HP Color LaserJet Enterprise MFP M480f
Quicklinx: GCXJWS00 Mfr#: 3QA55A#B19
Functionality: Scanner, Fax, Copier, Printer
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Laser
14 In Stock
£609.89 ex VAT
£731.86 inc VAT
HP's entry-level Enterprise-class Color MFP with speeds up to 28 ppm and strongest security.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
HP Color LaserJet Enterprise MFP M480f - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
55000 pages
Recommended Monthly Volume
900 - 4800 pages
Max Copying Speed
Up to 27 ppm (mono) / up to 27 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 203 x 392 dpi
Scanning
600 x 600 dpi
Display
4.3"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, photo paper, bond paper, glossy paper, preprinted paper, postcards, coloured paper, letterheaded paper, prepunched paper
Standard Media Capacity
300 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Office Machine Features
Save to USB flash drive, scan to e-mail, save to network folder, Instant-on Technology, HP Auto-On/Auto-Off Technology, security lock slot, Instant-on Copy, print from mobile devices, scan to PDF
AC 230 V
41.54 cm x 47.2 cm x 39.98 cm
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
55000 pages
900 - 4800 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
AirPrint Enabled
Hard Disk Drive
16 GB
Supported Flash Memory
MultiMediaCard
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
Collation copy, Edge Erase, blank page skipping, Book Copy, watermark, PDF encryption, preview, job storage, edge-to-edge, ID Copy, image adjustment
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PDF 1.7, PCL 5
Image Enhancement Technology
HP ImageREt 3600
Automatic Duplexing
First Print Out Time B/W
9.5 sec
First Print Out Time Colour
11 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
PC Faxing
Fax Machine Features
Speed Dialing
1000 station(s)
Fax forwarding, automatic redialing, LAN fax, auto reduction, fax archiving, confirmation report, Internet fax
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 197 x 273 mm, 76 x 127 mm, 99 x 148 mm, Oficio (216 x 343 mm), JIS B6 (128 x 182 mm), RA4 (215 x 305 mm), 195 x 270 mm, 184 x 260 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
300 sheets
150 sheets
ADF - 50 sheets , Input tray - 250 sheets - Legal (216 x 356 mm) , Multi-purpose tray - 50 sheets , Output tray - 150 sheets
Speed Details
Scanning: up to 29 ppm (A4) - B/W normal , Scanning: up to 20 ppm (A4) - colour normal , Printing: up to 7 ppm (A5) - B/W portrait , Printing: up to 29 ppm (Letter A) - colour (ISO) , Printing: up to 27 ppm (A4) - B/W (ISO) , Printing: up to 49 ppm (A5) - B/W landscape , Printing: up to 27 ppm (A4) - colour (ISO) , Printing: up to 25 ipm (Letter A) - duplex normal , Copying: up to 27 ppm (A4) - B/W normal , Copying: up to 28 ppm (Letter A) - B/W normal , Copying: up to 25 ppm (Letter A) - B/W duplex , Copying: up to 24 ppm (A4) - B/W duplex , Printing: up to 29 ppm (Letter A) - B/W (ISO) , Copying: up to 27 ppm (A4) - colour normal , Copying: up to 28 ppm (Letter A) - colour normal
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x modem - RJ-11
Security Protocols & Features
LDAP, SSL, TLS, IPsec, 802.1x, EAP-TLS, SNMP 3, EAP-PEAP
Software Included
Drivers & Utilities
AC 230 V
581 Watt
Power Consumption Standby
21.9 Watt
Power Consumption Sleep
1 Watt
First Copy Out Time B/W
9.6 sec
First Copy Out Time Colour
11.3 sec
FCC Class A certified, UL, TUV GS, BSMI, cUL, GS, CCC, EMC, PSB, FCC CFR47 Part 68, CECP, EN 62479:2010, RCM, ISO/IEC 19798, BIS, EN 61000-3-3:2013, CoC, CISPR 22:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, FCC CFR47 Part 15 A, LVD 2014/35/EU, EN 55024:2010+A1:2015, EN 55032:2012, ICES-003 issue 6 Class A, ES 203 021-3 V2.1.2, ES 203 021-1 V2.1.1, ES 203 021-2 V2.1.2, CISPR 32:2012, EN 60825-1:2014, EN 55035:2017, CFR 1040.10, CFR 1040.11, Mercury-free, IEC 60825-1:2014 Class 1, CISPR 35: 2016
Security Slot Type
Kensington security slot
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - 1 year - on-site , Technical support - phone consulting - 1 year
41.54 cm
47.2 cm
39.98 cm
Shipping Width
59.7 cm
Shipping Depth
49.7 cm
Shipping Height
49 cm
Shipping Weight
26.34 kg
Sound Emission
20 dBA (idle) / 49 dBA (operating)
15 °C
32.5 °C
10 - 90%
Ink (9)
GCXJ HP 415A Black Original LaserJet Toner Cartridge In Stock £72.99
GCXJ HP 415A Cyan Original LaserJet Toner Cartridge In Stock £93.06
GCXJ HP 415A Yellow Original LaserJet Toner Cartridge In Stock £93.06
GCXJ HP 415A Magenta Original LaserJet Toner Cartridge In Stock £93.06
GCXJ HP 415X High Yield Black Original LaserJet Toner Cartridge In Stock £146.92
GCXJ HP 415X High Yield Cyan Original LaserJet Toner Cartridge In Stock £200.74
GCXJ HP 415X High Yield Yellow Original LaserJet Toner Cartridge In Stock £200.74
GCXJ HP 415X High Yield Magenta Original LaserJet Toner Cartridge In Stock £200.74
GCXJ HP Glossy Laser Paper 150GSM 150 SHT/A4 In Stock £15.52
Other bundles (1)
GCXJ HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 3 years - on-site In Stock £208.31
Functionality: Fax
Functionality: Copier
Functionality: Printer
Output Type: Colour
Wireless Capability: Wireless
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
Price Range Ex VAT: £500 - £750
