HP's entry-level Enterprise-class color printer with speeds up to 28 ppm and strongest security.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
- HP Color LaserJet Enterprise M455dn - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- Number of Users
- 3-10 users
- 18.9 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 29 ppm - B/W - A4 (210 x 297 mm) , Up to 29 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 49 ppm - black landscape - A5 (148 x 210 mm) , Up to 49 ppm - colour landscape - A5 (148 x 210 mm) , Up to 24 ipm - colour duplex - A4 (210 x 297 mm) , Up to 24 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 25 ipm - colour duplex - ANSI A (Letter) (216 x 279 mm) , Up to 25 ipm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 7 ppm - colour portrait - A5 (148 x 210 mm) , Up to 7 ppm - black portrait - A5 (148 x 210 mm)
- Max Resolution (B&W)
- 600 x 600 dpi
- Max Resolution (Colour)
- 600 x 600 dpi
- Image Enhancement Technology
- HP ImageREt 3600
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Processor
- 800 MHz
- RAM Installed (Max)
- 1.25 GB (1.25 GB)
- Flash Memory Installed (Max)
- 4 GB
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PDF 1.7
- Media Type
- Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, postcards, glossy paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 55000 pages
- Recommended Monthly Volume
- 900 - 4800 pages
- Networking
- Print server
- Printer Features
- Instant-on Technology
- System Requirements
- UNIX, Android, Microsoft Windows Vista (32/64 bits), Ubuntu 10.04, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Apple MacOS X Lion 10.7, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), openSUSE 12.2, Red Hat Fedora 17, Ubuntu 12.10, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Red Hat Fedora 18, openSUSE 12.3, Linux Mint 13, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, openSUSE 13.1, Windows 10 (32/64 bits), Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x
- 1-year warranty
- 41.36 cm x 47.2 cm x 30.44 cm
- Printer Type
- Number of Users
- 3-10 users
- Localisation
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 600 x 600 dpi
- 600 x 600 dpi
- HP ImageREt 3600
- PostScript Support
- Standard
- Fonts Included
- 105 x TrueType , 92 x PostScript 3
- Printer Features
- Media Handling
- Processor
- 800 MHz
RAM
- 1.25 GB / 1.25 GB (max)
Flash Memory
- Flash Memory
- 4 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), B6 (125 x 176 mm), 76 x 127 mm, Oficio (216 x 343 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- Media Weight
- 60 g/m² - 200 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 150 sheets - Legal (216 x 356 mm)
- Max Media Capacity
- 850 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 55000 pages
- 900 - 4800 pages
- Networking
- Print server
- Network Controller Name
- HP Jetdirect
- Remote Management Protocol
- SNMP 1, SNMP 2, SNMP 3, HTTP, HTTPS, IPP 2.0, SLP
- Apple Bonjour, IPsec, 802.1x
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 2400 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 2100 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 2100 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 2100 pages ISO/IEC 19798
- TUV, GS, CECP, EN 62479:2010, EN 61000-3-3:2013, CISPR 22:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, LVD 2014/35/EU, EN 55024:2010+A1:2015, CE/EMC, EN 55032:2012, CISPR 32, EN 60825-1:2014, EN 55035:2017, Mercury-free, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, CISPR 35:2016 Class A, IEC 60825-1:2014 Class 1
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 574 watt
- Power Consumption Stand by
- 16.7 watt
- Power Consumption Sleep
- 1.1 watt
- Software Included
- Drivers & Utilities, HP Web JetAdmin, HP Printer Assistant
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- ENERGY STAR Version
- 3.0
- Limited warranty - 1 year - on-site
- 10 °C
- 32.5 °C
- 10 - 90%
- Sound Emission (Idle)
- 33 dBA
- Sound Emission (Operating)
- 48 dBA
- 41.36 cm
- 47.2 cm
- 30.44 cm
- 18.9 kg
- Width (Shipping)
- 49.7 cm
- Depth (Shipping)
- 37.9 cm
- Height (Shipping)
- 58.3 cm
- Weight (Shipping)
- 21.6 kg
HP 415A Black Original LaserJet Toner Cartridge | In Stock | £71.63 |
HP 415A Cyan Original LaserJet Toner Cartridge | In Stock | £96.74 |
HP 415A Yellow Original LaserJet Toner Cartridge | In Stock | £92.72 |
HP 415A Magenta Original LaserJet Toner Cartridge | In Stock | £92.72 |
HP 415X High Yield Black Original LaserJet Toner Cartridge | In Stock | £145.98 |
HP 415X High Yield Cyan Original LaserJet Toner Cartridge | In Stock | £199.80 |
HP 415X High Yield Yellow Original LaserJet Toner Cartridge | In Stock | £208.66 |
HP 415X High Yield Magenta Original LaserJet Toner Cartridge | In Stock | £199.80 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £16.69 |
