Print professional-quality colour documents at high speeds. Efficient paper handling and intuitive controls keep workgroups productive. With energy-saving features, your business can save money while reducing your environmental impact.
Powerful performance
Improve workgroup efficiency with print speeds up to 35 ppm A4 and a first page out in as fast as 9.5 seconds with Instant-on Technology.Handle a steady stream of print jobs and still stay productive.With 512 MB of memory, expandable up to 1 GB (1024 MB), this printer can store and process a large queue of documents.Easily integrate best-in-class networking and robust security options into your printing set-up.Expand the number of IP addresses on your network with IPv6. -
Brilliant, professional-quality colour communications
Achieve consistent, accurate colour with HP ImageREt 3600 and up to 1200 x 1200 dpi for smooth colour transitions, crisp text and sharp images.Save IT time and make printing easy for every user with the improved HP Universal Print Driver and HP EasyColor.Use Original HP supplies for outstanding, reliable results.Manage your colour printing costs using award-winning HP colour access controls, which enable you to assign colour access by user or by application, or turn off colour capability completely. -
Easy and efficient operation
Produce documents efficiently with automatic two-sided printing and a paper capacity of 600 sheets, expandable to 1,100 sheets.A 4-line colour display panel makes operation easy and straightforward.Simplify printing for multiple users and print jobs with HP Advanced Auto Media Sensing, which automatically adjusts settings according to paper type.With twenty-five years of continuous innovation and reliable, professional-quality printing, HP LaserJet remains the brand businesses count on. -
Minimise your environmental impact
Get up to 50 percent energy savings over competitive laser products, using Instant-on Technology.Reduce your impact on the environment and use up to 50 percent less paper with two-sided printing.Reduce packaging waste with pre-installed toner cartridges - no boxes, wrappers or manuals.Implement energy-saving settings across your entire fleet with HP Web Jetadmin.
- HP Color LaserJet Enterprise CP4025n - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 38.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 35 ppm - B/W - Legal (216 x 356 mm) , Up to 35 ppm - colour - Legal (216 x 356 mm)
- Max Resolution (B&W)
- 1200 dpi
- Max Resolution (Colour)
- 1200 dpi
- Image Enhancement Technology
- HP ImageREt 3600
- Interface
- USB, Gigabit LAN
- Processor
- 800 MHz
- RAM Installed (Max)
- 512 MB (1 GB) - DDR2 SDRAM - SO-DIMM 200-pin
- Language Simulation
- PCL 5, PostScript 3, PCL 6, PDF 1.4
- Media Type
- Envelopes, transparencies, labels, plain paper, cards, recycled paper, glossy paper
- Total Media Capacity
- 600 sheets
- Monthly Duty Cycle (max)
- 100000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet - integrated
- System Requirements
- Microsoft Windows 2000, Red Hat Linux 7.0 or later, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, SuSE Linux 8.x, Apple MacOS X 10.4, Apple MacOS X 10.3.9, Microsoft Windows Vista, Microsoft Windows 7 Professional, Microsoft Windows 7 Home Premium, Microsoft Windows 7 Ultimate, Microsoft Windows 7 64-bit Edition, Microsoft Windows 7 Enterprise, Microsoft Windows 7 Home Basic, Microsoft Windows Vista (64-bit versions), Apple MacOS X 10.5 or later, Microsoft Windows Server 2008
- 1-year warranty
- 54 cm x 52.2 cm x 42 cm
- Printer Type
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, Gigabit LAN
- 1200 dpi
- 1200 dpi
- HP ImageREt 3600
- PostScript Support
- Standard
- Processor
- 800 MHz
RAM
- 512 MB / 1 GB (max)
- Technology / Form Factor
- Slots Qty
- 1
- Empty Slots
- 1
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 216 mm x 356 mm
- Media Sizes
- Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), C5 (162 x 229 mm), JIS B5 (182 x 257 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 600 sheets
- Max Media Capacity
- 1100 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 100000 pages
- Networking
- Print server - integrated
- Data Link Protocol
- TCP/IP
- Remote Management Protocol
- SNMP 3
- IPsec
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Power Device
- Power supply - internal
- 740 Watt
- Power Consumption Stand by / Sleep
- 72 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site - response time: next business day
- 15 °C
- 27 °C
- 30 - 70%
- 54 cm
- 52.2 cm
- 42 cm
- 38.5 kg
- Width (Shipping)
- 74.6 cm
- Depth (Shipping)
- 64.4 cm
- Height (Shipping)
- 54.9 cm
- Weight (Shipping)
- 44 kg
