HP Color LaserJet Enterprise M652dn Printer Colour
Quicklinx: D81DWS00 Mfr#: J7Z99A#B19
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
This HP Colour LaserJet Printer with JetIntelligence combines exceptional performance and energy efficiency with professional-quality documents right when you need them – all while protecting your network with the industry's deepest security.
  • The world's most secure printing
    With HP Sure Start, each printer regularly checks its operating code and repairs itself from attempted hacks.Whitelisting checks firmware during startup to help ensure it's authentic, good code – digitally signed by HP.Run-time intrusion detection continually monitors activity to detect and stop attacks, then automatically reboots.Centralise control of your printing environment with HP Web Jetadmin – and help build business efficiency.
  • High speed performance meets energy efficiency
    Speed through tasks and save paper. Print two-sided documents at up to 47 images per minute, with 100% duplex efficiency.This printer wakes up fast and prints your first page faster – in a as quickly as 8.4 seconds.This printer uses exceptionally low amounts of energy thanks to its innovative design and toner technology.Paper handling options include a wheeled stand and 550-sheet input feeder for paper sizes 10.16 x 15.24 cm (4 x 6") to legal.
  • More Pages, Performance, and Protection
    ColorSphere3 toner formulation, combined with an automatic media sensor, help provide leading print quality.Original HP Toner cartridges with JetIntelligence supply 2x more colour pages per cartridge vs. predecessor.Help retain the Original HP quality you paid for with anti-fraud and cartridge authentication technology.Spend less time replacing toner, and more on business. Choose high-yield toner cartridges.
HP Color LaserJet Enterprise M652dn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
31.2 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 47 ppm - black normal - A4 (210 x 297 mm) , Up to 47 ppm - colour normal - A4 (210 x 297 mm) , Up to 74 ppm - B/W - A5 (148 x 210 mm) , Up to 74 ppm - colour - A5 (148 x 210 mm) , Up to 47 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 47 ipm - colour duplex - A4 (210 x 297 mm) , Up to 50 ppm - ANSI A (Letter) (216 x 279 mm) , Up to 50 ppm - duplex - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
1200 x 1200 dpi
Image Enhancement Technology
HP ImageRet 3600 / HP ProRes 1200
Automatic Duplexing
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Preview Screen Size
2.7"
1.2 GHz
RAM Installed (Max)
1 GB (2 GB) - DDR3 SDRAM - DIMM 144-pin
Flash Memory Installed (Max)
8 GB
Language Simulation
PCL 5C, PostScript 3, PCL 6, PDF 1.7, URF
Media Type
Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, opaque film, paper, middle thick paper, card stock, extra heavy-weight paper, light-weight paper, soft gloss paper, preprinted paper, postcards, glossy paper
Total Media Capacity
650 sheets
Media Handling
100-sheet multipurpose tray, 550-sheet input tray
Recommended Monthly Volume
2000 - 14000 pages
Print server
Printer Features
Hardware integration pocket, Instant-on Technology, Auto Power On, Auto Power Off
