HP's entry-level Enterprise-class Color MFP with speeds up to 28 ppm and strongest security.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
- HP Color LaserJet Enterprise MFP M480f - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 55000 pages
- Recommended Monthly Volume
- 900 - 4800 pages
- Max Copying Speed
- Up to 27 ppm (mono) / up to 27 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 203 x 392 dpi
- Scanning
- 600 x 600 dpi
- Display
- 4.3"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, photo paper, bond paper, glossy paper, preprinted paper, postcards, coloured paper, letterheaded paper, prepunched paper
- Standard Media Capacity
- 300 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, scan to e-mail, save to network folder, Instant-on Technology, HP Auto-On/Auto-Off Technology, security lock slot, Instant-on Copy, print from mobile devices, scan to PDF
- Power
- AC 230 V
- 41.54 cm x 47.2 cm x 39.98 cm
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Laser - colour
- 55000 pages
- 900 - 4800 pages
- Display Diagonal Size
- 4.3"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Hard Disk Drive
- 16 GB
- Supported Flash Memory
- MultiMediaCard
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- Collation copy, Edge Erase, blank page skipping, Book Copy, watermark, PDF encryption, preview, job storage, edge-to-edge, ID Copy, image adjustment
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PDF 1.7, PCL 5
- Image Enhancement Technology
- HP ImageREt 3600
- First Print Out Time B/W
- 9.5 sec
- First Print Out Time Colour
- 11 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 600 dpi
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- PC Faxing
Fax Machine Features
- Speed Dialing
- 1000 station(s)
- Fax forwarding, automatic redialing, LAN fax, auto reduction, fax archiving, confirmation report, Internet fax
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 197 x 273 mm, 76 x 127 mm, 99 x 148 mm, Oficio (216 x 343 mm), JIS B6 (128 x 182 mm), RA4 (215 x 305 mm), 195 x 270 mm, 184 x 260 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 300 sheets
- 150 sheets
- ADF - 50 sheets , Input tray - 250 sheets - Legal (216 x 356 mm) , Multi-purpose tray - 50 sheets , Output tray - 150 sheets
- Speed Details
- Scanning: up to 29 ppm (A4) - B/W normal , Scanning: up to 20 ppm (A4) - colour normal , Printing: up to 7 ppm (A5) - B/W portrait , Printing: up to 29 ppm (Letter A) - colour (ISO) , Printing: up to 27 ppm (A4) - B/W (ISO) , Printing: up to 49 ppm (A5) - B/W landscape , Printing: up to 27 ppm (A4) - colour (ISO) , Printing: up to 25 ipm (Letter A) - duplex normal , Copying: up to 27 ppm (A4) - B/W normal , Copying: up to 28 ppm (Letter A) - B/W normal , Copying: up to 25 ppm (Letter A) - B/W duplex , Copying: up to 24 ppm (A4) - B/W duplex , Printing: up to 29 ppm (Letter A) - B/W (ISO) , Copying: up to 27 ppm (A4) - colour normal , Copying: up to 28 ppm (Letter A) - colour normal
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x modem - RJ-11
- LDAP, SSL, TLS, IPsec, 802.1x, EAP-TLS, SNMP 3, EAP-PEAP
- Software Included
- Drivers & Utilities
- Voltage Required
- AC 230 V
- 581 Watt
- Power Consumption Standby
- 21.9 Watt
- Power Consumption Sleep
- 1 Watt
- First Copy Out Time B/W
- 9.6 sec
- First Copy Out Time Colour
- 11.3 sec
- FCC Class A certified, UL, TUV GS, BSMI, cUL, GS, CCC, EMC, PSB, FCC CFR47 Part 68, CECP, EN 62479:2010, RCM, ISO/IEC 19798, BIS, EN 61000-3-3:2013, CoC, CISPR 22:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, FCC CFR47 Part 15 A, LVD 2014/35/EU, EN 55024:2010+A1:2015, EN 55032:2012, ICES-003 issue 6 Class A, ES 203 021-3 V2.1.2, ES 203 021-1 V2.1.1, ES 203 021-2 V2.1.2, CISPR 32:2012, EN 60825-1:2014, EN 55035:2017, CFR 1040.10, CFR 1040.11, Mercury-free, IEC 60825-1:2014 Class 1, CISPR 35: 2016
- Security Slot Type
- Kensington security slot
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site , Technical support - phone consulting - 1 year
- 41.54 cm
- 47.2 cm
- 39.98 cm
- Shipping Width
- 59.7 cm
- Shipping Depth
- 49.7 cm
- Shipping Height
- 49 cm
- Shipping Weight
- 26.34 kg
- Sound Emission
- 20 dBA (idle) / 49 dBA (operating)
- 15 °C
- 32.5 °C
- 10 - 90%
Ink (8)
HP 415A Black Original LaserJet Toner Cartridge | In Stock | £72.02 |
HP 415A Cyan Original LaserJet Toner Cartridge | In Stock | £95.66 |
HP 415A Yellow Original LaserJet Toner Cartridge | In Stock | £93.12 |
HP 415A Magenta Original LaserJet Toner Cartridge | In Stock | £93.12 |
HP 415X High Yield Black Original LaserJet Toner Cartridge | In Stock | £147.02 |
HP 415X High Yield Cyan Original LaserJet Toner Cartridge | In Stock | £201.04 |
HP 415X High Yield Yellow Original LaserJet Toner Cartridge | In Stock | £201.04 |
HP 415X High Yield Magenta Original LaserJet Toner Cartridge | In Stock | £201.04 |
Other bundles (2)
HP Foreign Interface Harness (FIH) | In Stock | £77.37 |
HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 3 years - on-site | In Stock | £208.31 |
