HP LaserJet printers power office productivity with a smart, streamlined design that's reliable and hassle-free. Count on premium quality, maximum uptime, and the strongest security – all intended to drive successful organizations forward.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
Professional color printing
Print premium, professional-quality documents with vivid color images and graphics. This printer features a special print mode for a wider color range, an extra level of vividness for documents and marketing materials. Look professional on every page with vibrant, high-quality color prints that stand the test of time. -
Minimal interruptions and maximum productivity
Avoid interruptions with this HP LaserJet printer designed for maximum productivity. It wakes up quickly and prints fast - up to 40 ppm. Change the toner and drum in seconds. Both are easily accessible and come already installed out of the box. -
Secure printing
Each printer in your fleet checks its operating code and repairs itself from attacks. Your printer's outgoing network connections are inspected to stop suspicious requests and thwart malware. Memory activity is monitored to continually detect and stop attacks.
- HP Color LaserJet Enterprise M751dn - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 45.1 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A3/Ledger
- Max Media Size
- 320 x 457.2 mm
- Min Media Size (Custom)
- 64 mm x 127 mm
- Max Media Size (Custom)
- 320 mm x 457.2 mm
- Print Speed
- Up to 41 ppm - black normal - A4 (210 x 297 mm) , Up to 41 ppm - colour normal - A4 (210 x 297 mm) , Up to 41 ppm - black normal - ANSI A (Letter) (216 x 279 mm) , Up to 41 ppm - colour normal - ANSI A (Letter) (216 x 279 mm) , Up to 26 ppm - B/W - A3 (297 x 420 mm) , Up to 26 ppm - colour - A3 (297 x 420 mm) , Up to 41 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 18 ppm - colour duplex - A3 (297 x 420 mm) , Up to 18 ppm - duplex - Tabloid (279 x 432 mm) , Up to 26 ppm - black normal - Tabloid (279 x 432 mm) , Up to 26 ppm - colour normal - Tabloid (279 x 432 mm)
- Max Resolution (B&W)
- 600 x 600 dpi
- Max Resolution (Colour)
- 600 x 600 dpi
- Image Enhancement Technology
- HP ImageREt 4800
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host (internal), USB 2.0 host
- AirPrint Enabled
- Preview Screen Size
- 2.7"
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 1.5 GB (2 GB) - DDR3 SDRAM - SO-DIMM 144-pin
- Language Simulation
- PCL 5, PostScript 3, PCL 6, PDF 1.4
- Media Type
- Envelopes, transparencies, labels, plain paper, recycled paper, card stock, extra heavy-weight paper, light-weight paper, glossy paper
- Total Media Capacity
- 650 sheets
- Media Handling
- 100-sheet multipurpose tray, 550-sheet input tray
- Monthly Duty Cycle (max)
- 150000 pages
- Recommended Monthly Volume
- 40000 pages
- Networking
- Print server
- Printer Features
- Hardware integration pocket, Hard Disk Drive Encryption, Instant-on Technology, Auto Power On, Auto Power Off
- System Requirements
- SunSoft Solaris 2.5 or later, IBM AIX 3.2.5 or later, HP MPE/iX, HP-UX 11i, Novell NetWare 6, Novell NetWare 6.5, Microsoft Windows XP 64-bit Edition SP2 or later, Microsoft Windows XP SP2 or later, Novell Open Enterprise Server, Citrix Presentation Server 4.5, Apple MacOS X 10.5, Citrix Presentation Server 4.0, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2003 R2 (32/64-bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2003 (32/64-bits) SP2, Microsoft Windows Server 2003 (32/64-bits) SP1, Microsoft Windows Server 2008 (32/64-bits) SP1, Microsoft Windows Server 2008 (32/64-bits) SP2, Citrix XenServer 5.6, Apple MacOS X 10.6.8, Citrix XenApp 6, Red Hat Linux 7.x or later, SuSE Linux 8.x or later, Citrix XenDesktop 5.5, Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Apple MacOS X 10.8.x, Windows 8 Pro (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.7.5, Apple MacOS X 10.9.x
- Environmental Standards
- EPEAT Silver
- 1-year warranty
- 55.6 cm x 58.9 cm x 39.9 cm
- Printer Type
- Localisation
Printer
- Print Speed
- Built-in Devices
