HP Color LaserJet Enterprise MFP M776dn Multifunction Printer
Quicklinx: HNHBWS00 Mfr#: T3U55A#B19
Type: Printer / copier / scanner
Functionality: Printer, Scanner, Copier
Max Paper Size: A3 (297 x 420 mm)
Hurry, only 2 left in stock!
£3,438.04 ex VAT
£4,125.64 inc VAT
Expect brilliant colour prints from advanced MFPs, equipped with JetIntelligence technology. Offering the world's most secure printing and a wide range of paper handling features, this is printing that helps save time and simplifies workflows.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
HP Color LaserJet Enterprise MFP M776dn - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
200000 pages
Recommended Monthly Volume
40000 pages
Max Copying Speed
Up to 46 ppm (mono) / up to 46 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Scanning
600 x 600 dpi
Display
8"
Original Size
68 x 127 mm (min) - 297 x 864 mm (max)
Original Type
Sheets
Document Feeder Capacity
200 sheets
Media Size
64 x 127 mm (min) - A3 (297 x 420 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, film, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, glossy paper, punched paper, preprinted paper, postcards
Standard Media Capacity
650 sheets
Max Media Capacity
3900 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, HP EveryPage, Instant-on Technology, scan to FTP, scan to SharePoint, scan to OCR, HP Open Extensibility Platform (OXP)
AC 230 V (50/60Hz)
58.5 cm x 66.3 cm x 71 cm
70.9 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Printer Fonts
TrueType x 105 ¦ PostScript 3 x 92
Fax Type
Plain paper
Printing Technology
Laser - colour
200000 pages
40000 pages
Display Diagonal Size
8"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
3 GB
Max Supported Memory
3 GB
Hard Disk Drive
500 GB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
Booklet creation, collation copy, Job Build, Book Copy, watermark, job storage, edge-to-edge, ID Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PDF 1.7, PCL 5
Image Enhancement Technology
HP ImageREt 4800
Automatic Duplexing
First Print Out Time B/W
6.5 sec
First Print Out Time Colour
6.8 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Min Original Size
68 x 127 mm
Max Original Size
297 x 864 mm
Original Type
Sheets
200 sheets
Min Media Size
64 x 127 mm
Max Media Size
A3
Min Media Weight
45 g/m²
Max Media Weight
300 g/m²
Min Media Weight (lb)
12 lbs
Max Media Weight (lb)
80 lbs
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, 100 x 148 mm, JIS B5 (182 x 257 mm), 76 x 127 mm, 215.9 x 355.6 mm, JIS B6 (128 x 182 mm), 102 x 148 mm, RA4 (215 x 305 mm), 215.9 x 297 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
650 sheets
Max Media Capacity
3900 sheets
100 sheets
500 sheets
ADF - 200 sheets weight: 45 g/m² - 200 g/m² , Input tray - 550 sheets size: 148 x 148 mm - 297 x 431.8 mm weight: 60 g/m² - 256 g/m²; weight (lbs): 16 lbs - 68 lbs , Bypass tray - 100 sheets size: 64 x 127 mm - 320 x 457.2 mm weight: 60 g/m² - 300 g/m² , Output tray - 500 sheets
Speed Details
Printing: up to 46 ppm (A4) - B/W (ISO) , Printing: up to 46 ppm (A4) - colour (ISO) , Printing: up to 26 ppm (A3) , Printing: up to 26 ppm (A3) , Copying: up to 46 ppm (A4) , Copying: up to 46 ppm (A4) - B/W , Copying: up to 46 ppm (A4) - B/W duplex , Copying: up to 46 ppm (A4) - colour duplex , Printing: up to 45 ppm (Letter A) - B/W (ISO) , Printing: up to 45 ppm (Letter A) - colour (ISO) , Printing: up to 46 ppm (Letter A) - B/W duplex , Printing: up to 45 ppm (Letter A) - colour duplex , Copying: up to 45 ppm (Letter A) - B/W (ISO) , Copying: up to 45 ppm (Letter A) - colour (ISO) , Copying: up to 45 ppm (Letter A) - B/W duplex , Copying: up to 45 ppm (Letter A) - colour duplex , Printing: up to 26 ppm (Tabloid) - B/W (ISO) , Printing: up to 26 ppm (Tabloid) - colour (ISO) , Copying: up to 26 ppm (Tabloid) - B/W (ISO) , Copying: up to 26 ppm (Tabloid) - colour (ISO)
USB 2.0 host , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x modem - RJ-11
Security Protocols & Features
Kerberos, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
AC 230 V (50/60Hz)
900 watt
Power Consumption Standby
100 watt
Power Consumption Sleep
0.8 watt
FCC Class A certified, UL, cUL, GS, Laser Class 1
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year - on-site - response time: next business day
58.5 cm
66.3 cm
71 cm
70.9 kg
Shipping Width
85.6 cm
Shipping Depth
76 cm
Shipping Height
97.2 cm
Shipping Weight
92.12 kg
Sound Emission
32 dBA (idle) / 52 dBA (operating)
10 °C
32.5 °C
10 - 80%
HNHB HP 660A Original LaserJet Imaging Drum In Stock £200.88
HNHB HP LaserJet Toner Collection Unit In Stock £22.88
HNHB HP 659X Magenta High Yield Toner Cartridge In Stock £497.61
HNHB HP 659A Black Original LaserJet Toner Cartridge In Stock £143.02
HNHB HP 659A Cyan Original LaserJet Toner Cartridge In Stock £322.64
HNHB HP 659A Yellow Original LaserJet Toner Cartridge In Stock £322.64
HNHB HP 659A Magenta Original LaserJet Toner Cartridge In Stock £322.64
Functionality: Scanner
Functionality: Copier
Brand: HP
Price Range Ex VAT: £1500+