UNIX, Microsoft Windows Vista (32-bit versions), Citrix MetaFrame XP Presentation Server, Citrix MetaFrame Presentation Server 3.0, Android, Red Hat Enterprise Linux 6, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3, Microsoft Windows Server 2008 (32/64-bits) SP2, Microsoft Windows Server 2003 R2 (32/64-bits) SP1, Citrix XenApp 6.0 64-bit, Citrix XenApp 6, Citrix XenApp 5 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits), Citrix XenApp 6.5 64-bit, Citrix XenApp 6.5, Windows 8.1 (32/64 bits), Novell Open Enterprise Server 11 SP1, Ubuntu Linux 12.04, Red Hat Enterprise Linux 7, Apple MacOS X 10.10, Citrix XenDesktop 5.6, Windows 10 (32/64 bits), Linux Mint 17, BOSS GNU/Linux 5.0, Debian Linux 7.x, Novell NetWare 6.5 SP8, Ubuntu Linux 14.04, Apple MacOS X 10.11, Microsoft Windows Server 2012 R2 (32/64 bits), Citrix XenApp 7.5, Citrix XenDesktop 7, Debian Linux 8.x, Linux Mint 17.1, Linux Fedora, Apple macOS Sierra 10.12 or later, Linux Mint 17.2, Linux Mint 17.3, Microsoft Windows Server 2003 R2 (32/64-bits) SP2, SUSE Linux 13.2, Ubuntu Linux 16, Linux Mint 18, Citrix XenDesktop 7.5
1-year warranty
51 cm x 45.8 cm x 48.2 cm
Printer Type
Printer
Print Speed
Built-in Devices
Numeric key pad, 2.7 inch QVGA LCD display
Preview Screen Size
2.7"
Wired
AirPrint Enabled
1200 x 1200 dpi
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
Language Simulation
Fonts Included
105 x TrueType , 92 x PostScript 3
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
1 GB / 2 GB (max)
Technology / Form Factor
Slots Qty
1
Flash Memory
Flash Memory
8 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 76 x 127 mm, 76.2 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, RA4 (215 x 305 mm), 101.6 x 148 mm
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
Media Weight
60 g/m² - 220 g/m²
650 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Max Media Capacity
3200 sheets
Output Trays Capacity
500 sheets
Duty Cycle
2000 - 14000 pages
Print server
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, IPP, HTTP, HTTPS, TFTP, IPPS, SLP
Security Protocols & Features
Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) - up to 12500 pages , 1 x toner cartridge (cyan) - up to 10500 pages , 1 x toner cartridge (magenta) - up to 10500 pages , 1 x toner cartridge (yellow) - up to 10500 pages
UL, CISPR 22 Class A, cUL, GS, CECP, EN 62479:2010, EN 61000-3-3:2013, EN 55024:2010, EMC 2014/30/EU, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, FCC CFR47 Part 15 A, ICES-003 issue 6 Class A, CISPR 32:2012 Class A, EN 55032:2012 Class A, IEC/EN60950-1:2006 +A11:2009 +A1:2010 +A12:2011 +A2:2013, IEC/EN 60825-1:2014 Class 1
Security Slot Type
Kensington security slot
Power supply - internal
Frequency Required
50/60 Hz
690 watt
Power Consumption Stand by
31 watt
Power Consumption Sleep
0.7 watt
Software Included
Drivers & Utilities, HP Device Experience (DXP), HP Connected
System Requirements Details
Windows XP/Vista/7/8/8.1/10 - HD 2 GB , MacOS X 10.0 or later - HD 1.3 GB
Environmental Standards
Blue Angel
ENERGY STAR
Limited warranty - 1 year - on-site - response time: next business day
15 °C
30 °C
10 - 80%
Sound Emission (Operating)
53 dBA
51 cm
45.8 cm
48.2 cm
31.2 kg
Width (Shipping)
65.3 cm
Depth (Shipping)
59.6 cm
Height (Shipping)
57.8 cm
Weight (Shipping)
35.9 kg
Ink (6)
D81D HP Laserjet Toner Collection Unit In Stock £29.18
D81D HP 656X High Yield Black Original LaserJet Toner Cartridge In Stock £290.31
D81D HP 656X High Yield Cyan Original LaserJet Toner Cartridge In Stock £409.66
D81D HP 656X High Yield Yellow Original LaserJet Toner Cartridge In Stock £409.66
D81D HP 656X High Yield Magenta Original LaserJet Toner Cartridge In Stock £409.66
D81D HP Glossy Laser Paper 150GSM 150 SHT/A4 In Stock £16.54
Other bundles (2)
D81D HP Colour LaserJet CE247A 220V Fuser Kit In Stock £232.26
D81D HP 655A Black Original LaserJet Toner Cartridge In Stock £192.55