- Numeric key pad, LCD display
- 2.7"
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 600 x 600 dpi
- 600 x 600 dpi
- HP ImageREt 4800
- PostScript Support
- Included
- First Print Out Time B/W
- 5.7 sec
- First Print Out Time Colour
- 6.1 sec
- Fonts Included
- 105 x TrueType , 92 x scalable PostScript
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 1.5 GB / 2 GB (max)
- Technology / Form Factor
- Slots Qty
- 1
Media Handling
- Media Type
- Media Size Class
- A3/Ledger
- Max Media Size
- 320 x 457.2 mm
- 64 mm x 127 mm
- 320 mm x 457.2 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ARCH B (304.8 x 457.2 mm), 297 x 432 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA3 (320 x 450 mm), SRA4 (225 x 320 mm), 101.6 x 152.4 mm, 197 x 273 mm, 76 x 127 mm, 76.2 x 127 mm, RA3 (305 x 430 mm), 127 x 177.8 mm, 279.4 x 431.8 mm, 215.9 x 330.2 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm), 270 x 390 mm, 260 x 368 mm, 273 x 394 mm, 195 x 270 mm, 184 x 260 mm, 148 x 211 mm
- Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- Media Weight
- 60 g/m² - 300 g/m²
- 650 sheets
- Media Feeders
- Input tray: 1 x automatic - 100 sheets - 320 x 457.2 mm weight: 60 g/m² - 300 g/m² , Input tray: 1 x automatic - 550 sheets - 297 x 431.8 mm weight: 60 g/m² - 256 g/m² , Output tray: 1 x automatic - 250 sheets - 320 x 457.2 mm weight: 60 g/m² - 256 g/m²
- Max Media Capacity
- 4450 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 150000 pages
- 40000 pages
- Networking
- Print server
- Network Controller Name
- HP Jetdirect
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS, ICMP, DHCP, IPv4, IPv6
- Kerberos, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP, WPA2-Enterprise
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x USB host (internal) - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
- Security lock slot (cable lock sold separately), SNMP support
- GS, FIPS 140-2, EN 62479:2010, EN 61000-3-3:2013, EN 55024:2010, CISPR 22:2008, EMC 2014/30/EU, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, LVD 2014/35/EU, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011 + A2:2013, ICES-003 issue 6 Class A, CISPR 32:2012 Class A, EN 55032:2012 Class A, EN 60825-1:2014, IEC 60825-1:2014
- Security Slot Type
- Kensington security slot
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 870 Watt
- Power Consumption Stand by
- 48 Watt
- Power Consumption Sleep
- 0.6 Watt
- Software Included
- Drivers & Utilities, HP Web JetAdmin, HP Printer Assistant, HP Device Toolbox
- OS Required
- System Requirements Details
- Windows XP/Vista/7/8/2003/2008/2012 - HD 2 GB , MacOS X 10.6.8/10.7.5/10.8 - HD 2 GB
- EPEAT Compliant
- EPEAT Silver
- Blue Angel
- ENERGY STAR
- Limited warranty - 1 year - on-site - response time: next business day
- 10 °C
- 32.5 °C
- 30 - 70%
- Sound Emission (Operating)
- 51 dBA
- 55.6 cm
- 58.9 cm
- 39.9 cm
- 45.1 kg
- Width (Shipping)
- 78.6 cm
- Depth (Shipping)
- 73.6 cm
- Height (Shipping)
- 55.8 cm
- Weight (Shipping)
- 52.9 kg
Ink (13)
HP 658A Black Original LaserJet Toner Cartridge | In Stock | £134.32 |
HP 658A Cyan Original LaserJet Toner Cartridge | In Stock | £204.31 |
HP 658A Yellow Original LaserJet Toner Cartridge | In Stock | £204.31 |
HP 658A Magenta Original LaserJet Toner Cartridge | In Stock | £204.31 |
HP 658X High Yield Black Original LaserJet Toner Cartridge | In Stock | £359.81 |
HP 658X High Yield Cyan Original LaserJet Toner Cartridge | In Stock | £629.12 |
HP 658X High Yield Yellow Original LaserJet Toner Cartridge | In Stock | £629.67 |
HP 658X High Yield Magenta Original LaserJet Toner Cartridge | In Stock | £629.67 |
HP 660A Original LaserJet Imaging Drum | In Stock | £194.00 |
HP LaserJet 220V Fuser Kit | In Stock | £299.92 |
HP LaserJet Intermediate Transfer Belt Kit | In Stock | £321.63 |
HP LaserJet Toner Collection Unit | In Stock | £20.80 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £15.56 |
Other bundles (2)
HP Paper Tray and Stand - media tray - 1100 sheets | In Stock | £711.23 |
HP media tray - 550 sheets | In Stock | £332.81 |
