Expect brilliant colour prints from advanced MFPs, equipped with JetIntelligence technology. Offering the world's most secure printing and a wide range of paper handling features, this is printing that helps save time and simplifies workflows.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
- HP Color LaserJet Enterprise MFP M776dn - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 200000 pages
- Recommended Monthly Volume
- 40000 pages
- Max Copying Speed
- Up to 46 ppm (mono) / up to 46 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 8"
- Original Size
- 68 x 127 mm (min) - 297 x 864 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 200 sheets
- Media Size
- 64 x 127 mm (min) - A3 (297 x 420 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, film, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, glossy paper, punched paper, preprinted paper, postcards
- Standard Media Capacity
- 650 sheets
- Max Media Capacity
- 3900 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, HP EveryPage, Instant-on Technology, scan to FTP, scan to SharePoint, scan to OCR, HP Open Extensibility Platform (OXP)
- Power
- AC 230 V (50/60Hz)
- 58.5 cm x 66.3 cm x 71 cm
- 70.9 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Printer Fonts
- TrueType x 105 ¦ PostScript 3 x 92
- Fax Type
- Plain paper
- Laser - colour
- 200000 pages
- 40000 pages
- Display Diagonal Size
- 8"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 3 GB
- Max Supported Memory
- 3 GB
- Hard Disk Drive
- 500 GB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- Booklet creation, collation copy, Job Build, Book Copy, watermark, job storage, edge-to-edge, ID Copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PDF 1.7, PCL 5
- Image Enhancement Technology
- HP ImageREt 4800
- First Print Out Time B/W
- 6.5 sec
- First Print Out Time Colour
- 6.8 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Min Original Size
- 68 x 127 mm
- Max Original Size
- 297 x 864 mm
- Original Type
- Sheets
- 200 sheets
- Min Media Size
- 64 x 127 mm
- Max Media Size
- A3
- Min Media Weight
- 45 g/m²
- Max Media Weight
- 300 g/m²
- Min Media Weight (lb)
- 12 lbs
- Max Media Weight (lb)
- 80 lbs
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, 100 x 148 mm, JIS B5 (182 x 257 mm), 76 x 127 mm, 215.9 x 355.6 mm, JIS B6 (128 x 182 mm), 102 x 148 mm, RA4 (215 x 305 mm), 215.9 x 297 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 650 sheets
- 3900 sheets
- 100 sheets
- 500 sheets
- ADF - 200 sheets weight: 45 g/m² - 200 g/m² , Input tray - 550 sheets size: 148 x 148 mm - 297 x 431.8 mm weight: 60 g/m² - 256 g/m²; weight (lbs): 16 lbs - 68 lbs , Bypass tray - 100 sheets size: 64 x 127 mm - 320 x 457.2 mm weight: 60 g/m² - 300 g/m² , Output tray - 500 sheets
- Speed Details
- Printing: up to 46 ppm (A4) - B/W (ISO) , Printing: up to 46 ppm (A4) - colour (ISO) , Printing: up to 26 ppm (A3) , Printing: up to 26 ppm (A3) , Copying: up to 46 ppm (A4) , Copying: up to 46 ppm (A4) - B/W , Copying: up to 46 ppm (A4) - B/W duplex , Copying: up to 46 ppm (A4) - colour duplex , Printing: up to 45 ppm (Letter A) - B/W (ISO) , Printing: up to 45 ppm (Letter A) - colour (ISO) , Printing: up to 46 ppm (Letter A) - B/W duplex , Printing: up to 45 ppm (Letter A) - colour duplex , Copying: up to 45 ppm (Letter A) - B/W (ISO) , Copying: up to 45 ppm (Letter A) - colour (ISO) , Copying: up to 45 ppm (Letter A) - B/W duplex , Copying: up to 45 ppm (Letter A) - colour duplex , Printing: up to 26 ppm (Tabloid) - B/W (ISO) , Printing: up to 26 ppm (Tabloid) - colour (ISO) , Copying: up to 26 ppm (Tabloid) - B/W (ISO) , Copying: up to 26 ppm (Tabloid) - colour (ISO)
- USB 2.0 host , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x modem - RJ-11
- Kerberos, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
- Voltage Required
- 900 watt
- Power Consumption Standby
- 100 watt
- Power Consumption Sleep
- 0.8 watt
- FCC Class A certified, UL, cUL, GS, Laser Class 1
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year - on-site - response time: next business day
- 58.5 cm
- 66.3 cm
- 71 cm
- 70.9 kg
- Shipping Width
- 85.6 cm
- Shipping Depth
- 76 cm
- Shipping Height
- 97.2 cm
- Shipping Weight
- 92.12 kg
- Sound Emission
- 32 dBA (idle) / 52 dBA (operating)
- 10 °C
- 32.5 °C
- 10 - 80%
Ink (6)
HP 660A Original LaserJet Imaging Drum | In Stock | £200.88 |
HP LaserJet Toner Collection Unit | In Stock | £22.88 |
HP 659A Black Original LaserJet Toner Cartridge | In Stock | £143.02 |
HP 659A Cyan Original LaserJet Toner Cartridge | In Stock | £322.64 |
HP 659A Yellow Original LaserJet Toner Cartridge | In Stock | £322.64 |
HP 659A Magenta Original LaserJet Toner Cartridge | In Stock | £322.64 |
Other bundles (1)
HP Paper Tray and Stand - media tray - 1100 sheets | In Stock | £711.23 |
