 cm
- Height (Shipping)
- 51 cm
- Weight (Shipping)
- 16.9 kg
Ink (4)
|  | HP 219X - High Yield - black - original - LaserJet - toner cartridge | In Stock | £76.76 |
|  | HP 219X - High Yield - cyan - original - LaserJet - toner cartridge | In Stock | £90.40 |
|  | HP 219X - High Yield - magenta - original - LaserJet - toner cartridge | In Stock | £96.41 |
|  | HP 219X - High Yield - yellow - original - LaserJet - toner cartridge | In Stock | £88.30 |
