Fast performance meets energy efficiency
Print from sleep mode in as fast as 9 seconds. Get two-sided prints as quickly as one – up to 35 ipm.This printer uses exceptionally low amounts of energy – thanks to smart media sensing and toner technology.Manage jobs and settings quickly with the 4-line colour display and use the 10-key pad for PIN printing.Consistently print high-quality documents across a variety of media – including A5 – with automatic media sensing. -
Your fleet – simple, protected, streamlined
Centralise control of your print environment with HP Web Jetadmin – and help build business efficiency.Protect sensitive business data with embedded and optional HP JetAdvantage Security Solutions.Give your team what they need to succeed. Easily develop, deploy and add on HP and third-party solutions.Further safeguard data stored on the printer, using the optional HP Trusted Platform Module. -
Print whenever business demands
Easily print from a variety of smartphones and tablets – generally no setup or apps required. -
More
Original HP Toner cartridges with JetIntelligence deliver more pages per cartridge than predecessors.Count on professional quality at fast speeds – HP ColorSphere 3 toner works best with your HP printer.Help ensure the authentic HP quality you paid for with anti-fraud and cartridge authentication technology.Print right away with preinstalled cartridges. Replace them with optional high-yield cartridges.
- HP Color LaserJet Enterprise M552dn - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 27.5 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 33 ppm - B/W - A4 (210 x 297 mm) , Up to 35 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 33 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 35 ipm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 33 ppm - colour - A4 (210 x 297 mm) , Up to 35 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 33 ipm - colour duplex - A4 (210 x 297 mm) , Up to 35 ipm - colour duplex - ANSI A (Letter) (216 x 279 mm) , Up to 55 ppm - B/W - A5 (148 x 210 mm) , Up to 55 ppm - colour - A5 (148 x 210 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Image Enhancement Technology
- HP ImageREt 3600
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 1 GB
- Flash Memory Installed (Max)
- 4 GB
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PDF 1.7
- Media Type
- Envelopes, transparencies, labels, plain paper, heavy-weight paper, heavy-weight glossy paper, bond paper, recycled paper, opaque film, card stock, extra heavy-weight paper, light-weight paper, punched paper, preprinted paper
- Total Media Capacity
- 650 sheets
- Media Handling
- 100-sheet multipurpose tray, 550-sheet input tray
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 2000 - 6000 pages
- Networking
- Print server
- Printer Features
- Hardware integration pocket, Instant-on Technology
- System Requirements
- UNIX, Android, Microsoft Windows Vista (32/64 bits), Ubuntu 10.04, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Apple MacOS X Lion 10.7, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), openSUSE 12.2, Red Hat Fedora 17, Ubuntu 12.10, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Red Hat Fedora 18, openSUSE 12.3, Linux Mint 13, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, openSUSE 13.1, Windows 10 (32/64 bits), Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x
- 1-year warranty
- 45.8 cm x 47.9 cm x 39.9 cm
- Printer Type
- Localisation
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- HP ImageREt 3600
- PostScript Support
- Standard
- First Print Out Time B/W
- 6 sec
- First Print Out Time Colour
- 7 sec
- Fonts Included
- 105 x TrueType , 92 x PostScript 3
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 1 GB
Flash Memory
- Flash Memory
- 4 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), 102 x 148 mm, RA4 (215 x 305 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 650 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 550 sheets - 216 x 297 mm weight: 60 g/m² - 220 g/m²
- Max Media Capacity
- 1200 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 80000 pages
- 2000 - 6000 pages
- Networking
- Print server
- Network Controller Name
- HP Jetdirect
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, NDS, HTTPS, TFTP, IPPS, SLP
- Kerberos, LDAP, Apple Bonjour, IPsec, 802.1x, EAP-TLS, PEAP
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 5000 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 5000 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 5000 pages ISO/IEC 19798
- FCC Class A certified, CISPR 22 Class A, Laser Class 1, FCC CFR47 Part 15, IEC 60825-1, EN 60825-1, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 60950-1:2006, EN 62479:2010, IEC 60950-1:2005, EN 55024:2010, EN 55022:2010 Class A, ICES-003 issue 5 Class A
- Power Device
- Power supply - internal
- Frequency Required
- 50 Hz
- 569 watt
- Power Consumption Stand by
- 33.6 watt
- Power Consumption Sleep
- 3.95 watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- - 1 year - on-site
- 15 °C
- 30 °C
- 10 - 80%
- Sound Emission (Idle)
- 32 dBA
- Sound Emission (Operating)
- 51 dBA
- 45.8 cm
- 47.9 cm
- 39.9 cm
- 27.5 kg
- Width (Shipping)
- 60 cm
- Depth (Shipping)
- 59.8 cm
- Height (Shipping)
- 50 cm
- Weight (Shipping)
- 31.3 kg
Ink (10)
HP 508A Black Original Toner Cartridge | In Stock | £145.23 |
HP 508A Cyan Original Toner Cartridge | In Stock | £182.09 |
HP 508A Yellow Original Toner Cartridge | In Stock | £182.09 |
HP 508A Magenta Original Toner Cartridge | In Stock | £182.58 |
HP 508X High Yield Black Original Toner Cartridge | In Stock | £203.02 |
HP 508X High Yield Cyan Original Toner Cartridge | In Stock | £281.07 |
HP 508X High Yield Yellow Original Toner Cartridge | In Stock | £281.07 |
HP 508X High Yield Magenta Original Toner Cartridge | In Stock | £281.07 |
HP M522 Laserjet Toner Collection Unit | In Stock | £19.68 |
HP M522 220V Fuser Unit | In Stock | £212.99 |
